Tip & How-To about Computers & Internet
How to fix common issues in windows vista & windows 7
Hi friends
I find very cool utility called FixWin. It is a 529 KB freeware portable application to repair & fix common Windows annoyances & issues. It works of windows vista & windows 7 only. Just download & run it.
You can find more detail and download it form here.
Please Vote for this Tip if you found it helpful….
Computers & Internet Logo
can't run program winfix
Repair & Fix Windows 7 & Vista problems with FixWin Utility
RECOMMENDED: Click here to fix Windows errors and optimize system performance
We are pleased to release a first-of-its-kind application for Windows 7 & Vista: FixWin. FixWin is a 529 KB freeware portable application to repair & fix common Windows annoyances & issues. FixWin detects whether you have Windows 7 or Windows Vista installed and accordingly offers you the relevant fixes only. Windows 8 users may want to downloadFixWin v2 for Windows 8.
UPDATE: 19th March 2010. FixWin v 1.2 has been released which includes some minor bugfixes and UI changes. The download links mentioned below point to FixWin v 1.2 now.
While there were several tutorials and how-to's already available on the Internet to deal with such annoyances, FixWin as a single utility was conceptualized, to fix some of the common annoyances which may be faced by a Windows user.
Does your Recycle Bin not refresh correctly? Or maybe you find that for some reason your right click context menu has been disabled in Internet Explorer! Or perhaps things are not fine with your Windows Media Center and you need to flush & rebuild Windows Media Center database! Maybe you opted to be not-warned while deleting Sticky Notes and you now want the warning dialog box back! Or then perhaps, post a malware attack you find that your task manage or cmd or yourRegistry Editor has been disabled! Fixes for these and many more such common Windows problems are being offered here.
The solutions to repair and fix 50 common Windows annoyances, issues & problems have been categorized under 5 tabs, viz : Windows Explorer, Internet & Connectivity, Windows Media, System Tools & Misc Additional Fixes.
1. We first suggest that you run the System File Checker Utility. The button provided on the Welcome page, will 'run sfc /scannow' and will check for and replace any corrupted Windows system files. It is expected to take anywhere from 5-10 minutes. If asked to, do reboot.
2. Next we insist that you create a System Restore Point. The provided button will create one, called Safe Point. We always recommend that you create one before making any changes to your system. Should you wish or need too, you can always go back to this Safe Point.
3. Having done that, apply at most one fix at a time and restart your computer. Please check if things are to your satisfaction; and if not, you have the option of restoring back immediately.
It has been tested on Windows 7 & Vista, 32-bit and 64-bit versions. However, FixWin may fail to run if you have modified Windows 7 or Vista Image using third party app like vLite etc, as it may miss some core components required for FixWin to run and thus cause of failure.
thewindowsclub com
Apr 06, 2014 | MSI Computers & Internet
music player not functioning
If you Windows Media Player won't work you can try fixing it with Fix WMP Utility. Fix WMP Utility is a freeware portable app re-registers all the concerned Windows Media dll files required for the smooth functioning of Windows Media Player.
If you are facing any issues or getting any error message while running Windows Media Player, run this utility. It will re-register more than 40 dll files that are needed to ensure the proper smooth functioning of Windows Media Player.
Please run this utility and see if it addresses your issues, before moving on to advanced trouble-shooting.
Click Here to Download
Mar 22, 2011 | Computers & Internet
avira anti virus can't install
Un-install Avira Anti-virus Then Download and Scan By Using Glary Utilities
Optimize, clean and boost the speed of your Windows.
Protect your privacy and security.
Block spyware, trojans, adware, etc.
Fix certain application errors.
Simple, fast and User friendly interface
For only private use One Click A Day For PC Maintenance, Keeps Any PC Problems Away. With millions of worldwide users, the first-rank & free Glary Utilities is an INDISPENSABLE friend for your PC, with its 100% safe, thorough & quick cleaning and worry-free restoration.
Glary Utilities is a freeware with registry and disk cleaning, privacy protection, performance accelerator and amazing multifunctional tools. It can fix dogged registry errors, wipe off clutters, optimize internet speed, safeguard confidential files and maintain maximum performance.
The era of PC vex is dwindling as Glary Utilities comes. It is a freeware with registry and disk cleaning, privacy protection, performance accelerator and amazing multifunctional tools. It can fix dogged registry errors, wipe off clutters, optimize internet speed, safeguard confidential files and maintain maximum performance.
It is designed for both novice and professionals. User-friendly interface shows clear & detailed directions. For novice, all work can be done with just 1 or 2 clicks, while for professionals, abundant options are available.
To call Glary Utilities helpful would drastically understate the situation. It hopes to become your INDISPENSABLE friend with its one-stop-shop utilities for optimizing and maintaining your PC for best performance. My friend, welcome to have a try for Glary Utilities and have your say! To download Glary Utilities Press here http://download.cnet.com/3001-2239_4-10322935.html?spi=b1d949f58a45ea56498a7664cb708430
Download by Using ATF-Cleaner.exe was once upon a time just my personal temp file cleaner. There became a need for a good temp file cleaner that could do the job safely and without removing files that are crucial to windows, so I decided I'd share it with the public.
ATF-Cleaner has recently picked up alot of interested in the various communities online.
ATF-Cleaners options are fairly straight forward and its simplicity is part of its charm.
The general instructions for its use on the forums are as follows:To Download ATF-Cleaners press here http://www.atribune.org/index.php?option...
then Restart you Computer,after you Computer it is open Windows Now Download Again Avira Anti-Virus Press here http://download.cnet.com/3001-2239_4-10322935.html?spi=b1d949f58a45ea56498a7664cb708430
Jan 03, 2011 | Avira AntiVir Personal - Free Antivirus
hd hard error
  • HI
  • TO TEST THE HARD DRIVE ON THE COMPUTER
  • Run the Windows Check Disk utility. This utility will check and repair system file errors (logical structure), and examine the physical structure (the integrity of the disk surface) as well. Close all applications, browsers, and utilities.Open My ComputerRight-click your hard drive (C:)Click Properties, then click Tools TabUnder Error-Checking, click Check NowClick check box for "Automatically fix file system errors"Click check box for "Scan for and attempt recovery of bad sectors"Click Start to run the utility
  • Download and run the freeware diagnostic tool "HD Tune". This terrific tool will run a complete benchmark analysis of your hard drive, check for structural errors, examine overall health issues item by item, and more.
  • Download and run the freeware diagnostic scanning tool "Emsa DiskCheck". This tool is a dual purpose utility for disk checking (pre-scan and full disk reading) and benchmarking.
  • THANK YOU
  • Sep 13, 2009 | Dell Latitude D600 Notebook
    125 people viewed this tip
    David Payne
    David Payne
