Tip & How-To about Computers & Internet
How to solve the "Battery Plugged in not charging"
Battery Plugged in not charging and not detected solution I have a Dell Vostro 1510 laptop, and when i have the battery charger plugged in, the battery icon says "10% available (plugged in, not charging)", and if i pull out the cord, the laptop shuts down straight away. Can this be fixed, and if so, how? I bought this laptop new around 6 months ago. The detail info below:
The Battery didn't charge or detect being plugged in also caused by four reasons:
  • 1. The laptop battery failed
  • 2. The Adapter failed (can not charge the battery)
  • 3. The motherboard charging electric circuit failed (many caused by short damage). You can view more info here: Dell Motherboard Problem
  • 4. The laptop bios is too old to recognize the battery
After I checked my battery and adapter and confirm they are good. Then I try to repair it by myself.. My Latitude E6400 battery was fixed by myself.
The first solution :I search in the google: Repairman from another site suggested that while the computer is on and plugged in, to unplug the adapter and then plug it back in again. To check the computer can started charging.
So I remove the laptop battery from the laptop and left the AC cord connected, booting it up on the power cord alone until I was able to boot into Windows 7, at which point I then put the laptop battery back into the computer while it was still on. This worked and while a tad unsafe for most people, I wouldn’t recommend you use this idea unless you absolutely had to, that is, if there was no other choice.
The Second Solution: You can download the newest BIOS from dell.com and then flash the bios. But I do not want to update Bios, So I use another way to make the Power manager system to recognize my battery :)
I open up my laptop Device Manager (usually a right click on your Computer/My Computer) and remove all Dell inspiron 6400 battery related devices from the Device Manager. Then after you’ve done that, right click again and select “Scan for Changes”, which should reinstall the proper services and allow for your laptop to charge again. See the more info in the image below.
If this also can not solve the problem, I suggest you send the laptop to Dell to repair the Laptop motherboard.
The article Via laptop battery blog
Computers & Internet Logo
dell vostro 1510 laptop showing "Plugged in, not charging". i changed the battery. but the problem is same?
You need to check first if your charger is properly working or not and you can compare the exact voltage by using a multi-meter to ensure of the output is correct or not.
Oct 10, 2013 | Dell Vostro 1510 Laptop
in dell vostro 1510 laptop, when adapter is connected to laptop it showing "plugged in, not charging"
is battery already fully charged? Most of laptops disharge the battery while connected with AC adapter, they do not keep the charge at 100%.
no light indicator charging battery adapter
If the computer starts with the power charger plugged in, then replace the battery.
good luck
Sep 20, 2013 | Dell Vostro 1014 Notebook
the battery runs out, I plugged the power cable for hours after that but my laptop Vostro 1510 is still black out
The battery on the Vostro seems to run out more than the othere models as the processor takes in more current than the other processors. Also with the 15 inch display you have more drain, now coupled with all these factors the quality of the battery seems to be not as desired and there are many cases where the battery runs down than the time period.
So it this case you battery is bad and must be replaced as there is no charge accumulating even with long charging time.
Aug 27, 2011 | Dell Vostro 1510 Laptop
My computer does not charge when on charge display the word "plugin in not charging"
Er this is the dell old problem.
Follow the below steps to fix it.
The Battery didn’t charge or detect being plugged in also caused by four reasons:
  • 1. The Vostro 1510 laptop battery failed
  • 3. The motherboard charging electric circuit failed (many caused by short damage). You can view more info here: Dell motherboard problem
View more here : http://www.laptops-battery.co.uk/blog/battery-plugged-in-not-charging-solution/
Jul 03, 2010 | Dell Inspiron 1525 Notebook
567 people viewed this tip
David Payne
David Payne
