Tip & How-To about Computers & Internet
HOW TO ACTIVATE YOUR WINDOWS XP SP2 COPY (Without programs)....!
Dear All,
It is a way to make windows original, and you can download programs Microsoft and make updates.
lets start:
-open start main,then chose Run and write regedit and Click OK.
-now it opens your system registry editor Go to the existing basic and chose Edit(after the file menu) edit then chose Find.
-Type in the writing OOBETimer, And press the search for the next Find .
-When find this value will be in the form of a blue icon,Put it opens twice each square liberalization value
Look for value FF and Wipe and write instead means 00 (zeros).
-Click OK and then exit the program.
-Now click Start and go to run the operation
And paste there is the following:
C:\WINDOWS\system32\oobe\msoobe.exe /a
-Click OK, Show you screen options reactivate Windows ,Chosen option number one.
-Show you a new page
Click on the button to change the key to the product or ChangeProduct key.
*now enter this serial
B7R7P - J63JP - 2J7VH - W3TDJ - PDP7T
-Then click update and then exit the program .
-now close all programes and reboot your computer.
-Surely wants to really make sure your original xp ? go to run and open :
-Tell you that the product has been activated
Now copy registered go and work updates automatically to your computer.
note:- just make sure to backup your registry before you gona do..
Computers & Internet Logo
removing viruses
Download the free version of MalwareBytes Anti-Malware.
When the program executes, update it, run it and quarantine everything it finds.
Reboot into Safe Mode, usually tapping F8 as the computer starts to boot. Run it again.
Reboot and you are fixed for Malware.
https://www.malwarebytes.org/antimalware/
This program is so good I purchased the paid version after using it for years.
You can also go to the Microsoft website and download free Anti-Virus. Windows Defender wil protect you in real time. Download it and run a scan the same way, normal and safe mode.. Let me know how you get on by posting a COMMENT to this post.
http://windows.microsoft.com/en-us/windows/security-essentials-download
Microsoft Security Essentials Microsoft Windows
Apr 06, 2016 | HP Omni 100 PC
virus says open with
If you have an Antivirus program on your computer, try getting it to scan and quarantine the virus first. If that doesn't work, and you're running XP or higher windows, restore your computer to an earlier date than the problem started occurring. I've had success with this method. Go to "Help and Support" and go to "Backup and Restore", then "Restore". Pick a date and then let the machine run- sometimes it takes it a couple minutes to run, then it will tell you to turn off the computer and let it restart. Good luck, hope this helps.
Apr 17, 2010 | Microsoft Windows XP Home Edition
Microsoft .NET Framework (KB951847) not installing
  • Hi, there are a few things you can do to see if the "Software is installed. The first is to go to the Control Panel's (Programs), Uninstall a programs, you want to view that the software is present. If the software is listed? Try to (repair, or change the program). Next, open the Task Manager from the Desktop, (right) click on the Taskbar to open. In the Task manager you want to open the Services... click on the button. In the next window, scroll through the listings to find the Microsoft. Net... click to open, and see if its (Enabled; if the service is running), if not? Enable the service, Start the service, select "Apply and OK." Note: Most changes, updates, downloads.. require the computer to be restarted for the applications to take effect. "If the solution helped?, "Ratings is appreciated, thanks"
Feb 19, 2010 | Microsoft Network Programming for .Net...
my computer is very slow
on your desktop click on START, then click on RUN, a small windows will open. Type in (msconfig) without the parenthesis., this will open the system configuration windows and make sure (Normal startup is selected) then click on the (STARTUP) tab, click on disable all and then click on APPLY and then OK. a message windows will appear to restart your computer, click on DO NOT RESTART NOW buttom. this will disable programs that start with windows when you turn on your computer to make your computer start faster.
Use this link to learn how to speed up your computer:
http://www.microsoft.com/AtWork/getstarted/speed.mspx
I also recommend using an anti-virus software like (Kaspersky, Norton, Trend Micro or McAfee) internet security software to scan and protect your PC.
You can also download and install Glary Utilities from this website:
http://www.glarysoft.com/
also Run Microsoft Update to download new drivers and software updates to make sure your pc has enough resources to run programs.
My advice is do not run too many programs at the same time, this may cause your system to freeze and become unresponsive.
Comment back if this doesn't help and lets go deep into making your computer faster like running SYSTEM RESTORE, UPGRADING MEMORY, etc.
Good Luck.
Apr 20, 2009 | E-Machines eMachines Desktop PC
after i load ssp2 my computer does not open window program
What is 2.2 frame?
Do you mean .Net framwork 2.2 update from microsoft?
Press & hold the power on button on the E-Machine. That will shut down the PC. Unplug the power cord from the power supply. Wait a minute. Re-connect the power cord to you're PC & press the power button on you're PC. Windows should start & may run check disk before loading windows. Continue updating windows through windows update service. There are more
.Net framwork updates. If you're system continues to run restarting shut it down as before. This time when you start up the PC start pressing the F5 key every two seconds. Windows Advanced Option Menu will load. Choose Safe mode. Open control panel, open add/remove programs. At the top of the window & slightly to the right of the Add or Remove Programs windows is a box next to Show Updates. Left click in the box. Scroll down & find .Net framwork 2.2 & uninstall it. Close all opened windows & restart the PC.
Continue to update you're windows.
Please let me know if this has helped.
Good Luck!
Mike
May 08, 2008 | E-Machines eMachines Desktop PC
165 people viewed this tip
David Payne
David Payne
