Tip & How-To about Office Equipment & Supplies
Brother MFC Laser Printer Fax Machine just says printing "printing" reset procedure
I have seen this so many times I thought I would post a tip on the problem so you can repair your Brother MFC series machine that says printing and will not function. Using this procedure will save you from having to call out a service technician. Any time your machine says "printing" and will not do anything simply turn off the power. Now hold down the red clear/stop button WHILE turning the power back on. Continue holding the clear key for a few seconds then release. Your "printing" message should be gone and your machine should be back at the ready screen.
Good Luck and Thank You for using Fixya!
The LCD screen keep displaying "Printing" but
I have seen this so many times I thought I would post an answer on this so you can repair your Brother MFC series machine that says printing and will not function. Using this procedure will save you from having to call out a service technician. Any time your machine says "printing" and will not do anything simply turn off the power. Now hold down the red clear/stop button WHILE turning the power back on. Continue holding the clear key for a few seconds then release. Your "printing" message should be gone and your machine should be back at the ready screen.
WheatlandServices
Dec 16, 2010 | Brother MFC-8220 Fax
Brother MFC-665 CW with "unable to print 4F" error
My MFC 665CW popped this same "Unable To Print 4F" error recently making the machine fully useless. Just an annoying triple beep and repeat error message to screen when trying to do anything at all with it. I wrote Brother about it. They said to check all through the machine (with a light) for any paper torn off inside, or unwanted foreign objects. This is a good step to do anyway to help maintain the printer. If that is not it, they said it would be a mechanical malfunction. I tried "resetting" by unplugging it for a while as they suggested to no avail. Also while I did find a bit of paper torn off down in my MFC 665 removing it had no effect.
Jul 10, 2009 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-235C print head removal
there are no instructions that you would understand and once the print head is clogged up, you can noy mannually clean it , it has to be replaced! sounds like you are using generic ink!
Nov 05, 2008 | Brother MFC 240C All-In-One InkJet Printer
Print function stopped working. Brother MFC 5840CN
First things first:
press menu then start bk-copy then fourtimes arrow-up button. machine will display an error code no. plz post AS A NEW POST again.
BTW: The update has nothing to do with the stopping of the machine!
Jan 10, 2008 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC-8500 prints solid gray pages
I have seen the Toner cartridge in these cause this and also thought it was drum but new toner actually fixes it, have you installed new gen toner as well as drum? Make sure you tell machine you have fitted new drum too,
Sep 08, 2007 | Brother MFC 8500 All-In-One Laser Printer
299 people viewed this tip
jasbo
jasbo
