Tip & How-To about Sharp AL 1631 Copier
All sharp 1631 and 1642 models have scan unit problem.
When scan unit doesn`t move you have (L1-from left to right)and (L3-from right to left)code or blank copy (white).first must check scan uniy lock under the scan unit-then service 2 plates that scan moves on it.
Sharp AL 1631 Copier Logo
my Sharp AR5520 display L which is blicking how do i solve the proble m
always "L" code followed by number 1,2,3,4. so if you have L1, L2 or L3 your problem in the optical unit try to remove the copy glass and check the scanner movement by hand. and if the code L4 that mean you have driving machine problem some time this problem cause by toner cartridge so check it .
Feb 17, 2011 | Sharp AR-5320 Black and White Copier
WHAT DOES A L1 MEAN
The L1 is indicating a scanner lock.
1. Turn machine off.
2. Make sure the scanner lock is unlocked. This is a clear plastic knob. (it is located on the left hand side of the machine under the document glass in the copy exit area - check your manual for a picture.)
3. Turn machine back on, watch scanner to see if it moves.
4. Try a copy.
5. If you still get an L1 then it might need service because the scanning bar is jammed.
This also is a fix if you are getting blank copies.
Hope that helps...
Jun 23, 2008 | Ricoh 3310LE Copier
Getting an error L flashing then 1
Background:
Easy way to fix it:
2. Turn scan locking switch to unlock. This is a clear plastic knob. (it is located on the left hand side of the machine under the document glass in the copy exit area - check your manual for a picture of it around page 9 or so).
3. Turn machine back on.
4. Try a copy.
5. If you still get an L1 then it might need service because the scanning bar is jammed. They will ask you to try some service codes first to verify that it is indeed jammed. Call 1800 237-4277 for further support.
Followup:
Mar 18, 2008 | Sharp AL-1641CS Laser Digital Copier
2,971 people viewed this tip
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
