Tip & How-To about La Pavoni Europiccola EPC-8 Espresso Machine
La Pavoni Lever Machine Hissing?
If you have a La Pavoni lever model espresso machine and the safety assembley on the top right hisses while the machine is heating up, all you have to do is use something hard but preferably not metal or too large and tap the safety assembly quite firmly but not to hard and this should stop the hissing. This is because inside the assembly there is a bung on a spring and sometimes it becomes stuck and just needs a gentle tap to free it up. If it doesn't stop hissing then you can remove and stretch the spring or if needs be replace the spring and bung.
All the best
Mr La Pavoni
La Pavoni Europiccola EPC-8 Espresso Machine Logo
Why water drop before lever raised until top position?
\\this might be caused by a worn piston seal. see here how to replace seals.
dr pavoni
May 15, 2014 | La Pavoni Europiccola EPC-8 Espresso...
water leakage through grounds when lever is raised on my La Pavoni Europiccola.
Hi your grind is to course and or your tamp is to loose. Even with the right grind and tamp water will filter down through the puck eventually.
all the best
Dec 20, 2013 | La Pavoni Europiccola EPC-8 Espresso...
espresso comes out of comes out of spout before handle is raised
Hi there, i am Mr La Pavoni and am based in Glasgow, Scotland. I service and repair these machines all day every day and basically it could be a couple of different things. If it is pre 2000 then it could either be the piston gaskets or the piston shaft has come slightly unscrewed from the piston head. If it is post 2000 then it could be any of the above but also in these models there is an additional sleeve inside the group head which may be cracked or the seal on this part may need replacing. It could even just be a tiny bit of debris on one of the piston gaskets. If you have removed the shower plate and gasket and then taken out the piston assembley then you should really replace these gaskets anyway. You can purchase the parts on my website www.theespressoshop.co.uk which are all individually priced and every part is available for the lever machines. If you require any further assistance then please do not hesitate to get in touch at domesticespresso@live.com
All the best
Mr La Pavoni
May 14, 2010 | La Pavoni Europiccola EPC-8 Espresso...
we have a La Pavoni epg-8 Latte machine. When I turn it on steam escapes through the cap of the boiler. We have only used it about a dozen times, so its practically new. the O-ring appears to be in good shape. I don't know if I lost a piece on the inside of the cap. If I look inside of the cap of the boiler I see a hole in the center. If I fill the cap with water it seems to drain out the center hole. What am I missing?
I am an engineer that services these machines on a daily basis. Good news - you are not missing anything at all. The type of cap you have, has a safety release valve built in which will be the hissing sound. If you fill the boiler as normal, turn on the machine and allow to boil up as normal and if steam starts hissing out and does not stop then just give it a light tap and this should stop. Basically when these machines are new the spring inside sticks and once you have tapped it a few times to release it, it should loosen it up and it will give a brief hiss then stop as the machine heats up. I hope this helps but if you have any further questions you can get me at domesticespresso@live.com
All the best
Mr La Pavoni
Jan 05, 2010 | La Pavoni EPG-8 Espresso Machine
Hi there, Where can i buy a replacement heating element for the Europiccola Copper-Brass Espresso machine? V220 W1000
Hi there
I supply all La Pavoni spare parts and dispatch all over the world. Go to www.theespressoshop.co.uk and click on the la pavoni machine on the right to access the full parts list. We have all variations of the elements.
All the best
LaPavoniBoy
Feb 22, 2009 | La Pavoni Europiccola EPC-8 Espresso...
737 people viewed this tip
Top La Pavoni Coffee Makers & Espresso Machines Experts
billconfused
Pieter Vleeshouwers
Pieter Vleeshouwers
NOEL
NOEL
Are you a La Pavoni Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
