Tip & How-To about Garden
The number one problem 90+% of the time is a plugged main jet from old gas or water in the tank or carb. a complete clean out is simple and can be carried out in 15 minutes. if the seals are worn then a rebuild might be necessary. one simple step you can try first to make sure the needle isnt stuck in the seat on the carb is is open the drain plug on the bottom of the float chamber.you should get a clean flow of normal fresh gas. always place a rag to catch any gas and dont strart the mower until all the gas has evaporated. not all of the newer mowers have a drain plug in the bottom of the float bowl so you can just loosen the bolt that holds the float bowl in place that in in the middle under the float bowl and check for a good flow fuel. this is a good time to change the spark plug with the correct gap and the air filter as well. always sharpen your blades or have them sharpened once a year as well.
