Tip & How-To about Washing Machines
Smelly washers
OK there are a lot of people with the smelly front load washer . the smell is caused buy a build up of detergent it is recommend that you use 2 tbs of detergent and 1 if you have a water softener. also leaving the door open after a washing is good to help it air out . to often people blame the door gasket because they get spots on them well the rubber used is a antimicrobial rubber so it cannot mold . the smell is actually soap build up trapped inside the washer if you run your washer with nothing in it and see soap suds your using to much detergent. there is hope though cutting back on detergent and using a product called Lemeshine mc3 will eliminate the odor issue.
Washing Machines Logo
stale odor within tub
Front loaders are known for building up mold and the smell.
It’s caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it 50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Pull the rubber door seal back and clean the mold off .
Affresh is recommended by some manufacturers. You run it through a wash cycle with it.
Dec 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The rubber seal at the front of the machine has gone mouldy. I have cleaned it before with bleach but the mould comes back all the time
Oct 21, 2009 | Bosch Nexxt 700 Series WFMC6401UC Front...
LG WM0642HW smells bad. We leave the door open when not in use to dry it out and air it out. But the smelliness is getting worse.
There have been lot's of reports of moldy door seals. Check your door seal at the bottom to see if it is holding water and not draining properly. Dry and clean with a bleach solution is it is. Front loaders don't always drain completely. WHen you start a new cycle the first thing they do is purge any water left from the previous one. This also causes a mold issue. Easiest solution is to do a stain cycle with presoak and add 2 cups of bleach to kill the mold. Obviously no clothes! Good luck!
May 10, 2009 | LG WM0642H Front Load
Kenmore front load HE washer odor
How old is your machine? Mine is 5 years old, and I just started to get a "sewage" smell in my laundry room this weekend. I disconnected the water return to the sewer line and discovered lots of gunk in the hose, and the connector to the machine was completely dark green. I'm going to replace the hose, and trying to figure out if there is some sort of filter.
We only use He detergents too, so I guess this is something that just happens over time.
Oct 09, 2008 | Kenmore Elite 45986 Front Load Washer
236 people viewed this tip
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
