Tip & How-To about Computers & Internet
Using a crossover cable to connect two computers.
Hi.
You can use a crossover cable to share files and folders between the two computers.
A crossover cable looks exactly the same as any Ethernet cable, but its internal wiring is reversed respect to the regular cables used to connect computers to routers or switches.Crossover cables have the 1st and 3rd wires (counting from left to right) crossed, and the 2nd and 6th wires crossed, thay can be recognised because the word Crossover is printed on top of the cable.
Before proceeding ensure that the cable you are using is a crossover. Crossover wiring isdifferent. By using an ordinary ethernet cable you will not be able to extablish a directconnection between computers.
To use the crossover you will need to disconnect any other cable connection to computer ethernet cards. Naturally both computers must have a wired network adapter installed .
After connecting the crossover, you will need to configure the network connection.
Turn off both computers, connect the crossover (cat5 or cat6) cable, and turn back on computers.
Ensure that all firewallare turned off, and on Vista answer yes to all requests of authorization for the new network.
On both computers go to system properties, and ensure that the two computers have the same workgroup.
Second step is going to Sharing and Security, in system properties, and sharing the files and folder that you want to transfer.
Once the folders are shared you will see in My computer (Computer on Vista) the folder shared from the other computer. Simply copy and paste the files.
You may be asked to restart computer after each step.
If after sharing files and folder you want to share Internet connection, then you will have to assign two IP addresses that are in the same range to the two connected computers.
An IP address is a series of numbers from 1 to 256, in the format XXX.XXX.XXX.XXX . The two IP addresses must share the first three numbers to share the internet connection. In the real case, you can set the IP adresses to 192.168.0.1 and 192.168.0.2.
See also:
Connect two computers using a crossover cable
Computers & Internet Logo
How do I connect two notebooks (running on XP
Connect the two computers together either with a Crossover cable or a Hub/Switch to the Ethernet card in your computer.
Set the IP address on both computers. Goto Start > Control Panel >Network Connections (choose switch to classic view if you cannot see network connections)
Look for your Local Area Connection Ethernet adapter, right-click and choose properties.
Select Internet Protocol TCP/IP and choose properties.
Setup the IP as 192.168.1.1 and the subnet mask of 255.255.255. 0 on the first computer and 192.168.1.2 on the second with the same subnet mask.
Choose OK then OK/close again
To share your files, right click on any folder and choose Sharing to make them shared.
Apr 04, 2012 | Computers & Internet
How to connect two computers using a crossover cable.
Here's a tip for isolating printer problems on a network. Set up as above suggested by Ginko, then you can print to a printer without using the existing network you suspect is causing problems by using the crossover cable from a laptop to the suspect printer.
May 25, 2010 | Microsoft Windows Vista Ultimate Edition
i want to network two pc with windows xp using crossover cable,, how do i do it step by step pls.
If you need to connect two computers but you don't have access to a network and can't set up an ad hoc network, you can use an Ethernet crossover cable to create a direct cable connection.
Generally speaking, a crossover cable is constructed by reversing ("crossing over") the order of the wires inside so that it can connect two computers directly. A crossover cable looks almost exactly like a regular Ethernet cable (a "straight-through" cable), so make sure you have a crossover cable before following these steps.
Before buying a crossover cable, check your network adapter. Some newer network adapters automatically "cross over" when they detect that they are connected directly to another network adapter using a regular Ethernet cable.
To connect two computers with a crossover cable
This works best if both computers are running this version of Windows.
Plug each end of the crossover cable into a network port on the back of each computer.
On one of the computers that is running this version of Windows, do the following:
Open Network and Sharing Center by clicking the Start button , clicking Control Panel, clicking Network and Internet, and then clicking Network and Sharing Center.
In the network map at the top of Network and Sharing Center, double-click the Unidentified network? icon. (If you have more than one network, this icon will be labeled Multiple networks.)
If network discovery and file sharing are turned off, in Network, click the Information bar containing the following message: "Network discovery and file sharing are turned off. Network computers and devices are not visible. Click to change...," and then click Turn on network discovery and file sharing. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
In the Network discovery and file sharing dialog box, select one of the following options:
No, make the network that I am connected to a private network
Yes, turn on network discovery and file sharing for all public networks
The first option is usually the best choice because it only affects the network that you are connected to.
Notes
Networks created with crossover cables are automatically set up as "Public place" networks, which means that network discovery, file sharing, and printer sharing are off by default.
For Gigabit Ethernet or token ring networks, you will need a slightly different kind of crossover cable. For more information, contact a cable manufacturer.
Icons for both computers should now be visible in the Network window. Double-click each computer icon to share printers and other resources.
Note
If one of the computers is running Windows XP, it can take some time for that computer to appear in the Network window. You might need to move both computers to the same workgroup. You can do that by changing the workgroup on either computer. To change a workgroup, see Join or create a workgroup. You might also need to turn on file and printer sharing on the computer running Windows XP.
Hope this help!
Sep 06, 2011 | Pine Technology Motherboard Xfx Nforce...
purchased a gigaware cat5e crossover network cable to transfer files from one older computer to a new one. Cant get it to tranfer info.
So that you will be able to transfer your file from one PC to the other you have to share your folder first.
1. Share your folder in your old computer. Right click the folder then click Properties and Choose Sharing Tab. Check Share this folder (For windows 7 or vista you have to click Advance sharing button first) 2. Open your explorer from the other computer and Choose Network. Now, you should see the shared folder where your files are. Then start copying the files to your new computer.
*Note: you can also delete the files from the other computer by setting permission of the folder properties.
regards
Apr 02, 2011 | Computers & Internet
Transfering data from one computer to another
I think there is no way to do that. You CAN do it, however, with a crossover cable. It looks the same as a regular cable, but it's not. With the crossover cable, just connect the two computers and give 'em two IP's in the same network. Then enable file sharing and it should work. Sorry, I can't go into much detail because I haven't done that in a looong time, but I think that's about it. Hope it helps.
Sep 11, 2008 | Cat5e Computers & Internet
212 people viewed this tip
David Payne
David Payne
