Tip & How-To about Computers & Internet
How to uninstall internet explorer 8 in vista and windows 7
Since the format change the installation of ie8 is sent to a update folder and you must search updates and you will find it in that folder and just delete and reboot then all will be fine.
Computers & Internet Logo
IE8 problems
That sounds to me like something is there that got into your system unexpectidly.
I would restore my system to before IE8. Press start and search for restore point. Select the one that Windows made before installing IE8 and go for it.
Install Advanced System Care from iobit.com and run the whole programme. Then if you must have IE8, install it. You will be equiped to deal with anything the net throws at you now.
Dec 16, 2013 | Computers & Internet
I have been advised to install Internet explorer 8 by going to www.b t.com/help/ie8 ----no such website appears to exist ????? where do I go ?
just go to microsoft updates and download and install ...if you are running Xp ..it is enough to turn on automatic updates from the control panel ...and at one point they will be proposed to install them automatically ...or ..here ...
http://www.microsoft.com/windows/internet-explorer/default.aspx
Jun 15, 2010 | Computers & Internet
IE8 can't install because required updates are older than ones...
This problem is caused by the Multicore Processor support. Enter the system BIOS and dissable the multicore option. Restart the system and load IE8. Shut down and go back into the BIOS. Then reenable the multicore CPU option and restart. Remenver to save options at the end of each BIOS setup.
Sep 21, 2009 | Microsoft Internet Explorer 8
Won't install without error message
Excerpt from: http://blogs.msdn.com/ie/archive/2009/01/26/upgrading-to-internet-explorer-8-release-candidate-1.aspx
There is 1 update required when running IE8 RC1 on multi-core XPSP2 x86 computers:
KB932823 or KB946501.
This update resolves a problem in which an access violation occurs when an application exists on a Windows XP SP2-based multi-core computer. It will be installed automatically if you select “Install the latest updates” option in Setup Wizard. If this update fails to install successfully, IE8 installation will be blocked until you manually install this update from Microsoft Download Center.
So see if you can do a manual install of this update. There are a number of other suggestions in the above link that might also help.
Good Luck!
May 22, 2009 | Microsoft Internet Explorer 8
can not get on to my remote accrss since downloading ie8
Hi
Uninstall the IE8 and then your Remote internet would start working
How uninstall IE8
For XP
Start -control Pannel -add/remove programs - Check Mark View Install updates
find IE8 and uninstall IE8
For Vista
Start -control Pannel -Programs and Features -Left hand Top Coner View installed Updates
Uninstall IE8
Hussain .B
May 18, 2009 | Microsoft Internet Explorer 8
126 people viewed this tip
David Payne
David Payne
