Tip & How-To about Refrigerators
Freezer is cool, but the refrigerator side is warm !
The fridge gets it cold air from the freezer. There is like an air tunnel that goes from the freezer (usually in the back) to your fridge to provide cold air.
What probably happened it the tunnel is blocked with ice or another liquid. The easiest thing to do is unplug the fridge for 24 hour so the ice can melt.
If that doesn't help, we will have to manually clear the debris in the tunnel.
Refrigerators Logo
not getting cold, freezer freezes food but refrigerator cool..
May 30, 2010 | KitchenAid (KSRD22FKST) Side by Side...
I purchased a bottom freezer Amana refrigerator when we built our house in 1999. The produce in the vegetable drawer keeps freezing! Everything else in the fridge is fine. Why does this happen?
Usually on bottom freezer fridges, there are two vents at the bottom of the freezer compartment where the cold air goes back into the freezer (cold air enters the fridge through the vent at the top/back of the fridge.)
If the vents at the back of the fridge are covered, the cold air will settle to the bottom of the fridge after it enters, and freeze your vegetables. The problem could be caused by ice build up in the evaporator coil of the freezer section also, but this will probably warrant a checkup from a pro.
One thing that can cause ice to build up inside those vents is moist air seeping in through a faulty door gasket. A thin coat of ordinary Vaseline on the gasket surface can help it make a better seal.
Dec 04, 2009 | Dishwashers
Fridge part not working on Whirlpool Arc 7050 Fridge Freezer
If this is correct:
1. No ice build up on back of freezer wall.
2. Fan in freezer is working.
3. Items in freezer are frozen, ice cream is a good test.
Then:
Why is the cold air in the freezer not getting over to the Ref. side?
1. There is a channel (tunnel) from the freezer to the Ref, side and there is a door which regulates how much cold air from the freezer goes through to the Ref. side.
2. The control panel may have it labeled as "Freezer" setting, from cold to coldest. The coldest setting means the door is almost closed and will keep most of the cold air in the freezer.
3. Since your control panel is not working then this door must be almost closed keeping all or most of the cold air in the freezer.
Any service tech should be able to check the control panel and find the problem.
Jan 25, 2009 | Refrigerators
Jenn Air JCD2389 fridge not cold on fridge side
You have plugged the defrost drain line.This is where the water goes to in the bottom of your freezer when it goes through the defrost (removal of ice from the freezer coil) cycle. It sounds like that hole is plugged and now the water/ice has now frozen in the vent that lets air circulate down into your refrigerator compartment. What I usually do in this case is to unplug the refrigerator, empty out the freezer compartment. Usually I also end up either pulling off the back panel or the bottom panel (in the freezer compartment) Looking for that defrost drain hole and thawing it out with a heat gun (be careful of melting plastic) or actually I use a hair dryer. I can sometimes do this also by pouring small amounts of HOT tap water onto it and then sopping/absorbing it away with a sponge or dishcloth. I repeat this until I get the water to go down the drain tube.
Try it and let me know!
Sep 26, 2008 | Jenn-Air JCD2290HES Side by Side...
Fridge problem
I don't know about the hot points for sure, but all the maytags (I used to work for maytag) have a damper valve in the air tunnel that feeds cold air to the refrigerator. If the damper went bad, it would block cold air flow into the refrigerator. (assuming this model has a damper)
Feb 16, 2008 | Hotpoint  21.8 Cu. Ft. Top-Freezer...
247 people viewed this tip
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
