Tip & How-To about Cell Phones
I cant hear my ringtone on my blackberry curve
Okay I had the same problem, if you have a Blackberry 8100, go to media, video files, and play a video...if you have no sound tap the top button once quickly (it's the silver buttonon top which has a speaker icon on it with a line go through it,if you still hear no sound use the volume keys on the sound
and you should hear the video playing, which in turn will turn on all you volumes for you phone to ring
etc.
Cell Phones Logo
How to delete a downloaded video
It really depends on what kind of cellular phone you are having a problem with, but I'll try to help you as much as possible by giving you the step-by-step process to deleting a downloaded video on a Blackberry Tour:
First, you'll need to know the name of the downloaded video file. When downloading a video onto your phone, there will usually be a screen where you can name the file yourself; or it will be automatically saved as another name which describes the video. Once you have the name of the video, it's easy to delete it.
Once you have the name of the video, you want to open the dashboard on your Blackberry by pushing the Blackberry button which looks like this: jfpat.png
The dashboard should pop up, and you'll want to find your "Media" Application. Scroll around your dashboard with your track pad or track ball (to the right of the Blackberry button) until you find the Media folder which looks like a file folder with a "play" symbol in the middle of it (like the play button on a TV remote control or DVD player). Once you've highlighted the Media folder, click on it.
Now you are in the Media folder, and there should be a bunch of icons that look like music symbols, telephones, pictures, microphones, video cameras, etc. What you are looking for, however, is the icon that looks like the film on a movie reel or an undeveloped piece of film from a (now old-fashioned, haha) disposable camera. Select this icon.
Now a list of the names of the videos on your phone will open up. Search for the name of the video you want to delete by scrolling up and down with your track ball or track pad. Once you've highlighted the video that you want to delete, push the Blackberry button again, and a little menu will open up on the side. Scroll down to highlight the word "Delete", click on that, and the video is deleted off of your Blackberry smartphone.
Hope I helped. Thanks. -jfp
Jul 13, 2011 | RIM BlackBerry? Tour 9630 Smartphone
cannot play Blackberry 9000 mp3 files on Bluetooth devise
Complete the following steps:
1) Use a search engine or a dedicated download site to find and download a third-party conversion tool. The tool must have the ability to convert the format of the audio or video file to a file format that the Media application can read.
2) Install the third-party conversion tool and follow the program instructions to convert the audio or video file to a format that the Media application supports. Refer to the following tables for optimal settings in the Media application.
Optimal settings for the Media application on the BlackBerry 9000 series smartphones:-
For video setting's
a) Video format: MPEG-4.
b) Video file extension: .avi
c) Resolution (4:3): 240x180
d) Resolution (16:9): 320x180
e) Video bitrate: 400 Kbps
f) Frames per second: 24
For Audio settings:-
a) Audio format: MP3
b) Audio bitrate: 128 Kbps
c) Sample rate: 44 kHz
d) Channels: 2 (Stereo)
Transfer the audio or video file from the computer to the BlackBerry smartphone using one of the following methods:-
1) Using BlackBerry Desktop Manager.
Note: BlackBerry Desktop Manager 4.2 must be installed on the computer.
  1. In BlackBerry Desktop Manager, open BlackBerry Media Manager.
  2. Use the Media Manager tool to transfer the audio or video file to the BlackBerry smartphone using a USB connection.
  3. Copy the files to the appropriate folder (either \blackberry\Music or \blackberry\Video) on the media card, or directly to the internal BlackBerry smartphone memory.
Note: Files larger than 3 MB cannot be transferred to internal BlackBerry smartphone memory.
2) Using the BlackBerry smartphone as a USB mass storage device:-
  1. On the BlackBerry smartphone, go to Options > Advanced Options > Media Card.
  2. Make sure that Mass Storage Mode Support is set to Enabled.
  3. Connect the BlackBerry smartphone to the computer and follow the prompts on the BlackBerry smartphone.
  4. Open the My Computer folder on the computer. The media card should appear there as a Removable Disk.
  5. Copy the files to the appropriate folder (either \blackberry\Music or \blackberry\Video) on the media card.
Using a media card reader
  1. Make sure that the media card reader is connected to the computer.
  2. Insert a media card into the media card reader.
  3. Open the My Computer folder on the computer. The media card should appear there as a Removable Disk.
  4. Copy the files to the appropriate folder (either \blackberry\Music or \blackberry\Video) on the media card.
  5. Insert the media card into the BlackBerry smartphone.
Oct 24, 2009 | RIM BlackBerry Bold 9000 Smartphone
how do i transfer stuff from blackberry curve into the memory card
Open your media manager. Push menu button and select "explore".
Navigate through your device memory until you find the file you want to transfer. Highlight the file, push the menu button and select "move".
Navigate back up the file tree by selecting "up" until you see the memory card folder. Select the memory card folder, and choose the option to "put file here".
Keep in mind, you can not load programs from your memory card. You can only put files there (music, documents, ebooks, etc).
-Neil
Jun 25, 2009 | RIM BlackBerry Pearl 8100
Blackberry pearl 8100 won't turn on.
My Blackberry also wouldn't turn on, till a sharp tap at the top left of the screen made the screen flicker into life and I realised it was on, just no screen. After intermittent screen failing, repeated tapping seems to have fixed the problem. I'll upgrade to a new Blackberry when my contract allows.
Richard
Jan 24, 2009 | RIM BlackBerry Pearl 8100
blackberry pearl 8100 doesn't ring
Blackberries are famous for requiring the "take battery out and put back in" proceedure to reset things. Give it a try if you have not yet.
Hope that helps.. :)
Feb 07, 2008 | RIM BlackBerry Pearl 8100
130 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
