Tip & How-To about Cameras
Olympus E-10/20
I have been on love with my Olympus e-20n since the day I bought it. Yes, it's only 5 mega-pixel but the SLR design and full manual functions out weigh the limited resolution. I was very disappointed when I tried to buy a replacement high capacity battery and Lithium Polymer 8400ah battery was not only discontinued but totally not available (except for some used ones on Ebay and I'm just not brave enough to buy a used battery)
So crafting a replacement became my Memorial Day Weekend project. One quick trip to Fry's Electronics later and I had the solution. A 6-cell AA battery holder, 6ea AA NiMH 2600ah rechangeables and a 9-volt battery clip with pig tail is all I needed.
Crack open the external battery add-on (looks like a power winder on a 35mm SLR) 4-screws on the botton, one inside the battery well and 2 under the rubber hand grip. Locate the battery connector and un-screw the RED and BLACK prime power leads from each side. Cover the connector with electric tape or an insulated cover, your done with it, forever.
Solder the pigtail 9-volt battery clip to the RED and BLACK leads (red to red and black to black, duh!). Extend the 9v battery clip outside the case and re-assemble the case.
The 6 AA-cell battery holder will fit nicely into the battery door cup and if you pack the vacant space in the battery well with sponge or an old gym sock the battery will not slide around.
Fill the AA battery holder with the rechargeable batteries you have freshly re-charged and hook up the 9v clip. Thats it, new life for the my old companion.
Cameras Logo
Memory card for Olympus FE270
The larger the image, the more space it consumes, your new camera is producing files that are twice as large as the old one did. Buy a larger memory card, they are quite inexpensive these days.
May 15, 2008 | Fuji FinePix A330 Digital Camera
What is the number of recorded pixels on the DiMAGE 7i?
The DiMAGE 7i has four different image size settings; Full 2560x1920, UXGA 1600x1200, XGA 1280x960 and VGA 640-480. The recorded pixel size in each mode is almost equivalent to an image captured with a 5 mega pixel, a 2 mega-pixel, 1.3 mega-pixel, 0.35 mega-pixel DSC respectively.
Sep 15, 2005 | Konica Minolta DiMAGE 7i Digital Camera
Filters
Yes, the Olympus E-20N has a 62mm filter thread size. You can attach a standard 62mm lens filter directly on the lens. Color filters would not have an effect on the camera due to the auto white balance.
Aug 31, 2005 | Olympus Camedia E-20N Digital Camera
Microdrive
The E-20N power supply circuitry is designed differently from the power supply circuitry of the E-10, enabling it to work with the IBM Microdrive.
161 people viewed this tip
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
