Tip & How-To about Computers & Internet
How to make the taskbar reappear when it disappears in Windows
Sometimes on a computer running Windows, an application will crash or an unstable process will lock up the system, and out of nowhere the taskbar that runs across the bottom of the screen will disappear. The rest of the desktop and all of your icons will probably still be visible -- it's only the taskbar that is gone. Without the taskbar, you can't access the Start menu or view the open programs in your system notification tray.
To get your taskbar and Start menu back without shutting down your computer, hit and then (depending on the version of Windows that you are running) choose the appropriate option to open the Task Manager. (In Windows XP Professional, for example, there is a button labeled "Task Manager".) When the Task Manager window appears, select File from the menu bar and then from the drop down menu click on "New Task (Run)". Type "explorer.exe" into the text bar and hit . Windows will sort of "reset" itself, and the taskbar and Start button will reappear. (This may take a minute.)
Whatever caused the system to become unstable in the first place could easily happen again, so at this point it's a good idea to save any unsaved data, close all open applications, and then shut down and reboot your computer. If the same problem happens again, make a note of which programs you were running when it occurred, as it may be a resource conflict or compatibility issue that's causing the problem.
Computers & Internet Logo
primavera softawre not login
Problems: App Crash Problems usually happens when the computer overloads with to much data, or when certain system files become missing or broken. This is a critical sign of an unstable system that is typically caused by improper maintenance of the computer. dialog_warning.png Symptoms:App Crash Problems symptoms can include program lock-ups, slow PC performance, system freezes, blue screen, shutdown or startup problems, and installation errors.
Recommendation: To scan, diagnose and repair your computer, use the Free Download Advanced System Care from iobit.com
Nov 20, 2013 | Computers & Internet
computer is slow and it takes a long time to load application when i try to play a game on facebook
You need to clear your Windows Registry, I think. The Windows registry keeps growing as long as you use your computer. Whenever you install or uninstall software, add or remove hardware, or change your computers settings, a new entry is inserted into the Windows registry. Over time, your registry will be accumulated with a large number of obsolete, redundant and invalid entries and registry holes, which make your system increasingly unstable, run more slowly and crash more frequently.
www.comtips.net/go/perfectbooster.php
Feb 14, 2012 | Google Chrome
my computer problem is 0x3bc3 just crashed
Saw a solution in the web and it helps. Try the following step;
"System process at address 0xE4783995 have just crashed, please follow these steps to deactivate it from your system." is a fake warning and the only visible part of the infection which is defined as a Trojan/Ransomware. It's a piece of malware that blocks pretty much everything on your computer and demands payment in exchange for the identification key. In order to remove the "System process at address 0xE4783995 have just crashed"
STEP
Enter this code: 754-896-324-589-742 to unlock your computer.
HOW TO UNINSTALL IT
To remove all System process at address 0xE4783995 have just crashed files, you must kill all System process at address 0xE4783995 have just crashed processes that are running in your computer's memory. To kill System process at address 0xE4783995 have just crashed processes, press CTRL+ALT+DELETE to open the Windows Task Manager. Click on the "Processes" tab, search for System process at address 0xE4783995 have just crashed, then right-click it and select "End Process" key.
You'll also need to remove System process at address 0xE4783995 have just crashed registry keys. To remove System process at address 0xE4783995 have just crashed registry keys, click on the Windows "Start" button and select "Run" to open Windows Registry Editor. A window will popup. Type "regedit" into the box, and click "OK". Search for the registry key "HKEY_LOCAL_MACHINE\Software\System process at address 0xE4783995 have just crashed." Right-click it and select "Delete."
Finally, you'll need to manually delete other files to clean your PC of System process at address 0xE4783995 have just crashed. These System process at address 0xE4783995 have just crashed can be in the form of EXE, DLL, LSP, TOOLBAR, BROWSER HIJACK, and/or BROWSER PLUGIN. For example, System process at address 0xE4783995 have just crashed might create a file like
%PROGRAM_FILES%\System process at address 0xE4783995 have just crashed\System process at address 0xE4783995 have just crashed.exe. Locate and remove these files.
Jul 04, 2011 | Computers & Internet
hi i have labtop acer emachine e 510 when i wanna log in this message appear system process at address 0x3bc3 have just crashed please follow these steps to deactivate it from your system * i cant reach any of number to take deactivate key and even i call i cant speack in en please tell me what can i do to solve this problem format the window?? or get the key from anyone?? please help me.. thank
IT is a fake warning and the only visible part of the infection which is defined as a Trojan/Ransomware. It's a piece of malware that blocks pretty much everything on your computer and demands payment in exchange for the identification key. In order to remove the "System process at address 0x3bc3 have just crashed"
STEP
HOW TO UNINSTALL IT
3bc3 have just crashed files, you must kill all System process at address 0xE4783995 have just crashed processes that are running in your computer's memory. To kill System process at address 0x3bc3 have just crashed processes, press CTRL+ALT+DELETE to open the Windows Task Manager. Click on the "Processes" tab, search for System process at address 0xE4783995 have just crashed, then right-click it and select "End Process" key.
3bc3 have just crashed registry keys. To remove System process at address 0x3bc3 have just crashed registry keys, click on the Windows "Start" button and select "Run" to open Windows Registry Editor. A window will popup. Type "regedit" into the box, and click "OK". Search for the registry key "HKEY_LOCAL_MACHINE\Software\System process at address 0x3bc3 have just crashed." Right-click it and select "Delete."
3bc3 have just crashed. These System process at address 0x3bc3 have just crashed can be in the form of EXE, DLL, LSP, TOOLBAR, BROWSER HIJACK, and/or BROWSER PLUGIN. For example, System process at address 0x3bc3 have just crashed might create a file like
3bc3 have just crashed\System process at address 0x3bc3have just crashed.exe. Locate and remove these files.
Jun 29, 2011 | Computers & Internet
560 people viewed this tip
David Payne
David Payne
