Tip & How-To about Computers & Internet
How to configure automatic updates in Windows
Microsoft routinely puts out updates for current versions of Windows (and Windows applications). Some of these are critical updates, such as security patches, while others just tweak a program or fix a bug. Your operating system will run better if you stay up to date on the important updates, and an easy way to do this is by using Windows automatic updates.
To turn on automatic updates, right click on My Computer (in Windows Vista or 7, right click Computer) and select Properties. Then go to the Automatic Updates tab. Here you will see the different update options.
The safest choice is to pick Automatic, which will check for updates on a schedule that you choose (daily or weekly, at a certain time) and download any new updates it finds. However, if you want some control over which updates are installed, you can choose either of the next two options:
- Download updates for me, but let me choose when to install them
or
- Notify me but don't automatically download or install them.
If you pick either of these two choices, a yellow shield icon with an exclamation point will appear in the system notification tray when new updates are available, and you can download or install them by clicking on it.
The last option is to turn off automatic updates completely. Choosing this option may leave your computer at risk, because you won't get any security fixes Microsoft comes out with. If you do choose to turn automatic updates off, you should check for updates manually once in a while by visiting Microsoft's Windows Update web page at WindowsUpdate.Microsoft.com.
Whichever option you choose, click Apply at the bottom of the window to save your preference.
Computers & Internet Logo
how to update windows xp
Go to Microsoft Update and follow the appropriate instructions.
Jun 11, 2011 | LG Computers & Internet
what is acrobat reader?
Adobe Acrobat is a family of computer programs developed by Adobe Systems, designed to view, create, manipulate and manage files in Adobe's
Plug-in from Adobe. It reads documents in PDF format on any platform.
A program from Adobe that lets you capture a document and then view it in its original format and appearance
Adobe has changed the names of the products in the Acrobat family regularly, also splitting-up, joining, or discontinuing products. Between version 3 and 5, Standard and Professional versions were one product simply called Adobe Acrobat.
As of October 2009[update], the current main members of the Adobe Acrobat family are:
64px-adobe_reader.svg.png magnify-clip.pngAdobe Reader 8/9 Icon
  • Adobe Reader 9 (Windows, Mac and Unix)
  • Adobe Acrobat 9 (Windows & Mac only; no Unix version)
    • Adobe Acrobat 9 Standard
    • Adobe Acrobat 9 Pro
    • Adobe Acrobat 9 Pro Extended (includes Adobe Presenter)
The latest version
Version 9.0 Adobe Acrobat 9.0 was released July 2008:[10][11]
  • PDF version 1.7 (and prior) supported. There are Adobe extensions to PDF 1.7 for Acrobat 9.
  • Product Family includes: Acrobat Standard 9 (Windows only), Acrobat Pro 9, Acrobat Pro Extended 9 (Windows only).
  • Pro Extended Version includes Adobe Presenter and the features of Acrobat 3D.
  • The ability to create Acroforms was restored to Acrobat Standard in this release (in versions 6 through 8, Acrobat Professional was required).
  • Enable real-time collaboration of PDFs with synchronized document views and chat.
  • Improved Web Capture for capturing entire web pages or just some parts into PDF.
  • Integration with acrobat.com to enable storage and sharing of PDF files.
  • Personalize a PDF Portfolio with customizable templates for navigation and branding.
  • Compare and highlight the differences between two versions of a PDF document.
  • Insert FLV (Flash) or H.264 video for direct playback in Adobe Acrobat and Adobe Reader.
  • Convert a variety of video formats to FLV for playback in PDF.
  • Create PDF maps by importing geospatial files that retain metadata and coordinates.
  • OCR PDFs (Paper Capture) using ClearScan. Adobe ClearScan technology creates custom Type1-CID fonts to match the visual appearance of a scanned document after optical character recognition (OCR). ClearScan does not replace the fonts with your system fonts or substitute them by Type1-MM (as in Acrobat 8 and earlier versions), but uses these newly created custom fonts. The custom fonts are embedded in the PDF file (this is obviously mandatory). If the OCR does not recognize a word with enough confidence, then the image (bitmap) of the word is shown in the PDF and the text is put above but hidden (same as what is made in "Searchable Image" mode).
  • Adobe Reader 9 drops support for Adobe Reader Extensions 5 and 6 which permit Adobe Reader client software to save changes to filled-in forms in PDFs. Adobe Reader Extensions 6.1 and newer are still supported. Legacy PDFs will still be viewable, however they will open with the warning "This document enables Reader capabilities that are no longer enabled in this Reader version."[12]
  • On March 10, 2009, Adobe Reader 9.1 was released which addresses a number of customer workflow issues and a critical security vulnerability while providing more stability.[13]
  • On May 12, 2009, Adobe Reader 9.1.1 was released which addresses two critical security vulnerabilities.[14]
  • On June 9, 2009, update version 9.1.2 was released which addresses a number of critical security vulnerabilities.[15]
  • On July 31, 2009, update version 9.1.3 was released which addresses a number of critical security vulnerabilities.[16]
  • On October 14, 2009, Adobe Acrobat 9.2 was released (added support for Windows 7 x86/x64 and fixed many security issues).[17]
  • On January 12, 2010, Adobe Reader 9.3 was released which addresses a number of critical security vulnerabilities.[18]
  • On February 16, 2010, Adobe Acrobat 9.3.1 was released which addresses two critical security vulnerabilities.[19]
  • On April 13, 2010, Adobe Acrobat 9.3.2 was released which addresses several critical security vulnerabilities.[20]
Jun 03, 2010 | Adobe Computers & Internet
what is the different between xp serrvice pack 1 and 2
A service pack is a collection of all updates released to that point, and often includes new features, as well.
The major enhancements in Windows XP Service Pack 2 include Security Center, Automatic Updates, Windows Firewall, and Internet Explorer.
Security Center is an entirely new feature provided by Windows XP Service Pack 2. The Security Center service runs as a background process in Windows XP and routinely checks the status of the following components:
1. Windows Firewall: Security Center detects whether Windows Firewall is enabled or disabled. Security Center can also detect the presence of some third-party software firewall products.
2. Automatic Updates: Security Center detects the current Automatic Updates setting in Windows XP. If Automatic Updates is turned off or not set to the recommended settings, the Security Center provides appropriate recommendations.
3. Virus Protection: Security Center detects the presence of antivirus software from many third-party organizations. If the information is available, the Security Center service also determines whether the software is up-to-date and whether real-time scanning is turned on.
When Security Center detects an important security condition (such as improper settings), it displays a pop-up notice in the notification area.
Windows XP Service Pack 2 provides several enhancements to the Automatic Updates feature, including the following:
■ The latest version of Automatic Updates offers expanded support for Microsoft products, including Microsoft Office.
■ Previous versions of Automatic Updates could download only critical updates. Now Automatic Updates can download updates in the following categories: security updates, critical updates, update roll-ups, and service packs.
■ Automatic Updates now prioritizes the download of available updates based on the importance and size of the updates. For example, if a large service pack is being downloaded, and a smaller security update is released to address an exploit, that security update will be downloaded more quickly than the service pack.
■ Automatic Updates is now more automated. The need for users to accept End-User License Agreements (EULAs) has been eliminated. Also, the user now has a choice of whether to restart the computer following the installation of updates that might require a restart. Updates that do require a restart can now be consolidated into a single installation so that only one restart is required.
Previous versions of Windows XP include a software-based firewall named Internet Connection Firewall (ICF). After installing Windows XP Service Pack 2, this firewall is replaced by Windows Firewall.
Windows Firewall boasts a number of enhancements, including the following:
1. Windows Firewall is now enabled by default on all network
connections.
2. Windows Firewall provides an interface for configuring global settings that apply to all the connections of the computer.
3. In Windows XP Service Pack 2, Windows Firewall supports a new feature that allows you to keep Windows Firewall enabled and also not allow any exceptions; only solicited traffic is allowed. This new feature is intended to create an even more secure environment when connecting to the Internet in a public location or other unsecured location.
4. In Windows XP Service Pack 2, a startup Windows Firewall policy performs stateful packet filtering during startup, so that the computer can perform basic network tasks (such as contacting
DHCP and DNS servers) and still be protected.
5. In previous versions, you could not apply firewall rules based on Internet Protocol (IP) addresses. In Windows XP Service Pack 2, you can configure Windows Firewall so that firewall rules apply to IP addresses (or IP address ranges), meaning that only traffic from computers with valid IP addresses is allowed through the firewall.
6. In previous versions, you configure permitted traffic by specifying the TCP and UDP ports used by a service or application. In Windows XP Service Pack 2, you can also configure permitted traffic by specifying the file name of the application. When the application runs, Windows firewall monitors the ports on which the application listens and automatically adds them to the list of allowed incoming traffic.
Internet Explorer:
Windows XP Service Pack 2 introduces a number of new security features to Internet Explorer 6. As with the rest of the enhancements introduced with Windows XP Service Pack 2, most of the updates to Internet Explorer are intended to provide better security.
Jul 16, 2009 | Microsoft Windows XP Professional With...
Some application software are not working.
You will need to install WinXP service pack 3 and some critical updates plus microsoft dot net distribution packages like" Microsoft.net 1,2 & 3". After installing them you will be able to install the various softwares you mentioned..........sodeep
Apr 25, 2009 | Microsoft Windows XP Professional
138 people viewed this tip
David Payne
David Payne
