Tip & How-To about Computers & Internet
How to enable CD digital audio extraction
(Digital CD Audio Playback)
1. Click START / SETTINGS / CONTROL PANEL / SYSTEM.
2. Click the HARDWARE tab.
3. Click DEVICE MANAGER.
4. Click the plus (+) to the left of DVD / CD-ROM DEVICES and double-click your CD-ROM drive. Note you can also right click and select Properties.
5. Click the PROPERTIES tab and toggle ENABLE CD DIGITAL AUDIO EXTRACTION FOR THIS DRIVE.
6. Click OK
Repeat steps 4-6 for any other ROM drives listed in Device Manager.
Note you may need to reboot your computer for the change to take effect.
At this point CD digital audio extraction should be enable and you do not need to have the CD audio cable connected between your ROM drive and sound card. Note if you have an older computer (CPU under 1G) then you may need to have CD digital audio extraction turned off because your computer may not be able to handle the data from the CD on the system bus.
Computers & Internet Logo
sound problem with windows 7 32bit intel MB dg31pr
click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker you might have to configure them then select properties you will see tabs general level in this tab make sure your setting are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply
click start control panel hardware and sound manage audio devices playback you should see your speakers right click select enable or you might have to configure them this option will be at the bottom of of the playback list also right click on the speaker select properties you should see a few tabs general levels enhancement and advanced you might find you need to select a different option possibly stereo or dvd or studio quality windows7
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further changes to your sound setting by right clicking on the speaker icon in the taskbar(bottom of screen)
http://download.cnet.com/Realtek-AC-97-Driver-Windows-Vista-Windows-7/3000-2120_4-10962344.html
Realtek AC
Sep 14, 2011 | Intel DG31PR Motherboard
HK 2.1 analog system with Windows 7, worked flawlessly no problems, moved and reconnected system but no audio. Have tested speakers separately, reloaded drivers, have done a system reset, done an entire system scan, all with no problems. The system hardware shows the audio and drivers working and with sound levels and acknowledge when I connect or disconnect. However, headphone jack does allow audio. I am persistent but I am now going on 5 days trouble-shooting and the heroics are gone. (My audio test for the speakers was unique as all my sound equip has different connections types. I used a boom box AM/FM device, having its own amp and the 2.1 HK having its own internal amp. Could there be an internal fuse tripped? It is hard to know where there problem is. Help!
have you configured the speakers?
hope this helps you
Sep 05, 2011 | Harman Kardon Audio Players & Recorders
it won't extract m cd. it just says scanning for devices and nothing happens
For stuck CD do this:
Hit Ctrl,Alt and Delete all at the same time> Windows Task Manager should open> Click on the "Applications Tab"> Click End Task to close all Apps.> Now go to your Cd/Dvd player hit the eject button on the front.> Remove CD.
Now for your device problem try this:
To specify your preferred audio devices for playback or recording in Windows, do the following:
Windows 98, 98se, ME:
1. In Control Panel, double-click Multimedia or Sounds and Multimedia.
2. On the Audio tab, select the devices you want in the Preferred Device boxes.
3. Click the Use Preferred Devices Only check box to select it.
4. Click OK.
Windows 2000 and XP:
1. In Control Panel, double-click Sounds and Audio Devices.
2. On the Audio tab, select the devices you want in the Default Device boxes.
3. Click the Use only default devices check box to select it.
4. Click OK.
Windows Vista:
1. Go to Start > Control Panel
2. In Control Panel, select the option that says Hardware and Sound
3. Under the listing for Sound, select Manage Audio Devices
4. Under Recording and Sounds tabs, you will find all available devices. To set a default device, right click on one of them and select Set as Default Device.
Windows should now be configured to use these devices for both playback and recording.
This should fix your problem, if not use link to go to Sony support. Use the E-Mail option for a faster solution.
http://www.sonycreativesoftware.com/support/
Oct 08, 2010 | Sony Sound Forge 8.0 for PC
Can't hear playback. Windows Vista - Playback device says usb Audio Codec
here is what ION is telling people (short version) this is for vista or win7
1. Visit www.ionaudio.com/ezvc to download the latest EZ Converter software.
2. install new software if needed,
3. connect ION Audio USB. make sure its ON (if it has a switch)
Setup Procedure
1. Start then Control Panel.
2. double-click Hardware and Sound.
3. double-click Sound.
4. At top select Playback tab. choose the audio output device.
Don’t chose “speakers-usb audio codec” (that’s your ION) don’t chose modem
5. click Set Default.
6. select Recording tab at top of Sound Control Panel. choose "Microphone – USB Audio Codec" as the default device. (that’s the ION)
7. Click Set Default.
8. click Properties. select Advanced tab
9. set the Default Format setting to 2-channel, 16 bit 44100 Hz (CD Quality).
10. Un-check the two boxes under Exclusive Mode. Click Apply
11. select Levels tab from the top of the Sound Control Panel.
12. Set the level slider to 4. Click Apply, click OK to close the window.
Have everything set up and running, if you have to call this number for help.
401-658-3743 ext. 1405
Jun 25, 2010 | ION Audio iTTUSB Turntable
sound
inux:
1. System has been set as “Volume mute”. Please press Fn+ F7 to enable speaker.
2. Please click the Diagnostic Tool icon under the Setting Tab==>System Test==>Audio, and test it.
3. Please restore the system for a try.
4. If it is a hardware related problem, please contact the local service center.
XP:
2. Reinstall the audio driver.
3. Using the support DVD or hard disk partition (requires a recovery partition) to restore the system for a try.
Mar 28, 2010 | ASUS Eee PC 1000H Laptop
207 people viewed this tip
David Payne
David Payne
