Tip & How-To about Health & Beauty
Equinox EQ-310-cth thero/hygro/clock
I have Equinox EQ-310-CTH
thermo meter how adjust the clock
Health & Beauty Logo
where is the ad know located on 2006 Chevrolet equinox?
push clock button top right your hour should blink then use your radio tuning knob to adjust hrs. push clock button again to switch to minutes and use tuning knob again to adjust minutes once set just press the clock button to enter
Oct 09, 2014 | 2006 Chevrolet Equinox
when setting up xr8600 is it best to start mains and monitors master at 0DB?
1. Turn the main and monitor volumes all the way down (off). Plug a cd player into channel 9/10 and play a track of music of your liking. With the main/monitor volumes still off, adjust the gain on 9/10 until the clip light turns on, then back it down until the clip light just turns off. Put the channel volume at 12 o' clock.
2. With the music still playing, turn up the mains to the desired listening level first, and then adjust the graphic eq until the music sounds good in the room. Remember or mark the position of the volume control. Do not use the channel eq on 9/10 for music that has been mastered properly, leave the eq flat. Once this step is completed then you have now set the main eq.
3. Repeat the same for monitors. Turn off the main volume and then bring up the monitor main volume to the desired level first, then set eq. Now your monitor eq is set properly. Remember or mark the position of the monitor volume.
4. Set up microphone - plug a mic into channel 1 with volume all the way down. Speak or sing into the microphone and adjust the GAIN until you see the clip light, then back down a litttle on the gain. Put the monitor and main volumes back up to the mark from step 2. Now adjust the volume and monitor send on the mic channel to the desired loudness first before adjusting the mic channel eq. Use subtractive eq method to minimize distortion and feedback. ...i.e. if the mic is bassy then turn down the lows, do not ADD highs. If the mic needs bass, turn down the highs.
Jun 08, 2014 | Peavey Xr 8600 8 Channel Powered Mixer
I don't understand how to use the 'tone' controls
Watch vidoes on "mixer setup". Don't worry if they are not your exact model as the principles are essentially the same among the various types. EQ controls for the channels are "flat" when they are all set to 1 o'clock. The lower one reduces or boosts the bass, the next the midrange and the high the trebles. SOme have a midrange EQ frequency which adjusts the cnterpoint of the midrange frequency. Leave this at 12 o'clock until you get familiar with the rest if your unit happens to have that extra control.
Jun 05, 2011 | Phonic Powerpod K12 Plus 1000W 8...
hITACHI HCU-AX10E Hifi, how to set the timer & EQ
Clock,timer,eq and presets you can adjust by remote control
Aug 29, 2009 | Audio Players & Recorders
I cannot set my clock on a pioneer deh 1100
Shut off the radio. now you can set the clock through the EQ buttons as stipulated in the instruction book that came w/ the unit...Steve A...lol...
Dec 05, 2007 | Pioneer DEH-1100 CD Player
1,297 people viewed this tip
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
