Tip & How-To about Microsoft Windows XP Professional SP2
How to Encode your VBS and JS files for secure website uploading
If you are still at Service Pack 2 then you can use Microsoft's own Script Encoder download it from HERE it's a command line version so after you have installed it you need to run the command prompt also make sure the Windows Scripting Host is started.
REMEMBER MAKE YOUR SCRIPTS "FOR YOUR EYES ONLY"
For both Visual Basic Scripts and JavaScript you will need to format the text in your script to look like this;
Replace your code goes here with your actual code when the encoder has been run then you will see that the
Microsoft Windows XP Professional SP2 Logo
429 error active x
It looks like the solution is to download this file:http://www.microsoft.com/download/en/details.aspx?id=8247
I found this information on this website:http://www.ehow.com/how_6018818_fix-active-error-429.html
The most recent version of this script is 5.7, not 5.6, but it should fix the problem. Also, make sure you have the most recent updates through Windows Update and Service Pack 3. Install the script first, however.
Mar 29, 2012 | Microsoft Windows XP Professional...
keep getting stack overload. line 0
Your browser is corrupted, reinstall it.
Jul 11, 2010 | Dell Inspiron 1720 PC Notebook
cannot download itunes since a recent firmware upgrade for ipod touch, went to apple forum site and told to delete apple,quicktime, apple mobile device support and now i can`t get itunes to download onto my computer..windows xp home service pack 3..help!! i was also told to go to system 32 and delete quicktime and quicktimevr files
Make sure VBScript is installed, turn off script blocking in anti-virus and personal firewall software, reregister VBScript, and then install iTunes." Resolution Download and install the latest version of iTunes.
Install the latest VBScript engine from Microsoft for your Windows OS platform Windows 2000 Download and install VBScript version 5.6 for Windows 2000 from Microsoft, and then try installing iTunes or QuickTime again. Windows XP Download and install VBScript version 5.7 for Windows XP from Microsoft, and then try installing iTunes or QuickTime again. Windows Vista No download necessary. The latest VBScripting engine (version 5.7) is already included with Vista. Follow the steps below to register the VBSScript again if you still have this issue in Vista.
Register the VBScript engine again If the latest VBScript engine is already installed, register it again. Note that you must be logged in as administrator or logged in as a user with administrator privileges for the computer to execute these steps.
For Windows 2000 or Windows XP: 1. On the Start menu, click Run.
2. In the "Open" field dialog box, enter the following command and click OK:
regsvr32 vbscript.dll
3. A message should appear stating that the "DllRegisterServer in vbscript.dll succeeded."
4. Click OK and try installing iTunes or QuickTime again.
Oct 19, 2009 | Apple iTunes
1,300 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
