Tip & How-To about Nintendo Wii Console
How to Sync Your Wii Controlers
I thought that everyone knew about this but from a lot of questions, some people don't. When you can't get your controllers to work by pushing the 1 and 2 buttons, you may need to sync the controllers.
In the front of your Wii, there is a flap. If you open the flap, there is an SD card slot and a red button. Also, on your Wii controllers, when you remove your battery cover, there is also a red button. If you hold both red buttons for a while, the controller should sync and should be able to work.
Syncing a controller is very useful when you need to use your controlers on a different Wii. When you use your controllers on a different Wii, they will not work unless you sync them.
Nintendo Wii Console Logo
my car stop when i release the gas and push the brakes in stop lights or intersections
POSTED 2 TIME, BUT THIS ONE LONGER. read other post answer now.?
your engines stalls! if engine stalls so does car.
BUT DOES IT RESTART EASY,??????
Does the restart, starter sound fast and normal or weak
can you prevent the stall with fast right foot action?
ever get a tuneup in last decade?
most stalls are caused by 50 things.
top of list is MISFIRING.
http://jeepdied.com/Misfire101.html
Feb 01, 2016 | 2006 Jeep Grand Cherokee
it has fuel pressure and how do i check the ecu codes where would the unit be located
How do you check codes on an OBD2 system ?
Thought everyone knew you needed code reader
& the DTC Connector is under the dash next to your
right knee
Mar 29, 2013 | 1997 Nissan Pathfinder
Hyundai H100 diesel engine how to replace spark plugs.
when i used to teach mechanics many years ago i sent this disruptive student outside in the cold to change the spark plugs in my ford transit diesel ,after half an hour this clever little disruptive lad came back into the class and was totally demoralised because he couldnt find the spark plugs and everyone was laughing at him because they all knew it was a diesel and he thought he knew it all .Now you sure you dont mean the heater glow plugs ??
Jan 27, 2011 | Hyundai Tucson Cars & Trucks
how to add transmission fluid to 2000 bmw 740il
Hey
They don't put a fill tube on them . It's suppose to be life time fluid. Must be filled from the fill hole and the plug is on the right rear side of the trans.
Hope this has helped
Jun 17, 2010 | 2000 BMW 7 Series
Remote not working/No universal remote code either
you can set up any like this
1. turn on what ever you want set up
2. press and hold set up tell light blinks or stays lit
3. push what you are trying to set up t.v. or dvd ect.
4. push power on/off tell it turns off
5. push enter when it turns off
Thank you for useing fixya please rate me
Feb 12, 2009 | Samsung LA26R71BD 26 in. HD-Ready LCD TV
703 people viewed this tip
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
