Tip & How-To about Computers & Internet
How to enable hibernation in Windows XP
Hibernation is a low-power mode that laptops use when they are idle in order to save power. A hibernating computer can come back up to ready a lot quicker than a computer that is completely shut down, but it only uses marginally more power while it is hibernating.
To enable hibernation, open the Power Options applet in the Control Panel. Click on the Hibernate tab (the farthest one on the right) and check the box next to "Enable hibernation." Beneath this box you will see the amount of disk space required to use hibernation. (This amount is typically about the same as the amount of RAM you have installed, because when the computer hibernates, everything in RAM is written to the hard drive.) If you do not have enough free hard drive space, you won't be able to use hibernation; delete some old programs or files that you no longer need in order to free up some more room.
Once you have enabled hibernation and clicked Apply, you can tell Windows when to use hibernation. Go to the Advanced tab (still in Power Options). Under the "Power buttons" heading, there are settings for different actions, such as closing your laptop's lid or pressing the power button. If you want your computer to hibernate when any of these actions are performed, just choose Hibernate from the drop down list. You can also make your computer hibernate manually by choosing Hibernate from the shut down options (Start menu > Shut Down).
Your changes will take effect as soon as you click Apply or OK.
Computers & Internet Logo
My HP compact nc6000 laptop went to Hiberating mode and i don't know how to fix the problem. If i could please get help that would be great. i just got this laptop yesterday. it was working but all of the sudden it went to the hiberating mode while i was just fixing the icons in the start menu i was reorganizing it. Thanks, Jessica
Hi Jessica,
Hibernation mode usually turns the computer off but saves any work. Then you would start it back up by hitting the power button, it will boot up and you log in like normal and the computer should be as it was before it went into hibernation.
If you can't get it out of hibernation by pressing the power button, try holding the power button for 5-10 seconds. The laptop may actually still be on, and holding the power button will cut if off. Once the computer is back on you can change the battery options(hibernation/turn off settings) in Windows by going to the bottom right task bar and right clicking on the battery icon. Normally you will have an option like "power saving settings", "battery settings". In this setting window you can turn off hibernation due to inactivity.
Let me know if you have any questions.
Regards,
G33k
Jul 09, 2011 | HP Compaq nc6000 Notebook
I am unable to unhibernate
Power down the computer and power back up. Lets just shut hibernation off...you can always just have the computer sleep...it is much better on the system anyway.
Shutting Down Hibernation
Go to the control panel > Power Options > Hibernation tab > uncheck hibernate…this way you save a lot of disc space and don’t have to go through all the intermittent hibernation problems that occur. After you uncheck hibernation, you can go to the other power options and change how the computer reacts to the lid being closed, when it sleeps and for how long before sleep kicks in. Make sure to change the setting for what happens when lid closes to “do nothing” this will keep the laptop alive even though you close the lid to move it, etc.
Sep 27, 2009 | Compaq Presario 1275 Notebook
question
Hibernation is a power management feature. When you hibernate a laptop, you're essentially turning it off. So, unlike Stand By (Sleep) mode, a hibernated laptop isn't using any battery power at all - that laptop is off!
The secret behind hibernation is that before you turn off the laptop, everything you're doing with the computer is saved. (The contents of memory are saved to the hard disk.) When the computer is turned on again, it recovers from hibernating by reloading all the saved information and restoring your laptop to exactly the same condition it was in before it was hibernated.
Briefly, hibernation works like this:
1. You activate the hibernation feature.
Hibernation is activated differently depending on how it's set up.
2. The laptop hums as everything in memory is saved to disk.
3. The laptop turns itself off.
It's really and truly off: The battery isn't being used, and it's safe to store the laptop or put it away until you need to use it again.
To recover from Hibernation mode, just turn the laptop on. In some cases, the laptop may recover from hibernation when you press a key or touch the mouse pad. hibernated state for as long as you want.
Hibernation mode requires hard drive space. So you should be aware that when hard drive space runs low, it's possible that Hibernation mode won't work.
In Windows XP, you have to activate Hibernation mode before you can use it. Follow these steps to activate Hibernation:
1. Click the Start button.
2. From the Start menu, choose Control Panel.
3. Open the Power Options icon in the Control Panel.
4. In the Power Options Properties dialog box, look for and click on the Hibernation tab.
If you don't see a Hibernation tab, there's your answer: The laptop isn't capable of hibernating. Oh, well.
You might want to check the laptop's Setup program to see whether you can activate Hibernation there.
5. Select the Enable Hibernation option by clicking the check box to place a check mark in the box.
6. Review other options, if they're available.
7. Click OK to confirm the changes and close the Power Options Properties dialog box.
Optionally, close the Control Panel window, as well.
Some laptops may require you to restart Windows for this change to take effect.
Sep 09, 2009 | Computers & Internet
Pavilion Dv1000 monitor won't show anything
Power management lets you reduce your Notebook power consumption. Your Notebook has two power management modes:
  • Hibernation is an energy-saving feature and safeguard that saves information to the hard drive, then turns off your Notebook. When you resume from Hibernation, your information returns to the screen where you were previously working. Your Notebook hibernates when the Power button is pressed, when the battery has little power left, or when your Notebook (operating on battery power) is in Sleep mode for more than one hour.
  • Sleep, also called Standby, is an energy-saving feature that reduces power to system components that are not being used. When Sleep is initiated, your information is saved in Random Access Memory (RAM), and the screen is cleared. Your Notebook is still on, but the display is blank. When you resume from Suspend, your information returns to the screen where you were previously working.
Automatically put your notebook into hibernation Windows can automatically put your computer into Hibernate mode after a specified period of inactivity. Or Windows can detect when your batteries are running low, and then automatically put your computer in Hibernate mode to save your work before the battery fails. NOTE: Using Power Options in Control Panel, you can adjust any power management option that your notebook's unique hardware configuration supports. Because these options may vary widely from computer to computer, the options described may differ from what you see. Power Options automatically detects what is available on your computer and shows you only the options that you can control. To automatically put your computer into hibernation:
  1. In Category view, click Start , click Control Panel , click Performance and Maintenance , and then click Power Options . In Classic view, click Start , click Control Panel , and then click the Power Options icon.
  2. Click the Hibernate tab, select the Enable hibernate support check box, and then click Apply . Figure 1: Enable hibernation check box c00035872.gif
  3. Click the Power Schemes tab, and then select a time period in System hibernates. Your computer hibernates after it has been idle for the specified amount of time.
Manually put your notebook into hibernation This feature is available only on notebooks with the Windows XP operating system installed.
  2. Click the Hibernate tab, and then select the Enable hibernate support check box. NOTE: If the Hibernate tab is not available, your computer does not support this feature.
  3. Click OK to close the Power Options dialog box.
  4. Click Start , and then click Turn Off Computer . In the Turn off computer dialog box, hold down the Shift key. The Stand By button will change to Hibernate. Click Hibernate .
Jan 06, 2009 | HP Pavilion dv1000 Notebook
my acer computer will turn on but wont come out of hibination mode
Some laptops have issues with Windows XPs hibernation mode. To get the computer back up again you should just hold the power button down until it shuts off completely. Some laptops won’t shut off even if you do this. When this happens you have to take the battery out to get it to turn off. Make sure it is not plugged into the wall when you do this otherwise it wont work.
Once you get the computer back running again you may want to disable hibernation if it seems like its going to keep happening. Go to Start, Settings Control Panel or Start, Control Panel and go to the Power Options icon. Change the hibernation section to never. You may want to try standby as an alternative. Standby saves all your running applications and documents into RAM while hibernate saves them to the hard drive. Hibernate uses less power from your battery, but it will take you considerably longer to get the computer back up. If you always plug the computer in then you may want to disable standby and hibernate since you really dint need them while plugged in.
Let me know if this works.
Aug 16, 2008 | Acer Computers & Internet
160 people viewed this tip
David Payne
David Payne
