Tip & How-To about Linksys Wireless-G Broadband Router
How to secure your wireless router
Most WLAN hardware has gotten easy enough to set up that many users simply plug it in and start using the network without giving much thought to security. Nevertheless, taking a few extra minutes to configure the security features of your linksys router wireless or access point is time well spent. Here are some of the things you can do to protect your wireless network:
1) Secure your linksys router wireless or access point administration interface linksys router wireless have an administrator password that's needed to log into the device and modify any configuration settings. Most devices use a weak default password like "password" or the manufacturer's name, and some don't have a default password at all. As soon as you set up a new WLAN router or access point, your first step should be to change the default password to something else. You may not use this password very often, so be sure to write it down in a safe place so you can refer to it if needed. Without it, the only way to access the linksys router wireless or access point may be to reset it to factory default settings which will wipe away any configuration changes you've made.
2) Don't broadcast your SSIDlinksys router wireless automatically (and continually) broadcast the network's name, or SSID (Service Set IDentifier). This makes setting up wireless clients extremely convenient since you can locate a WLAN without having to know what it's called, but it will also make your WLAN visible to any wireless systems within range of it. Turning off SSID broadcast for your network makes it invisible to your neighbors and passers-by (though it will still be detectible by WLAN "sniffers").
3)Enable WPA encryption instead of WEP802.11's WEP (Wired Equivalency Privacy) encryption has well-known weaknesses that make it relatively easy for a determined user with the right equipment to crack the encryption and access the wireless network. A better way to protect your WLAN is with WPA (Wi-Fi Protected Access). WPA provides much better protection and is also easier to use, since your password characters aren't limited to 0-9 and A-F as they are with WEP. WPA support is built into Windows XP (with the latest Service Pack) and virtually all modern wireless hardware and operating systems. A more recent version, WPA2, is found in newer hardware and provides even stronger encryption, but you'll probably need to download an XP patch in order to use it.
4) Remember that WEP is better than nothing If you find that some of your wireless devices only support WEP encryption (this is often the case with non-PC devices like media players, PDAs, and DVRs), avoid the temptation to skip encryption entirely because in spite of it's flaws, using WEP is still far superior to having no encryption at all. If you do use WEP, don't use an encryption key that's easy to guess like a string of the same or consecutive numbers. Also, although it can be a pain, WEP users should change encryption keys often-- preferably every week. See this page if you need help getting WEP to work.
5) Use MAC filtering for access control Unlike IP addresses, MAC addresses are unique to specific network adapters, so by turning on MAC filtering you can limit network access to only your systems (or those you know about). In order to use MAC filtering you need to find (and enter into the linksys router wireless or AP) the 12-character MAC address of every system that will connect to the network, so it can be inconvenient to set up, especially if you have a lot of wireless clients or if your clients change a lot. MAC addresses can be "spoofed" (imitated) by a knowledgable person, so while it's not a guarantee of security, it does add another hurdle for potential intruders to jump.
6) Reduce your WLAN transmitter powerYou won't find this feature on all wireless linksys router wireless and access points, but some allow you lower the power of your WLAN transmitter and thus reduce the range of the signal. Although it's usually impossible to fine-tune a signal so precisely that it won't leak outside your home or business, with some trial-and-error you can often limit how far outside your premises the signal reaches, minimizing the opportunity for outsiders to access your WLAN.
7) Disable remote administrationlinksys router wireless have the ability to be remotely administered via the Internet. Ideally, you should use this feature only if it lets you define a specific IP address or limited range of addresses that will be able to access the linksys router wireless. Otherwise, almost anyone anywhere could potentially find and access your router. As a rule, unless you absolutely need this capability, it's best to keep remote administration turned off. (It's usually turned off by default, but it's always a good idea to check.)
source: http://www.linksysrouterwireless.com/article/Securing-your-wireless-network.php
Linksys Wireless-G Broadband Router Logo
intellinet wireless adapter malfunction
Wireless Zero Configuration (WZC) was introduced with Windows XP, it is also known as WLAN AutoConfig in Windows 7 and Vista. It is is a wireless connection management utility which dynamically selects a wireless network to connect to based on a user's preferences and various default settings. or most users the Windows Wireless Zero Utility is all that is needed to manage your wireless connections.
You can configure WZC as follows:
  1. Type services.msc in "run" and enter.
  2. Select wireless zero configuration from the list which appears in the next window.
  3. Double click on that option , and choose to Start or Stop the Wireless Zero service.
Here are steps to use Wireless Zero Configuration/WLAN AutoConfig in Windows 7:
  1. Click the Windows logo button
  2. Type services in the Start Menu's Search box and press Enter. Scroll to the bottom of the list and locate WLAN AutoConfig'. Double-click WLAN AutoConfig to open its Properties window.
  3. Click the General tab of WLAN AutoConfig service. Click the Startup type drop-down menu and click Automatic to have the service started automatically when the operating system loads. Click the Start button. Click Apply and then OK. Close the Services console window.
  4. Click the Windows logo button. Type cmd in the Search box and press Enter. In the Command Prompt window, type netsh wlan show settings and press Enter. Look at the last line of the Wireless LAN Settings entry to see if the message Auto configuration logic is enabled on interface or Auto configuration logic is disabled on interface appears. If the entry notes that it is disabled, type, set autoconfig enabled=yes interface=Interface Name and press Enter. Close the Command Prompt window.
Nov 25, 2011 | INTELLINET Wireless 150N USB Adapter...
failed to connect to the internet thr wi-fi
f Active Standby is activated on your Cell, your WLAN connection status is always visible from standby mode. The bottom line of the screen shows your WLAN status. If there are no wireless networks in the area, you'll see the message 'No WLAN network found'. If you're near a WLAN that you're not connected to, you'll see the message 'WLAN name found'.
To log on to this network, simply highlight the WLAN status line and press the centre selection key. You'll see three options:
  • Start Web browsing
  • Search for WLAN
  • Switch WLAN scan off
If the WLAN has detected then cell will open, unprotected network (and needs no passcode to access) then simply highlight Start Web browsing and press the centre selection key to go to your Bookmarks page and start browsing the web.
Hope this helps
Jan 17, 2011 | Cell Phones
I need to secure my home wirless network
1) Secure your wireless router or access point administration interface
Almost all routers and access points have an administrator password that's needed to log into the device and modify any configuration settings. Most devices use a weak default password like "password" or the manufacturer's name, and some don't have a default password at all. As soon as you set up a new WLAN router or access point, your first step should be to change the default password to something else. You may not use this password very often, so be sure to write it down in a safe place so you can refer to it if needed. Without it, the only way to access the router or access point may be to reset it to factory default settings which will wipe away any configuration changes you've made.
Most WLAN access points and routers automatically (and continually) broadcast the network's name, or SSID (Service Set IDentifier). This makes setting up wireless clients extremely convenient since you can locate a WLAN without having to know what it's called, but it will also make your WLAN visible to any wireless systems within range of it. Turning off SSID broadcast for your network makes it invisible to your neighbors and passers-by (though it will still be detectible by WLAN "sniffers").
4) Reduce your WL-AN transmitter power
You won't find this feature on all wireless routers and access points, but some allow you lower the power of your WL-AN transmitter and thus reduce the range of the signal. Although it's usually impossible to fine-tune a signal so precisely that it won't leak outside your home or business, with some trial-and-error you can often limit how far outside your premises the signal reaches, minimizing the opportunity for outsiders to access your WL-AN.
5) Disable remote administration
Most WL AN routers have the ability to be remotely administered via the Internet. Ideally, you should use this feature only if it lets you define a specific IP address or limited range of addresses that will be able to access the router. Otherwise, almost anyone anywhere could potentially find and access your router. As a rule, unless you absolutely need this capability, it's best to keep remote administration turned off
Thanks
Have great day
Sep 04, 2010 | Computers & Internet
wireless printing
I assume you have a wireless network set up with a wireless router, since you said you have a wireless laptop.
You need to share the printer on the desktop. You also need to set up both computers to be on the same network (for example, WORKGROUP or MSHOME, or a name of your choosing).Once shared and on the same network, you can go to the laptop and add a printer--just tell it that it is a network printer.
A caution--to work without further hassle, both computers need to be running the same version of Windows. If not, you'll need the driver disk for the system on your laptop.
Jan 16, 2009 | Computers & Internet
how to secure conection to linksys router
Are you trying to secure the wireless connection?
Jun 17, 2008 | Linksys Wireless-G Broadband Router
1,235 people viewed this tip
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
