Tip & How-To about RIM BlackBerry? Tour 9630 Smartphone
How to move applications on a BlackBerry Tour
With its default setup, when you download an application to your BlackBerry Tour, it goes into the Downloads folder. However, this isn't where most users want to keep their applications -- typically they move them to the Applications folder, the Home folder, or a custom folder.
To move an application, highlight its icon with the trackball and press the BlackBerry button (the one with seven dots to the left of the trackball) and select "Move To Folder" from the menu that pops up. A list of all of your folders will appear; select the folder you want to move it to and either press the trackball or the Enter key. The application will disappear from the current folder and it can now be found in the folder you moved it to.
You can also move the application around within that folder, if you want to switch the order of programs. This can be useful for the Home folder if you're using the Zen layout, because the first six programs in the Home folder appear on the main screen. To change the order of applications within a folder, hover over an application you want to move, press the BlackBerry button, and choose "Move." Then go to the position you want to place the folder, and press the trackball.
If you want your downloaded applications to go somewhere else rather than the Downloads folder, you can specify a location by clicking the BlackBerry button when you're in the Home folder and selecting Options. Scroll down to Downloads Folder, press the trackball or Enter, and choose a new folder to save your downloaded applications to. (Be sure to save your change when exiting the Options screen.)
RIM BlackBerry? Tour 9630 Smartphone Logo
blackberry tour will not ring
It sounds like a software fault. Even more so if nothing is behind the buttons to cause them getting stuck.
You need to download the latest version for your device from the carrier the phone was sold with.
Save the folder to your desktop, double click it to install it your computer. (can take 40 mins to download)
Then you connect up the blackberry and using the program called application loader,(which is built into the desktop manager program that came on the cd) push the new software to the device. Ensure when you see an 'advanced' box, you click into it, to check both check boxes to remove all current installed software.
Here is a list of software carrier sites:
http://na.blackberry.com/eng/support/do ... _sites.jsp
And Also
Use BlackBerry Application Loader to install BlackBerry Device Software
Good Luck and let us know how you go..
9/10 times this is a software fault.
if the Problem is resolved..
then vote me
Jan 04, 2010 | RIM BlackBerry? Tour 9630 Smartphone
how do i solve the APP Error 523 on blackberry tour. I have no password set, i have the OS version 4.7 on the blackberry device. The device loads and shows the error APP Error 523 and reset. Upon reset it agin loads and goes back to the white screen with App error 523 and reset. Please let me know how i can resolve this problem
I had this same problem it was from a third party application that I had downloaded. Go to blackberry.com, and select support and search your APP error it will walk you through a guide on getting it fixed--although your phone will reset back to default.
Sep 27, 2009 | RIM BlackBerry? Tour 9630 Smartphone
624 people viewed this tip
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
Jason
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
