Tip & How-To about Microsoft Windows Vista Home Premium Edition for PC
Find the 24 Trubleshooters in Windows7 We all know we need them so here is the current list and how to find them. 1. Aero 2. Display Quality 3. Hardware and Devices 4. Home Group 5. Incoming Connections 6. Internet Connections 7. Internet Explorer Performance 8. Internet Explorer Safety 9. Network Adapter 10. Performance 11. Playing and Burning CDs,DVDs and Blu-ray Discs 12. Playing Audio 13. Power 14. Printer 15. Program Compatibilty 16. Recording Audio 17. Search and Indexing 18. Set up TV Tuner 19. Shared Folders 20. System Maintenance 21. Windows Media Player DVD 22. Windows Media Player Library 23. Windows Media Player Settings 24. Windows Update Getting To The tools And Have Them All On One Page. Go to Start and left click. Go to Control Panel and left click. Left click in the search box top right,and type troubleshooter. Now look to the left side you'll see Troubleshooting,left click that. Now look back to the left side and you will see the words View all,left click that. When the new window opens you'll see all tools listed on one page. Hope this tip helps.
Microsoft Windows Vista Home Premium Edition for PC Logo
dont get aero
To display Aero effects such as transparency in Windows 7/Vista, follow these steps:
1. Click on Start menu.
2. Type the following text into the Start Search box: Aero
3. Click on a search result listing under Control Panel group that named as the following:
Find and fix problems with transparency and other visual effects.
Trick: If you don't see "Find and fix problems with transparency and other visual effects" in the search results, click on Control Panel to see all Aero related items in Control Panel.
4. An "Aero - Troubleshoot computer problems" wizard dialog will appear. Click on Next button.
5. The troubleshooting wizard will try to detect any problem by running a series of checks against various components required to make Aero works and running, such as video memory, Desktop Windows Manager (DWM) service, color depth, theme, power settings and etc. At the end of the analysis, the wizard will attempt to fix the issues related to Aero service and restart the Aero feature.
Tip: If there is still items that are marked with red cross which indicates is the problems that prevent Aero from working properly, fix the issues and then rerun the "Find and fix problems with transparency and other visual effects" troubleshooting wizard again.
Tip: To create a shortcut to 'Find and fix problems with transparency and other visual effects', right click on it on search results, and then click on Open file location. On the "All Tasks" window opened, right click on Find and fix problems with transparency and other visual effects again, and select Create Shortcut to place the shortcut on desktop.
Hope this help. Goodluck!
Mar 28, 2011 | Biostar P4M890-M7 Motherboard
Ssss
Trying to run too many programs at the same time can cause display problems such as jittery or choppy video. If you notice erratic or reduced visual performance on your computer, try one or more of the actions described below.
1.The more programs you have open, the more system resources Windows needs. Try closing programs that you're not currently using, or reducing the window size.
2.Even if you have only a few programs running, some programs (such as video-editing programs) and features (such as high-definition television) use a lot of system resources. Running too many of these programs at the same time puts a strain on system resources and might degrade display quality or make video appear jittery or disconnected.
On some computers, very high resolution require a lot of system resources to display properly. If you notice problems at high resolutions, try lowering the resolution until the problems disappear.
1 open display from control panel
  1. In the left pane, click Adjust resolution.
  2. In the Resolution list, click the resolution you want, and then click Apply.
If you set the DPI higher than 96, and you're running the Aero desktop experience, the text and other items on the screen might appear blurry in some programs that aren't designed for high-DPI display. To avoid this problem, follow these steps:
To make text and on-screen items clearer in programs that aren't designed for high DPIIf you set the,
  1. In the left pane, click Set custom text size (DPI). ?id=18abb370-ac1e-4b6b-b663-e028a75bf05b If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  2. In the Custom DPI Setting dialog box, select the Use Windows XP style DPI scaling check box, and then click OK.
Dec 11, 2010 | Vga (CAT5-1000S/R) (EXTCAT51000)
How do I set the current time on the Woods Digital Timer Model#59203?
78a8604.jpgWoods 59301
Manual for 59301
http://waterheatertimer.org/pdf/Woods-59203.pdf
Plug timer in wall for 1-2 hours so rechargeable battery charges
If display does not show after 1-2 hours, the battery is dead and timer is no good
After 1-2 hours, you can remove timer from wall to program
Press reset (R) with paper clip to clear memory
Select format: Press and hold Clock button until 12 hour or 24 hour shows on display, then release
Press hour button to change display to 12H
press Clock button and display returns to normal
AM shows in upper left corner
Set current time:
Press and HOLD clock button
While holding clock button, press hour button and minute button until display shows current time
Release clock button
Press and HOLD days button until current day shows in display
Release days button
Further instructions to set ON-OFF times are in manual (click link shown above for manual)
If you have problems, re-post additional question.
Oct 17, 2010 | Woods Indoor 24 Hour Digital Timer (59203)
need to reset the drum counter on the AL 1740 sharp while changing to a used drum
Entering in the simulation mode:press Clear - Interrupt - 0 - Interrupt -Main code - Start -Subcode - Start.
When the clear all key is pressed the simulation mode is cancelled.When the interrupt key is pressed,the proces is interrupted and the screen returns to the subcode entering display.After cancelling the simulation mode be sure to turn OFF/ON the power and check the operation.
Main code 20 subcode 1 =Maintenance counter clear.
Main code 21 subcode 1 =Maintenance cycle settimg
subcode 2 =Mini maintenance cycle setting.
Maincode 22 subcode 1 = Maintenance counter display
subcode 2=Maintenance preset value display
subcode 3=Jam memory display
subcode4=Total jam counter display
subcode 5=Total counter display
subcode 6=Developing counter display
subcode 7=Developing preset counter value display
subcode 9=Paper feed counter display
subcode 12=Drum counter display
Maincode 24 subcode 1 =Jam counter clear
subcode 2=Trouble memory clear
subcode 7=Drum counter clear
subcode 8=Copy counter clear
Maincode 26 subcode 22=Language setting
Maincode 42 subcode 1=Developing counter clear
Maincode 43 subcode 1=Fusing temperature setting
Maincode 46 subcode 1=Copy density level adjustment
subcode 19 AE mode picture quality change
Nov 20, 2009 | Sharp AL-1641CS Laser Digital Copier
2,818 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
