Tip & How-To about DekCell EasyCap USB 20 Video Capture Adapter with Video Editor Software (CPA1280) Video Capture
Windows7 64bit & EasyCap directions
Ulead Video Studio SE DVD how to run on Windows7 64 bit systems by Not you. Drivers updated now has drivers for XP Vista and Windows 7 7/16/2010 Getting started,you will need another program its called USB-AVCPTSetup_For_Win7 you can get it here... download links are at the bottom of page.Do not install at this point save to your desk top! Ok your ready Do not plug in your Easy cap usb drive. 1. Put the EasyCap disk into your CD Rom When auto play starts click Run HAutorun.exe a window will open DO NOT INSTALL THE DRIVER !!!! 2. click Install Video Studio,complete the install adding your code with no driver reboot when asked. after reboot remove the disk you will not need this anymore. 3.DO NOT INSTALL THE EASYCAP USB DRIVE YET. 4. Install the software you saved to the desk top (USB-AVCPTSetup_For_win7) reboot your system. 5. Plug in the EasyCap USB stick and wate till the driver installs this will be done auto,in a few seconds. 6. Sorry to say but you need to reboot now. leave the USB drive in its port. You are now installed but your cam will only show a black screen at this point,its ok we are now going to resolve that. Start the Ulead Video Studio. During the start up you'll have the choice of VideoStudio Editor or Movie Wizard click the 16:9 ckeck box at the bottom then click VideoStudio Editor. New window will open click Capture,now look for capture video button on the right side of the black screen,click it Just to the right you will see an Options button click. A drop down will show,look to see if input source is in dark letters,if so open and set source to NTSC/M and composite video is checked. If the input source is greyed out,open Capture properties directly under the input source,a new box will open click properties a new box will open this box will have 3-4 tabs you only need the first tab called Image tab under video sources click ntsc/m and composite video click ok click ok again thats it you should now have video,After any restart you will need to reset ulead up again,you should be good to go...... Hope this helps :-} Here are some pic's to help.Note after the instalation,if you move the Easycap usb drive from the usb port it was installed in and input it into any other port it will not work,the driver will need to be reinstalled!!! New download links For Windows XP/VISTA/7 32-Bit, please download Windows 7 64-bit This web page I have not goten any link to open but thought I'd add it so you all can see it,if anyone gets it open please post any or all links for us all. Thats all for now I'll upload more as I get them. ps working with a company rep now,update for easycap d60 4 input style,If not getting a picture on input 1 move to 3 for setup and one camera setting.
DekCell EasyCap USB 20 Video Capture Adapter with Video Editor Software (CPA1280) Video Capture Logo
is my linux computer compatible with windows xp software? are the parts interchangeable? example= installing a linux video card in a windows 7 tower?
Most devices that have Unix drivers will also have drivers available for some versions of Windows. Asus lists XP drivers for this board: http://www.asus.com/Motherboards/AMD_Socket_754/K8V_SE_Deluxe/#download . The K8V-SE Deluxe motherboard is not listed as Win7 compatible (but it's not listed as known incompatible either). To test if this board is Win7 compatible, update to the most recent BIOS, then use a Win7 install DVD to search for drivers and other support. (I know the Windows Update disc confirmed that my WinXP box would support Win7.)
For moving components into another computer, you will need to identify the exact device that you want to move and the slot/interface for that device. For example, since ASUS K8V-SE Deluxe motherboard has an AGP video card slot, it will not fit in a newer tower with only PCIe or PCI slots. If your Win7 tower does have an AGP slot, you may need to look in will amongst the drivers for "legacy cards". Finding an XP driver will be fairly easy. The Windows 7 driver may not exist and Win7 may not run without an external video card (if it can load at all).
I hope this helps. If you are looking at a different motherboard or wish to check specific components, please add a comment with the make and model of those parts. I'll be glad to try to find additional information. Include in your comment whether the Win7 tower is/will be running Windows 7 32-bit or 64-bit. Drivers for the 32-bit Windows are more common since they don't need the signature. (To check if a Windows machine is currently running Win7 64-bit, click Start > Control Panel > System and Security > System. If the title ends with x64, it's the 64-bit OS. Otherwise it's the 32-bit version.)
May 11, 2012 | ASUS K8V-SE Deluxe Motherboard
Instant dvd recorder software 'not responding'
Hello Joshua,
Instant DVD Recorder 2.6.1 UPDATER
  • Please install the Instant DVD Recorder 2.6.1 UPDATER if you are using the Dazzle DVD Video Recorder, Dazzle Video Creator or Dazzle Video Creator Platinum with a previous version of Instant DVD Recorder. This updater also includes the hardware drivers.
  • If you are using a Dazzle product already that includes Instant DVD Recorder version 2.6.1, then you do not need to install this update.
New with this version:
  • added support for Windows Vista 64 bit and Windows 7 (32 & 64 bit)(
  • Includes Windows Vista and Windows 7 drivers (for both 32 and 64 bit) for the DVC 100, 101, 103, 107 hardware NOTE: DVC130 and DVC170 don't have 64 bit drivers and can only be used with Windows XP and Windows Vista 32)
  • 16x9 detection
  • PCM Audio (already included with Instant DVD Recorder ver. 2.5)
Supported Hardware:
  • Dazzle Video Recorder ( DVC90) - Windows XP and Vista 32 bit only
  • Dazzle Video Creator ( DVC130) - Windows XP and Vista 32 bit only
  • Dazzle Video Creator Platinum ( DVC170) - Windows XP and Vista 32 bit only
  • Dazzle Video Creator ( DVC100 and DVC101) - Windows XP 32 bit, Windows Vista and Windows 7 (32 bit and Vista 64 bit)
  • Dazzle Video Creator ( DVC103) - Windows XP 32 bit, Windows Vista and Windows 7 (32 bit and Vista 64 bit)
  • Dazzle Video Creator Platinum ( DVC107) Windows XP 32 bit, Windows Vista and Windows 7 (32 bit and Vista 64 bit)
  • and other compatible hardware
Installation Instruction:
  • To be able to install this version, you must own an Instant DVD Recorder Version 2.x full version
  • To install this Instant DVD Recorder version not as an update but as a full version you need to enter your Instant DVD Recorder Version 2.x serial number during the installation process. The serial number was included in your Dazzle product.
  • With Windows Vista 64 bit or Windows 7 64 bit, you need to install Instant DVD recorder 2.6.1 as a full version.
  • If you own an Instant DVD Recorder Version 1.x full version, to only install Instant DVD Recorder 2.6.1 full version.
  • If you use this Instant DVD Recorder Updater to update the Instant DVD Recorder included with Studio Version 12, 11 or 10, please make sure that Instant DVD Recorder is already installed on you system. Please note that the version of Instant DVD Recorder included with Studio Version 12, 11 or 10 can't be installed under Windows Vista 64.
For Windows XP
http://apps.pinnaclesys.com/cdb/register/enter.aspx?checkRegistration=1&langue_id=7&supportFileID=35261&productid=2250
For Windows Vista 32 Bit
For Windows Vista 64 Bit
For Windows 7
Sep 15, 2011 | Pinnacle Dazzle DVD Recorder
I can not capture video from my camera Sony DCR-HC51E
this is due to incorrect drivers choosen for cam...just uninstall all apps related to cam alongwith drivers and reinstall them...
Jul 12, 2009 | Sony DCR-HC28E Camcorder
Canon MP500 all in one printer is not compatible with Windows Vista. Is there a solution for this problem, or do I need to buy a different printer?
My Canon PIXMA MP500, purchased in mid-2006, came with the (then) ScanSoft OmniPage SE2 software on a CD. The PC had WinXP Installed. I had no use for the ScanSoft it so I made no effort to install it.
Fast Forward:
Two PC crashes later, July 2009. Using Win Vista Home Premium
LOST, important WinWord document file, only a hard copy available.
I tried to recover, scanning the "Xerox" copy. The SE Version of OmniPage was very complicated but I succeeded in producing a replacement *.doc file.
It appears that newer editions of WinVista contain the right printer drivers for this Canon Model.
Apr 26, 2009 | Canon Pixma MP500 All-In-One InkJet...
Problem with Toshiba e-studio 280- need vista 64 bit driver
You update your copier driver for 64 bit windows suppoted.www.toshiba studio 161.com
Mar 11, 2009 | Toshiba e-Studio 161 Copier Copier
73,556 people viewed this tip
Top DekCell Televison & Video Experts
Robin Hill
Robin Hill
ka4iup
ka4iup
Clif Roberts
Are you a DekCell Televison and Video Expert? Answer questions, earn points and help others
