Tip & How-To about Sharp AR-5320 Black and White Copier
How to clear code H4 in All sharp copiers.
All the sharp copiers reset by code 14.
type of codes entry:# interrupt C interrupt.led goes off,press 14 and start.
2`nd type:(# * c * ) 14 start ( M 207 model)
3`rd type: C interrupt 0 interrupt (almost for analog copiers)and AR-161 .AR - 5015
Sharp AR-5320 Black and White Copier Logo
Is there a reset code for a Sharp AR-507 copier, error H2-00?
enter simulation: pound, interrupt, clear, interrupt, then enter 14, press start,press execute on touch screen, press ca until copier restarts, this is a general clear code, if problem returns you will have a heat problem in the fuser.
May 04, 2010 | Sharp AR-507 Copier
SHARP AR M-205
Hello sir; this error code require reset the procedure as follow;
1, press "#", "interrupt", "clear", "interrupt".
2, enter 14, press start.
3, turn power off and back on
Feb 07, 2009 | Sharp AR-M205 Copier
code H4 comes up when the sharp copier ar-5316 is switched on. it cannot be use. what shall I do to solve this problem of error code H4.
Hello sir; H4 code require reset procedure as follow;
1, press"#" "interupt" "c" "interupt" these 4 keys.
2, enter 14 , then press start
3, turn power off and back on .
Jan 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
how do u reset the Sharp copier AR-153E? wat buttons do u push?
For error codes:
You enter simulation by pressing #,interrupt,c,interrupt in sequence display goes off, then no. 14 then start key.
Hope that helps...
Lbcoaster
Jul 14, 2008 | Sharp AR-153E Copier
cant enter simulation in sharp ar m207
Is that the right sequence for your model? The Sharp copiers I used to work on used either "CROP" (Clear, Reset, '0', Print) or "CPOP" (Clear, Print, '0', Print). I believe Reset and Interrupt is the same key.
Sep 14, 2007 | Office Equipment & Supplies
3,019 people viewed this tip
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
