Tip & How-To about Video Game Consoles & Games
Pairing a Headset to a Playstation 3 (PS3)
  1. On the Playstation 3, got to "Accessory Settings"
  2. Next, goto "Manage Bluetooth Devices"
  3. Next Select "Register New Device"
  4. At this point make sure that the headset is in pairing mode before selecting "Start Scanning"
Refer here to put headset into pairing mode:
http://www.fixya.com/support/r5009033-put_most_bluetooth_headsets_into_pairing
After pairing, go to "Audio Device Settings" and select your new headset as the Input and Output device and adjust the Microphone level to 5, if you can see the meter flash when you talk, your headset is working correctly, then hit OK.
If you don't know the Pin Code refer to here:
http://www.fixya.com/support/r5008953-pin_codes_most_bluetooth_headsets
If this helps, please give me a vote.
Thanks.
Video Game Consoles & Games Logo
How do I connect two bluetooth devices to one playstation?
settings> Accessory settings > manage bluetooth(R) Devices > Register New Device.
i do not know how mine you can have going at 1 time but i have 4 devices register in all.
May 26, 2011 | Video Game Consoles & Games
i keep having a problem with synchronizing my bluetooth to my ps3 it keeps not wanting to take it how do i fix this?
These are the steps to follow when you want to sync a Bluetooth to your Playstation 3.
1. Go to Playstation 3 menu then click "Settings," then "Accessory Settings"
2. Select "Manage Bluetooth Devices."
3. Select register new device
4. Press the button of your Bluetooth device then select "start scanning" on your Playstation 3.
5. Select the device you want to sync and if there is a passcode, enter the correct passcode and click "OK"
Mar 09, 2011 | Video Game Consoles & Games
how do you pair wireless headset with ps3?
On the PS3, navigate to Accessory Settings > Manage Bluetooth Devices. At the bottom, you'll then select Register New Device. Then place your bluetooth headset in pairing mode, usually by holding the power button until the LED blinks rapidly. Back on the PS3, then select Start Scanning and select your device. The PIN for all headsets by default is 0000.
Mar 02, 2011 | Sony Playstation 3 (PS3) Console
how do you connect the headset tothe ps3
Navigate to SETTINGS and scroll down to select ACCESSORY/PERIPHERAL settings menu, when selected scroll down to MANAGE BLUETOOTH DEVICES, follow the ADD NEW DEVICE to connect your Headset to your ps3.
Make sure your headset is turned on and in pairing mode.
now scroll down to select the AUDIO device settings and select your headset as your device, you are now ready to use your headset.
Jan 12, 2010 | Sony Playstation 3 (PS3) Console
connecting bluettoth to playstation 3
there are two different places in XMB to change your headset settings. If both of these are not active then it will not work. One is accessory settings Manage bluetooth devices and make sure the headset has a blue dot by it, the other is accessory settings also and audio device settings. Make sure the input and output device settings are set to the headset
Jan 10, 2010 | Video Game Consoles & Games
5,255 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
