Tip & How-To about Cell Phones
Display an image when someone's calling:?
Go to Menu > Contacts > "select a contact card" > Options > Edit > Options > Add thumbnail > "choose an image
Cell Phones Logo
How to assign a different ring tone for specific contacts on Nokia 5230
Groups can contain any number of contacts, and even just a single member, so you could, for instance, have one ringtone for family members, one for work colleagues and one for your partner.
To create a group, assign a ringtone and image and then select a group's members, follow these instructions:
  • From the main menu, highlight Contacts and click Select.
  • Highlight Groups and click Select.
  • Click Add (or if you have already added groups, click Options, highlight Add new group and click Select).
  • Enter a name for the group and click OK.
  • Highlight the group's name in the list and click Options.
  • Highlight Group details and click Select.
  • Highlight Group ringing tone and click Select
  • Highlight Open Gallery, click Select, locate the ringtone in your gallery and click Select to apply.
  • Highlight Group image and click Select.
  • Click Add, highlight From Gallery, click Select, locate the image in your gallery and click Select.
  • Now highlight Group members and click Select. Click Add and your contacts list will open. Highlight the contacts you want to add to the group and click Select. You can add as many contacts as you like to each group.
If you want to add contacts to an existing group, highlight the group's name on the Groups screen, click View and click Add to display your contacts list. Highlight a contact and click Select to add them.
Nov 22, 2010 | Nokia 5230 Cell Phone
how to save contacts to sim on nokia n97 please?
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} You can save and update contact information, such as phone numbers, home addresses, or e-mail addresses of your contacts.
To add a new contact to the contact list:
  2. Tap a field to enter the information in the field. Fill in the fields that you want, and select Done.
To edit contact information, open a contact and select Options > Edit.
If you want to remove a contact, select a contact by tapping it lightly (do not open it) and select Options > Delete.
i hope this will help you,
Goodluck. :)
Dec 11, 2009 | Nokia N97 Cell Phone
How to switch fixed dialling on nokia n73?
Press menu button and select Contacts > Options > SIM contacts > SIM directory to see the names and numbers stored on the SIM card. In the SIM directory you can add, edit, or copy numbers to contacts, and you can make calls. To view the list of fixed dialing numbers, select Options > SIM contacts > Fixed dialling contacts. This setting is only shown if supported by your SIM card.
Oct 17, 2009 | Nokia N73 Cellular Phone
dont know how to change ringtone on my sci phone
1. At the main menu, select “Settings”
2. Now select “User profiles”
3. In the next menu, select “General”
4. Now “Customize”
5. Select “Tone setup”
6. Choose which SIM (on dual SIM card phones) you want to assign a ringtone to.
7. You will now see a list of available ringtone.
8. Select it.
You should see at the very bottom of this list 5 empty locations this is where you can add your own mp3's as ringtones.
Apr 09, 2009 | Dual Electronics CECT P168 Cellular Phone
help with samsung sgh g600
Good day
When you are in the Camera, about to take a photo, press the left soft button, this is your menu for shooting a picture, in there you will get the settings for brightness, flash, etc.
To add a ringtone to a Contact, go to Contacts, choose the contact that you want to add the ringtone to, select view, scroll down to the icon that looks like a bell, select it and choose your ringtone.
To add a picture go to Contacts, choose the contact that you want to add a picture to, select view, scroll down to the icon that looks like a mans head, select it and choose a picture to add.
Please be advised that you can only choose ringtones and pictures that are on the phone, not those that are on a memory card
Hope this helps you
Regards
Nov 09, 2007 | Nokia 1100
99 people viewed this tip
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
