Tip & How-To about Computers & Internet
How to remove bios password?
Remove c-mos battery from motherbord at least 1 min.
Computers & Internet Logo
wont let me do anything looking for f1 to set time and date
first remove the power and check the c mos battery for 3v if the battery have no voltage cange the battery also look for the jumber pins in your motherboard near the c mos battery and bios you will see two pins shorted with an juber move the jumber to the third pin normally the jumber setting are 1 and normal 2and 3 clear c mos
Oct 30, 2011 | Toshiba Computers & Internet
how to install a c-mos battery in a dell latitude c-840 Laptop
this means you will be opening the laptop cover from under, then remove the old c-mos battery, then replace with another.
The laptop must be off, battery removed, unscrew the under laptop cover, to access the c-mos battery, and that's all.
Good luck.
Apr 23, 2010 | Dell Latitude C840 Notebook
How do i remove power on pass word? IBM T23 thinkpad
try removing the C-MOS battery, you will need to take the laptop apart, the battery (s) are located at the front right and should be in a plastic either blue or yellow sleeve, they will look like watch batteries or if you have ever owned a laser pointer they will look like those, small round about 1/4' diameter and there should be 3 of them, disconnect the wire for about 30 min then reconnect and that should fix the issue
Jan 20, 2010 | IBM ThinkPad T23 2647 Notebook
How can remove BIOS password
YOu can reset bios password with 2 method.
(1) open back cover of laptop then find motherbord .Pull cmos cell from motherbord for 15 minutes then again put it in it's position .then it not ask for password.
(2)You can clear password with jumper settings find jumper on motherbord named clear cmos it has 3 pin .1-2-3
Put jumper in 2-3 position then again put it in 1-2 position then check .
Let me know if you need more assistance.
Thanks.
Nov 19, 2009 | Toshiba Satellite M45-S165 Notebook
Power-On Password on Compaq Presario C300
Thanks.
Nov 09, 2009 | Compaq Presario Notebook
98 people viewed this tip
David Payne
David Payne
