Tip & How-To about Car Audio & Video
How to wire subwoofers correctly.
If you're ever unsure about how you need to wire your subwoofers to get the correct ohm load to your amplifier there are a few resources to help. Usually in the owners manual that comes with your subs and your amp they include a detailed ohm load calculator. First step is to determine what subwoofers you have. Common subs come in a dual 2 ohm or a dual 4 ohm version or a single 2 ohm or a single 4 ohm version. Next determine what ohm load your amplifier is rated at. Mono "subwoofer" amps usually are rated x amount of watts at either a 2 or a 1 ohm load. This means you need to purchase the correct subwoofer combination to match your amp. If youre purchasing 2 dual voice coil 4 ohm subs then to maximize an amp you should buy a mono amp stable at 1 ohm. and Dual 2 ohm subs would need a 2 ohm stable amp wired in series parallel. A great resource for a beginner is to go to www.the12volt.com and on the top of the page find the words "subwoofer wiring diagram" and click on it. This will bring you to a drop down menu where you choose the number of drivers "subs" or "speakers" you have and then you choose the impedence in the next drop down menu. Next you'll be provided with multiple wiring options. Good luck and never think you can't do it yourself. Once you learn it's very easy to retain.
Car Audio & Video Logo
How do i install 2 ckicker cvr to my amp
Here are a couple of diagrams 2+4 ohm dual voice coil wiring.
Option 1 (parallel/parallel) = 1 ohm load
Voice coils wired in parallel, speakers wired in parallel
Recommended Amplifier: Stable at 1 ohm mono 2_4ohm_dvc_1ohm.gif
Option 2 (series/parallel) = 4 ohm load
Voice coils wired in series, speakers wired in parallel
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_4ohm_dvc_4ohm.gif
Option 1 (parallel/parallel) = 0.5 ohm load
Recommended Amplifier: Stable at 1/2 ohm mono 2_2ohm_dvc_05ohm.gif
Option 2 (series/parallel) = 2 ohm load
Recommended Amplifier: Stable at 2 or 1 ohm mono 2_2ohm_dvc_2ohm.gif
Option 3 (series) = 8 ohm load
All voice coils wired in series
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_2ohm_dvc_8ohm.gif
Apr 12, 2010 | Kicker CVR12 Car Subwoofer
how do i hook up kicker solo baric in the box
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_2ohm_dvc_8ohm.gif Option 1 (parallel/parallel) = 1 ohm load
Apr 10, 2010 | Kicker Solo-Baric L5 Car Subwoofer
how do i install my L5 solo barics to a 2 channel amp if there is only one connection on the enclosure next to the vent? If I bridge the amp to 1x1000W will the power distribute evenly between both speakers?
Option 1 (parallel) = 2 ohm load
Speakers wired in parallel
Recommended Amplifier: Stable at 2 or 1 ohm mono 2_4ohm_svc_2ohm.gif
Option 2 (series) = 8 ohm load
Speakers wired in series
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_4ohm_svc_8ohm.gif
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono 2_4ohm_dvc_4ohm.gif Option 1 (parallel/parallel) = 0.5 ohm load
Apr 09, 2010 | Kicker Solo-Baric L5 Car Subwoofer
i have a ly1440 amp how can i wire it to my hk15x2
This subwoofer has (2) 2 Ohm voicecoils.
Which means you will only be able to wire a 1 Ohm or 4 Ohm configuration for your amplifier.
The Model # you listed for the amplifier is not a valid one.
If your amplifier is 1 Ohm mono stable...
you wire both (+) Sub to amp (+)
and both (-) on Sub to amp (-)
This is PARALLEL wiring and lets the amplifier SEE a one ohm load
If your amplifier is NOT one ohm mono capable - your only other possibility is a 4 Ohm load.
Wire from (+) on amplifier to one (+) on the sub
Then Wire from (-) on amplifier to the OTHER terminal's (-)
You will have one (+) and one (-) left on the subwoofer - wire them together.
This is SERIES wiring, and nets a 4 ohm load for your amplifier.
There is no other configuration for wiring one Dual 2 ohm sub.
Thanks for using FixYa - a Very Helpful Rating is appreciated for answering your FREE question.
Aug 07, 2009 | MA Audio HK15X2 Car Subwoofer
How to wire 2 ohm 2 12ich alpine type r's to box terminals?
Dual 4 ohm subwoofers can only be wired @ 1 ohm, 4 ohm or 8 ohm.
2 ohm mono load is not possible.
You will need to use (1) subwoofer to get the 1000W out of the amp.
Wire both positives on one sub to + on amplifier and both - on the same sub to - on amplifier to give the amplifier a 2 Ohm load.
Add a second amplifier, or buy an amplifier that is 1 ohm mono stable.
You can wire both to the amplifier at 4 ohms 600W, but they will share the power and only see 300W ea.
Jan 12, 2009 | Alpine Type-R SWR-1242D Car Subwoofer
4,107 people viewed this tip
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
