Tip & How-To about Radio Communications
How to put most Bluetooth headsets into Pairing Mode?
There are two main ways to put your Bluetooth Headset into Pairing/Discovery mode:
1. For devices that have a Power Button
Start with the headset in the OFF state, then hold the power/action button until it goes into pairing mode (about 3-5 seconds). When in pairing mode, the light should be flashing red and blue or have a steady blue light, in most cases.
Then you can discover it with your phone or PC.
2. For device that have an On/Off SWITCH
Start with the headset in the OFF state, then hold the call/action button while you turn the headset ON. The headset should now flashing red and blue or have a steady blue light, in most cases.
If you forgot the pairing code, refer here:
http://www.fixya.com/support/r5008953-pin_codes_most_bluetooth_headsets
If you need a copy of your manual, refer here:
http://www.fixya.com/support/r4964670-get_manual_most_any_electronic_device
Radio Communications Logo
My iPhone 4 bluetooth won't discover the plantronics 220 Bluetooth earpiece for pairing. Both devices are on including bluetooth on my phone
On your phone, make sure bluetooth is turned on (settings, general).
While your phone is in discovery mode, turn your bluetooth device on and put it in discovery mode ***(usually you have to hold the power button for 7-10 seconds)***
Your phone will find the device, and you will be prompted to enter the devises PIN number (often 0-0-0-0). Your phone should pair with the device then.
Dec 31, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Plantronics 925 Discovery won't connect with Droid 2
  • Turn on Bluetooth within your phone - Consult phone instruction booklet
  • Put phone into pairing mode - Consult phone instruction booklet
  • Put headset into pairing mode - With headset off, press and hold Call Control Button
    until the headset begins to flash red and blue.
  • Select "Add new device" on your phone.
  • Select the Plantronics headset when prompted. Enter "0000" as passcode.
  • Your 925 headset will now have a continuous blue light blinking.
  • Choose "Yes" if your phones asks if you want to bond to the 925 headset.
  • Your phone is now paired with the Plantronics 925 headset and ready for use.
  • Please leave me a good rating!
    Sep 04, 2010 | Plantronics Discovery 925 Bluetooth...
    how do i get my plantronic 220 in discovery mode
    Hi,here is a detailed solution on how to set your plantronic headset into the discovery mode;
    STEP 1 You have to firstly put off the headset,by holding the call control button,which is the button on the face of the bluetooth,until the blue light turns red,as soon as the blue light turns red release the button.
    STEP 2 After putting off the headset,wait for like 5 secs to ensure its completely off.when the device is off,you can now press and hold on the call control button for 5secs if its the first initial pairing,if it's not,then you have to hold on the call control button for 8seconds,afterwards the light should flash red then blue in both cases
    STEP 3 At this point in time your headset is in discovery mode,and you have 60 seconds to pair it with your phone which should also be in the pairing mode as well.
    Your plantronics headset and your phone are matched up and you are good to go.
    Thanks and take care
    Apr 22, 2010 | Plantronics Explorer 220 Bluetooth Headset...
    HOW DO I PAIR A MOTOROLA n136 TO A LG VX5400
    follow the steps below:
    • Setting the headset into pairing mode
    1) Ensure the headset is fully charged
    2) The headset must be switch off
    3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
    4) The headset is now in pairing mode
    • Searching for the headset on the phone
    1) Go to “settings” or “connections”
    2) Select Bluetooth, then options
    3) Select Devices and click add
    4) The phone should search for any available Bluetooth devices and display what was found
    5) Select the Motorola device and click add
    6) You will be required to enter in a pass code which is standard ‘0000’
    7) If successful then the headset will start flashing BLUE every few seconds.
    • The headset is now paired with the phone
    Hope this helps
    Season's Greetings from Fixya!
    Chris (ziraffa)
    Dec 21, 2008 | Motorola Mobility HS850 Consumer Headset
    14,060 people viewed this tip
    Top Radio Communications Experts
    eradiostore
    eradiostore
    Mike Charette
    Are you a Radio Communication Expert? Answer questions, earn points and help others
