Tip & How-To about Cameras
How to fix : Sony Camera - E:91:01 error
The problem is with one of the capacitors, Sony can replace it for you at a cost of $80. This error can come, if we click photos continuosly, the capacitor may get heated up. We need to give a gap of 3 to 4 seconds. Time to be given for the flash to get recharged after a click.
Just give a call at Sony help line. 800.222.SONY, they will replace the capacitor.
If its worth the cost, go for the repair, or you can use the device without flash by disabling the flash. At setup just disable the flash and this error wont show up again.
Cameras Logo
Can't switch from tuner to photo on Sony str gx50es
behind the switches perhaps has bad connections on the front panel pcb
or the switches need taken out and apart and cleaned a tricky job
i do all the time in studios
so you need to take this unit as it quite old and a decent sony to a dealer or the local tv repair man
and have him solder it up and clean it etc
and replace any capacitors it needs changed out.. also
cost i think about £50 to restore fully
or diy = £0
Apr 13, 2015 | Sony Audio Players & Recorders
Have a sony dsc-w50 display flashers E:91:01 all the time what does it mean Have not used camera for a while. Flash seems to not work
May 30, 2010 | Sony Cyber-Shot DSC-F717 Digital Camera
E:91:01
Apr 16, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
Program switch of Indesit-WD105T starts rotating
I had the same problem. I followed the signal lamp code and replaced NTC dryer sensor. The same error code came again. After that I reprogrammed EEPROM with original program and start getting different error codes. Finally I replaces all of electrolytic capacitors and it just start working with no problem. So, if you are planing to repair indesit than start with capacitors.
Tip: use capacitors with higher voltage than original, because voltage on PCB is around 16v
Oct 19, 2009 | Indesit Washing Machines
191 people viewed this tip
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
