Tip & How-To about Computers & Internet
Time will reset everytime I start my Pc after power off
This problem can be fixed very easily, There will be a CMOS BATTERY in the motherboard (Coin sized) , Once you replace this battery with a new one, your problem will be fixed.
This problem occur if the CMOS BATTERY has became weak, It cannot store the time so every-time you start the computer after power off your time will be reset or the time will be changed.
Once the CMOS BATTERY is replaced with new one, it will work perfectly.
Rate my Tip.
Regards
Computers & Internet Logo
cmos battery failure
The BIOS battery may be flat and needs replacing.
This battery is probably a coin size lithium battery approx. 20mm in dia. and could be a CR2030 battery.
After inserting the new battery go into the BIOS configuration and set the Date and Time etc.
Mar 29, 2011 | Intel D102GGC2 Motherboard
I have gigabyte gl 81915 motherboard on my cabinet. but some days ago it's display check sum error default loaded so how can i solve it give me solution?
The CMOS checksum error occurs when the CMOS battery is worn out and the CMOS data gets corrupted. Replace the CMOS battery, this battery most likely a CR2032 lithium coin size button battery - check to make sure before you purchase.
After replacing with a new battery, then go to the BIOS configuration and set the Time
Sep 02, 2010 | Gigabyte GA-945GCMX-S2 Motherboard
Every time when i restart the system my Time is changing so how can i fix this problem
1. There is a coin sized battery present onto your motherboard, which is used to remember your computer CMOS/ BIOS settings as well as date and time.
2. If the system time keeps changing when your computer is turned off and started back, this indicated that your CMOS battery in your motherboard drained out of its charge.
3. Open you computer cabinet and locate the CMOS battery. Replace it with a new one similar to this.
4. Restart your computer and set the time once and it will be retained forever without any problem
I hope this is helpful to you.
Please rate the solution provided.
Thanks
Aug 15, 2010 | ASUS Computers & Internet
low battery alert at start up. must always type
The only battery in a desktop PC is the CMOS battery. This is a 10c sized silver disc that is held in a plastic black clip on the Motherboard. It can be clipped out and easily replaced. they are 3.6v and somewhere like Radio Shack etc. will have them.
Jan 27, 2010 | Dell Dimension 8400 PC Desktop
cmos battery
open the case at back of your notebook you will see the motherboard, look for the battery just a size of a coin, thats the cmos battery and replace it with a new one.
Nov 08, 2009 | Sony VAIO PCG-K23 Notebook
137 people viewed this tip
David Payne
David Payne
