Tip & How-To about Microwave Ovens
How to uninstall program from my DELL computer
Questions people asked:
1 How to uninstall program that’s not showing up?
2 I go to add/remove programs and want to uninstall program. It says “error, can not delete the program”, how can I remove it from my DELL computer?
3 I recently install McAfee and my computer gets a Blue Screen, Should I uninstall it? How to remove it from Control Panel?
You may face stubborn program of uninstalling an unwanted program especially it is an anti-virus.
How to remove corrupt programs from your computer in one minute? You can get the best solution to remove a program completely from your PC.
Add/ Remove Programs utility usually helps you remove programs from your computer. Unfortunately, it can only find common program install on your computer. It can not show hidden programs and some malicious programs such like windows messenger, vista protector, Norton anti-virus 2006, etc.
You can not remove anything if you uninstall using Control Panel. Every time you install a program, your registry entries will be modified. The residue can be the causes of Blue Screen, computer freezing, DLL error and computer slow. If you want to remove programs completely, you should also remove associated registry entries. It is also the best solution to remove corrupt programs.
Get rid of programs which combine well with the operating system:
Troubled with uninstalling programs? Don’t worry! You can solve it in one minute. ErrorFix integrate with Windows registry fix tool, uninstaller, invalid file removal and IE restore program.
Download this excellent uninstaller now.
With this software, you can forcibly remove a program even it is running. Why not experience this wonderful software? You don’t have to get more computer savvy.
Microwave Ovens Logo
Mod.KHMS155LSS-1 Getting F-6 Fault code ????
Search Results
    Combination Microwave Wall Oven - Error Code/Message ...
    www.kitchenaid.com/...microwave...error-code...f6-error-cod...
    KitchenAidQuestion: Combination Microwave Wall Oven - Error Code/Message - F6 Error Code -F6 E8. Answer. Product Symptom: Combination Microwave Wall Oven ...
    Over-the-Range Microwave - Error Code - Starts with F ...
    www.kitchenaid.com/...microwave-error-code...f...f6...code/P...
    KitchenAidKitchenAid's product help articles give answers to your frequently asked questions (FAQs). ... Microwave - Error Code - Starts with F - Starts with F6 - F6E0 Code.
    Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost ...
    www.shopyourway.com > Manage My Life > Questions
    I have a Kitchen Aid Model # KEMS308SSS02 and I getting the follow error message... is working and was always working but the top microwave/oven does not work. ...Kitchen Aid Oven Model # KEMS308SSS02 error msg - Lost Err/ F6 E0/ ... Most "F6/E0" fault codes is usually because of a loose wire connections, loss of ...
Feb 05, 2016 | KitchenAid Microwave Ovens
Would like specifications to JVM1850SM2SS
  • 1.8 CF Oven Cavity
  • Electronic Touch Controls
  • 950 Watts
  • Display On/Off Yes (option pad)
  • Add 30 Seconds Instant-On
  • Cooking System CircuWave®
  • Defrost - Auto / Time / 1 lb. Quick Defrost
  • Delay Start
  • Express Cook Instant-on 1-6 minutes
  • Instant On Controls
  • Micro / Time Cook I & II
  • 10 Power Levels
  • Wire Oven Rack
  • Cooktop Lighting - Bright/Night/Off
  • Demo Mode
  • Interior Oven Light - Halogen
  • Night Light (option pad)
  • Child Lockout
  • Easy Mount Installation
  • Exhaust Fan 3 Speed Plus Boost (315 CFM)
  • Cooking Complete Reminder
  • Timer (On/Off)
  • Reminder (24 hr)
  • Sound Volume Control - 4 levels
  • Sensor Controls
  • Beverage Instant-On
  • Popcorn Instant-on
  • Potatoes Instant-on
  • Reheat Instant-On
  • Sensor Controls
  • Vegetables Instant-on, 3 pads (canned, frzn, fresh)
  • SmartControl System
  • Clock Plus AM/PM pad
  • Concurrent Programming
  • Custom Pad
  • Electronic Scrolling Digital Display - 2 line
  • Help Pad
  • Variable Scroll Speed - 5 Speeds (Options Pad)
  • 14.25 " Turntable - Glass Recessed
  • Turntable On / Off
  • 2 Wire Oven Racks; 2 Positions
  • Recirculating Charcoal Filter Kit JX81B
Dec 15, 2014 | GE Microwave Ovens
I don't have the Manuel to program a WESTEK TE22DHB timer. Can you locate one or tell me how to program it?
Many timers are sold under different brand names with different numbers.
For example Westek TE06WHB is same as Woods 59377
Sometimes different timers are packaged under same number, for example Utilitec TE06WHBL is shipped as the old Woods TD1300.
GE and Utilitec sell the same timer with different numbers.
Westinghouse and Stanley and Utilitec and Woods overlap.
I got manuals for some, and can sometimes cross reference if you describe the timer.
1) take a minute and add a comment with description of button layout with button names, or describe the dial and switches. Be as detailed as possible.
2) Look through timers on following links and see if your timer shows:
http://waterheatertimer.org/Woods-timers-and-manuals.html
http://waterheatertimer.org/GE-timers-and-manuals.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 23, 2011 | Microwave Ovens
my microwave shows an error that says c-5 what is it
That would be "CS", which means low current sense.
CS Current Sense
Current Sense - Indicates control is sensing low current
(Amp) draw. Check components which would allow unit
to run but produce no heat or low heat. Current sense
circuit is active only when using pre-programmed pads.
Time Entry feature will by-pass current sense circuit.
Red wire from cavity T.C.O. must be routed through
current sense loop on H.V. Board.
Possible Causes:
1. Interlock switch (contacts 2 & 3).
2. Open thermal cut-out (magnetron).
3. Open/loose wire.
4. Power relay.
5. H.V. Board.
6. Magnetron.
7. Diode.
8. Capacitor.
9. Transformer.
10.Triac.
See the full service manual here.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Oct 01, 2010 | Amana RC17 Microwave Oven
RVM1435 Turntable not working
The turntable motor can be replaced by following these simple steps:
1. UNPLUG the microwave before servicing.
2. Locate and remove the screws around the perimeter of the bottom panel of the microwave (located UNDER the microwave bottom).
3. With the screws removed the panel will open, exposing the turntable motor. Remove the glass tray and reach inside the oven cavity and grasp the turntable spindle. Pull straight up to remove it from the motor shaft.
4. With the spindle removed, disconnect the motor connector plug and mounting screws.
5. Insert new motor and reinstall everything using the steps provided in reverse order.
If you have any questions, please let me know. I hope this helps you.
NOTE: If this microwave is mounted, this repair can be performed without uninstalling the oven.
Aug 15, 2009 | Hotpoint RVM1435 Microwave Oven
246 people viewed this tip
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
