Tip & How-To about Cameras
How to maintain camera battery and lengtens camera battery life ?
Camera batteries tips for use and promote battery life:
Camera batteries could cause failure of turning on a Camera easily. Try to turn battery off and turn on Camera through the outside electrical source when Camera can't turn on and all the indicator light if off.
Why Camera battery can't charge to 100%?
Generally speaking,batteries for Camera usually can't charge to 100% due to the display problem but not the battery fault. After adjust the electricity display 1-2 times,it will show correctly.
Whether Camera Samsung BP70A battery life will be cut down when Samsung BP70A battery hasn't run out and is charged?
Samsung BP70A Battery life is generally computed by the times of full charge.Lithium battery usual have 300-400 times and once is defined charge it up to 80%-90%. So don't be worried.
What is the best temperature for battery storage?
Because very hot or cold conditions could affect a battery's performance and such as canon lp-e8 battery life,you'd better store the canon lp-e8 battery in a place with recommended storage temperature of 15°C (59°F).
Camera Batteries Note Of Don't:
Battery can be only used on the designated equipment.
1.Do not heat the battery or dropped into the fire.
2.Do not put it near fire or into the car at temperature over 60'.Do not discharge under these circumstance.
3.Do not put the battery into the water, do not make them wet.
4.Do not put the battery with necklaces, hairpins, coins, or screws and other metal items together in pocket or bag, they should not be stored together with the battery with the above-mentioned items.
5.Do not reverse the positive and negative when load the battery.
6.Do not use sharp objects to pierce the battery.
7.Do not break down the battery.
8.Do not weld the battery directly.
9.Do not use battery with serious wounds or deformation.
Before use your new battery, please read the operating instructions. Improper operation may lead to battery heat increasing, fire, explosion, destruction or attenuation of battery capacity.
Cameras Logo
My samsung GT-19100 WONT TURN ON OR CHARGE?
1.Check that the battery life has been corrupted or the battery is a consumable, if damaged or used improperly lead to premature failure of the battery, you can try to change a battery, see if you can start, if the problem is solved, you need to replace the battery.
2.Failure to use the phone a long time, the quality is not very good the cottage, the most easily damaged, leading to problems inside the phone will not turn on, and this time you can search for the specific situation on the Internet, request the help of friends to be under warranty go to solve after the carry out repairs.
3.Brush water or damage caused by man-made nature of this problem is the cause of your own, and water, then use a hair dryer blowing a blow, disassemble baking try, if broke, damage internal parts, you need to find a service center for repairs a. If the cause can not boot brush can be re-brush machine to try to recover.
4.If the basic methods are tried, or invalid, you can only go to a professional service center for repair, generally unable to solve their own good power failure, you can also try to search to see if there is no solution for you Method.
Jul 22, 2015 | Samsung Cell Phones
my samsung L730 digital camera will not turn on, i have charged it overnight and am using a lithium ion rechargablt battery that came with the camera
Some lithium-ion really loose their life easily and sometimes quickly.They are affected by temperatures too.I noticed that when I am charging the batteries tend to heat up and I found out they loose their power quickly when you let them charge and leave them warm.Secret to of prolonging their life is after a full charge zip lock it and freeze them.Of course dry them upon use.Do try a new set of batteries it will resurrect your camera back to life.
Nov 25, 2010 | Samsung L73 Digital Camera
Kodak EasyShare C433 won't turn on
alkaline batteries are fine .. they should not cause any problems if they are actually good .. its not unusual to see a dead cell in a package of new, usually off brand batteries ... not as likely with quality brands but still possible ... make certain that the batteries are inserted correctly .(proper polarity) .. examine the metal contacts that touch the ends of the batteries for damage or green corrosion .. you can clean them with alcohol and a Q-tip .. also clean the battery ends.. make sure the batteries + tip actually can make contact .. there is often a plastic barrier that prevents any contact if the battery is in backwards .. the + tip should fit inside that barrier and touch the metal contact .. once in a while the tip on a battery will be too short to make contact (try an different brand battery) .. .. if you have a charger or external power supply .. you can test the camera to see if it works even without the batteries .. if the cameras CPU got spooked (usually by static) .. then you might have to reset it .. there may be a key sequence that you hold down as you power the camera that will do a reset ... that might be mentioned in your instruction booklet .. sometimes there is a tiny hole with a reset switch inside .. you poke with a pin ... sometimes you can simply leave the batteries out for a few hours or a day .. so that any internal keep alive circuits get discharged .. then when you reinstall new batteries the camera will reset .. good luck .. hope it comes to life for you ..
Apr 09, 2009 | Kodak EasyShare C433 Digital Camera
Short or No Battery Life
Please eject camera battery and clean with a pin your battery tip in your camera with care fully.
Hope its helpful to you
Oct 09, 2007 | Canon PowerShot S1 IS Digital Camera
292 people viewed this tip
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
