Tip & How-To about Computers & Internet
How to remove Autorun.inf
Here are some typical malware which can install autorun.inf.exe file to your computer and give your computer a critical strike.
Autorun.inf virus contains three execute files which are kavo.exe, ntdelect.com and autorun.inf. All of them are hidden files. You cannot find the by showing hidden files. The only way to find them is to use DOS command.
Not all user have computer savvy. I was suffered from this virus a lot. Success got rid of it using RegTool and want to share it with you.
To remove Autorun.inf
Tools you need RegTool and AVG anti-virus.
Also here is an easy way to remove Autorun.inf manually!
click Start>Run>enter “CMD” them you will see and command window. In the command prompt, you can search for any exe.files. First we can disable “read only” and “hidden” attributes.
Enter the word in prompt.
Check C drive: key in dir c:\/a/w
2 then
attrib -s -h -r c:\autorun.inf
attrib -s -h -r c:\ ntdelect.com
You can use the same way to disable attributes of other drive such like D, E, etc.
3 OK, everything is done, we can now remove these two files.
For C drive, you can enter
del c:\autorun.inf
del c:\ntdelect.com
The same to D drive
How about kavo.exe? You need to repeat step1 and step 2 to disable attributes.
The delete command is different with them.
attrib -s -h -r c:\windows\system32\kavo.exe
del c:\windows\system32\kavo.exe
last thing you should do:
Open registry editor by entering Regedit.
Go to HKEY_LOCAL-MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run
Remove Kavo value.
Computers & Internet Logo
I have windows os and there is a autorun.inf something hidden file in my all drives.my avira antivirus has blocked that file.and i want to know that is the file safe or it is going to harm my pc.what should i do?
Autorun.inf is the primary instruction file associated with the Autorun function. Autorun.inf itself is a simple text-based configuration file that tells the operating system which executable to start, which icon to use, and which additional menu commands to make available. In other words, autorun.inf tells Windows how to deal open the presentation and treat the contents of the CD.
That being said, it would depend on what it is trying to run automatically. If it is trying to run iTunes automatically that is one thing, but if it is running a virus automatically it would not be safe.
You can right click on the file, and edit it with notepad/wordpad to find out what program it is trying to run.
May 02, 2011 | Computers & Internet
Antivirus for ''doomsday'' virus
I had this virus, and the following procedure seemed to work in getting rid of it for me. Hopefully it works for you as well.
open command prompt my going Start > Run and typing cmd.
You should be in a directory called something like “C:\Documents and Settings\User”. if you are not, change to it by typing ‘cd’ and the directory above (replacing ‘user’ with your username), and then pressing enter.
type ‘attrib’ and press enter. There should be a file called svchost.exe, and will have the attributes SHR (which stands for System-file, hidden, and read-only).
type ‘attrib -s -h -r svchost.exe’. This removes the SHR properties and allows you to delete the file.
type ‘del svchost.exe’. This should delete the virus from your computer.
NOTE: svchost.exe is a critical system file if it is located in C:\WINDOWS\System32. If it is located elsewhere (as this one is), it is generally a virus.
Then, insert infected pen drives (memory sticks, iPods etc.) which carry the virus. Change the directory to the pen drive by typing ‘E:’(or whatever letter it is) ENTER. Then type ‘attrib’ as above.
there should be the files ‘protector.exe’ and ‘autorun.inf’ which also have the properties SHR. type ‘attrib -s -h -r’ ENTER, and then delete the files by typing ‘del autorun.inf’ ENTER then ‘del protector.inf’ ENTER. This should remove the virus. Autorun.inf might reappear, but this shouldn’t be a problem.
Do not open the pen drive after you insert it, and cancel any autorun windows that come up.
May 13, 2010 | Computers & Internet
autorun.inf virus prob.
go to start button and press run option type cmd type cd\  2. type c: and press enter
3. type attrib -r -h -s autorun.inf
4. type del autorun.inf
Apr 01, 2009 | Microsoft Windows XP Home Edition
unable to delete the autorun.inf
hi azhar here form Karachi it is very easy. do, the below steps
reboot ur PC in safe mode with command prompt
when u bring a dos screen just move to ur drive mostly virus stayed in d: drive got d: drive and type
d:dir/ah and press enter
if u see there any auto run.inf file there also should be another file like .exe file or .bat or any kind of unknown , file so for delete the auto run file type attrib -s -h -r autorun.inf and press enter
then type del autorun.inf and hit enter here u go u have done.
do the samr process in all drives because mostly autorun.inf file make copy in all drives
remember autorun inf is just a file which help the virus to run autometicly
Feb 12, 2009 | Microsoft Windows XP Professional With...
241 people viewed this tip
David Payne
David Payne
