Tip & How-To about Computers & Internet
Clean Your RAM & Make Your Comp Speed Better
Hi...
You may recognize that your system gets slower and slower when playing and working a lot with your Desktop or a laptop. That’s because your RAM is full of remaining progress pieces you do not need any more.
Open the notepad and type
FreeMem=Space(64000000)
in this file and save it as RAMcleaner.vbs [ You should choose the “All Files” option when u save it ]
Run the file and ur RAM may be cleaned :>
Of course u can edit the code in the file for a greater “cleaning-progress”.
FreeMem=Space(128000000)
just try it out..
Computers & Internet Logo
cannot play videogames
I'll assume that your notebook is otherwise working fine. Generally most laptops will play simple games with no problems. They do not have the hardware to run something demanding such as Call of Duty. I don't know what version of windows you have but I think the 530 should have come with Vista. Vista is a wee bit of a resource hog so that is one problem. You only have 512mb of ram and that really isn't enough to run Vista let alone something demanding such as a game. The 530 supports up to 2gb of system ram and that is important for a few reasons. First you need to have enough to let Vista run properly and that will use everything you can give it. If you could get it over 1gb you would notice a substantial increase in performance. The last and biggest problem is the video hardware. In this laptop is uses shared memory. This means it does not have dedicated fast video ram but instead relies on the using the system ram. So while you might have 512 of system ram the video card will take probably about 64 mb of that. If you update it to say 2gb then this can increase to a max of I think 225mb. That sounds like a lot but it is shared slower system ram. You do find new gamer laptops with high spec video chips and dedicated vram but even those do not perform as well as a desktop with the same or smaller amount of video ram. Unlike a desktop you cannot change out the video on a laptop so what you have your are stuck with. When it comes to gaming especially something like first person shooters the video card is the key to everything. I have a dual core laptop with 4gb of ram a very stripped down version of windows and 1gb of system ram dedicated to the video. I also have a old 2.8ghz single core pentium with 1gb of system ram but it has a new 1gb video card (important as these have a video processor and do not use the system one) and this does play call of duty at 60-100fps and anything else I can find to try on it. I tried the video card as an $75 experiment as I was about to replace the system. I didn't do that. It makes that much of a difference.
I hesitate to call these fixes as they really won't get you what you want out of any laptop with similar hardware like yours. That really isn't possible because of the slower system ram and shared ram probllems. The first thing is to max out the ram. It will cost a few dollars but then you can max out the size of the shared video ram.Nothing else will have as much effect as doing this to your laptop. Turn off anything you can in vista to speed up performance. It probably has most of it turned off now due to the low ram you have. Disable anything you don't need running. Fir instance office and adobe will load speed loaders at boot up. They are supposed to make these pop open faster. Disable them and you won;t notice the difference for those programs but you will in the system resources they consume. Also make sure anything like msn or yaho do not start with windows. msmessenger especially can at times be a real hog for resources. There are very few programs that ever need to load something at start up to run. Most are for convenience and each then steals resources. Not a big deal if you are not gaming and have plenty to spare but in your case very important. If you are dealing with simple games such as web based card games then usually the issue is with jave. You may need to download and install the java package from sun. As I mentioned you can't really make it into a hardcore gamer machine but hopefully you can see what the problems are to doing that with almost any laptop (not just yours).
Dec 27, 2011 | HP 530 Notebook PC
Can't run a PC game, but its properly installed.
Chances are the desktop PC had a video accelerator and the laptop didnt. Laptops have integrated video cards that share the systems processor and memory to do its work. Video accelerators have their own dedicated CPU and memory and take the video work away from the system. A video accelerator with say 64 to 128 mb of video memory may have a 250 to 300 mhz CPU on the card. This means the system can dedicate the full 1.5 GHz and 512 mb of memory to the game. Integrated video cards like this one will give up about a third of its memory AND half of its processing power to run your game. In essence, the laptop is SLOWER than the desktop when playing the game. If the laptop is running Vista, then the slowdown is even greater.
Mar 01, 2009 | Computers & Internet
Playing Call of duty 4 on vista
could try to add ram. laptops rarely have good video cards for gaming, and its prolly using system ram instead of dedicated video ram. If its using system ram, the reaction time will always be slower than if it had a suficient amount of dedicated video ram.
May 17, 2008 | HP Pavilion dv9000z Notebook
memory upgrade
try with reomiving temperoroy file and delete file or programmes from statrup uninstall unwanted software and run chksdk utility and check for virus also. if you still facing the the problem i will advise you to take a backup of your system and format and reinstall opreating system
Oct 06, 2007 | HP Media Center m7060n PC Desktop
221 people viewed this tip
David Payne
David Payne
