Tip & How-To about Computers & Internet
Reset forgotten Windows Vista Account Passwords
My son has an HP laptop and playing around, changed his password and then couldn’t get into his account. There were a number of problems here, any of which we could have fixed had we been paying more attention earlier on (like soon after he got his laptop):
  1. We could have created a password recovery disk (which can also be on a USB keyfob) – but we didn’t.
  2. We could have created a secondary administrative account on the machine with a password known only to me, his dad – but we didn’t.
We’ve now done both of these things since we were able to restore access to the machine under his previous password. But it was a bit of a trick to get access under the previous password. I figured we were going to have to reinstall Vista, using the File and Settings transfer program to first grab his old settings and files, and then reinstall all the programs – probably a 3-4 hour undertaking. But then I had another thought.
Method 1. The key here was using Vista’s System Restore feature.
The exact steps will probably vary on your machine (and this is from my memory on his HP laptop, having just done this) but roughly what we did was:
  1. Harangue him for a few hours to try to remember his password, try different variations (with and without caps lock on, for instance) and try omitting characters he might have thought he typed when he changed the password but didn’t. That didn’t work.
  2. Reboot the machine and press F11 while it’s booting – on HP machines, this gets into the "recovery console" which is thoughfully put on the system disk in a separate partition by HP.
  3. Select to restore the system (note: not restore to it’s original factory condition – that will reformat your main partition and wipe out your files, which we really wanted to avoid).
  4. Chose to reset to an early restore point – in his case, there was a restore point just four days old. Vista creates these restore points regularly. The only thing he had done in the last four days was reset his password, so I thought there was a chance that Vista might reset the old password along with the restore point. I wasn’t sure it would, but I thought it was worth a try.
  5. It took about ten minutes for Vista to do this and it then rebooted – and he was thrilled that he was able to log in with his old password!
I’ve used System Restore in other cases to get rid of really wierd behavior, and it always works like a charm. This is yet another use.
Oh, yeah, and we then created a secondary administrative account on the machine. Do that right now if you have a laptop with just one admin account – then squirrel away the password somewhere safe at home and you’ll thank yourself one day.
Method 2. Use windows password key 8.0
Step1: Choose the existing windows password key 8.0 image file.
You can click "Browse" to browse Windows Password Key 8.0 image file. The file is usually located as the default.
Step2: Choose your CD/DVD drive:
Select "CD/DVD" and specify the CD burning drive from the pull-down list. Insert a blank CD/DVD disk into the CD-ROM drive.
Step3: The burning process starts.
Windows Password Key extracts the ISO image and copies the necessary files on a CD.
Step 4: Put in your newly created CD and remove your Windows password:
1. Insert newly created CD in your CD drive and reboot your computer.
When the CD boots, you’ll see Windows Password Key 8.0 initializing (see screen shot below). If so, you can continue to the next step. If the computer boots still boots into Windows, it’s necessary to change your computer’s setup to make it boot from the CD.
Step 5: restart the machine.
Enter the recently changed password for the local user. Then you will get the above message stating ‘The user’s password must be changed before logging on the first time’
Click OK and type in the new password
Voila, you have just changed the password for the local account. Now you can login with the newly created password.
Computers & Internet Logo
do you just not want me to use facebook? Why wont you help me?
When you want to log into your facebook you use your phone number phone and password but it takes you to your sons account. so when it does this log out of the sons account then reenter your phone number and your password. your password is different then your sons? if your using the same computer it will remember what the last person typed. don't share password or phone number on fixya we don't need to know
Jul 12, 2015 | Toshiba Computers & Internet
my son is 9 yrs old. I need to change his password because of explicit content
if you have an administrator account that is no problem. If you, like most people, let him have an administrator account this can be a problem. He needs to login for you and you need to create an Administrator account for YOU, and after creating that and password protecting it, you need to change his account to limited user. THEN, you can change his password.
Sep 28, 2013 | Computers & Internet
I CANT GET INTO MY LAPTOP!!! HELP!!!
Most of the time the default windows installations leaves the Administrator account active with a blank password to back door for cases like these.
First try logging in using username ADMINISTRATOR and don't type anything for the password. Click ok to see if that gets you in. If it does then you can go to your account settings and change the password for your default account. If not there may still be other ways but this is typically the easiest.
Nov 17, 2008 | Microsoft Windows XP Professional With...
HP dv6000 Computer locked
i take it you mean the user password on xp turn off your pc start in safe mode by pressing f8 key as it boots up you will have to play with timeing here you should get a black screen select safe mode this will put you in as adminastrater then go on user accounts find yor account click chane password or remove
Jul 29, 2008 | HP Pavilion dv4000 Notebook
Acer Aspire 5315 - Help
It depends on what operating system your using, if it's windows XP then you should be able to press 'control' 'alt' and 'delete' twice when it comes up with the logon screen. This will then give you the option to log into an account called administrator. This will either have no password, or have the same password that you originally used to setup the account. From here you should be able to either change the password of the other account or, create a new account.
Failing that you can hang your son upside down from a window untill he remembers.
Mar 31, 2008 | HP Pavilion dv6000z Notebook
228 people viewed this tip
David Payne
David Payne
