Tip & How-To about Plumbing
Teflon Tape .. What else can I use?
I just found a good alternative to Teflon Tape.. A good old plastic grocery bag, Yep in a pinch this works great, and may be just a permanent as the store bought tape is. Cut you a strip as long as you would use from a tape roll and wrap the pipe or what have you with the plastic bag, your back in business.
Plumbing Logo
what gallon bags does shredmaster 1256S use?
GBC Shredmaster Personal Shredder Bags Staples i use the plastic bags you get when grocery shopping they don't look pretty but they work for me
Jan 08, 2015 | Shredder Office Equipment & Supplies
tsurumi pumps parts breakdown
In order to create a good seal for these plastic fittings you can apply Teflon tape to the threads.
http://www.freshwatersystems.com/p-4968-dmfit-teflon-tape-12-w-x-60-l-4-density.aspx
Jun 04, 2013 | Plumbing
Mixing paddles come off during mixing, am using teflon tape on shaft to hold paddles on, what is a better fix?
Sound like you need new shafts or paddles and I know the paddles can cost $30 each. so think about a new model or buy one at a thrift store and try those paddle or use the machine. I got a great one for $10 . :)
Jul 30, 2017 | Black & Decker B2300 Bread Machine
hoover max extract 77 water tank leaking
Remove the little black plastic plug on the bottom of tank (has a metal spring around it), that is where it is leaking. Wrap Teflon (pipe tape) around it and the spring. Replace black plug. Not a permanent fix, but can help if you are on a bind. It worked for me.
Sep 09, 2012 | Hoover F5505 SteamVac Spot Vacuum
1,236 people viewed this tip
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
