DVD Players Logo
Tip & How To about DVD Players
How to create stock DVD menus for Dimadsoft DVDRemake Pro
Posted by Owen Stephen DawsonOwen Stephen Dawson on Thursday, May 27, 2010
There are already 4 types pre-loaded Pool 2 is for PAL (720 x 576) with 2,3 and 4 merged titles and Pool 4 is for NTSC (720 x 480) however if you want to create your own the simplest way is to use Adobe Photoshop or CorelDraw and Muxman to create a dummy title and then import this into the stock menu.
All you need to do is located the correct titleset (this is normally the last one on a DVD merger) and right click it and select replace with still from the menu
The best way to create your own is to export an existing frame as a BMP to get the location buttons for you custom title and then use this as a starting point then create your own BMP and then use Muxman to create the VOB that you can then import into DVDRMKP to use for your new merger menu
NOTE:>> Muxman requires the use of 24 bit Bitmaps ONLY, if select the Photoshop 32 bit default this will give you an empty VOB but will not cause an error in Muxman v0.15R so make sure that when you save the file in Photoshop this has been pre-selected with the 24 bit mode.
If you are using the latest FREE version of Muxman v0.16.6 from the 14th October 2005 then you have the option of FORCING the aspect ratio and the resolution for either PAL or NTSC and 4:3 or letterbox 16:9 if you forget to use a 24 bit BMP the resulting VOB will look like this, caught me out a few times I must say..
Anyway point well and truly put I think so if you download version 0.16.6 and FORCE the video you can create not only the VOB file but also the corresponding IFO and BUP (VOB backup) for the BMP that you have created.
Click on START and then use this resulting VOB file to LOAD into DVDRMKP this will add yours to the stock list for use. It will work first time as you used the existing BMP as a template the buttons will already be in the correct place.
Also check out my CDR-Zone Tips wrt removal of commentaries with DVDRMKP from a few years ago
http://www.cdr-zone.com/forum/search.php?search_author=Spideray
Hidden within one of the CDR-Zone forums is this great tutorial by blackstar from 2009 no need to rewrite it here so goto the link below
http://backstar.com/blog/2009/09/22/create-new-menu-for-existing-dvd
This tutorial uses the following FREEWARE Tools and a drawing package for creating BMP's you could use MS paint however I suggest either Coraldraw, Paintshop Pro OR the ever popular Adobe Photoshop CS2
Read more tips from Owen Stephen Dawson
    • By avatarOwen Stephen Dawson Nov 23, 2010
    • N.B:> When using 24bit BMPs with MuxMan v0.15R ensure that the resolution is set to 720x576 for PAL if you try to use a 720x540 resolution it will not work as it thinks it is for NTSC. The later version v0.16 allows you to select either PAL or NTSC.
