Tip for XHB123D X/Y Series Heat/Cool BTU 12000/11600 Air Conditioner
Carrier PPA / PGA model error codes
posted on Apr 07, 2008
bobotfel
bobotfel
Rank: Guru
Rating: 87%, 283 votes
CARRIER PPA / PGA MODEL ERROR CODES
Comment by bobotfel, posted on Apr 07, 2008
NO. OF LED BLINKS ERROR CONTENTS POSSIBLE DEFFECT 2 blinks Room Air Thermistor 1.Check for defective room air thermistor. 2. Defective control board. 3 blinks Indoor coil thermistor 1.Check for defective coil thermistor 2.Defective control board. 4 blinks Compressor drive malfunction 1.Check for trip off outdoor. 2. Check for defective compressor. 3. Check for trip “off” circuit breaker. 4.Check the outdoor fan motor operation. 5. Re-tight all terminals and terminal clips. 6. Check if charge of refrigerant is adequate. 7. Check if current reading is correct. 8. Check for defective thermistor 8 blinks Indoor blower motor RPM 1. Check the operation of indoor blower motor.
Very Helpful
Was this helpful?
Yes
No
1 person thought this was helpful
Featured Tip
nxt prv
Add A comment
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
Can you Help with these Air Conditioners problems?
Answer
need owners manual for my unit or the wiring specs for it cant find the model number help on that... (More)
Answer
carrier ac model no cac 19 can i get wiring diagram please send by mail
Answer
Hi Just had a Carrier Infinity 96 (40000BTU) installed a few months ago in our 1500 sq ft home. My... (More)
Answer
where does the electric pilot hook up to the furnace unit. It seems my pipe has moved over the years... (More)
Describe your problem:
Select a Category:
Insert Link
Insert Image
Insert List
Insert List
Spell Check
What is this?
Select
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
