Tip & How-To about Cameras
How to Improvise the Life of Digital Camera Batteries>
To improve the life of rechargeable batteries, Discharge them completely once in a while before charging, remove the battery from the device whenever it's not used for a long time.
(Note : this applies to all rechargeable batteries for a long and healthier Life)
Cameras Logo
Has been charging for 3 days but does not reach full charge. Now appears to be draining when plugged into charger
Sounds like a faulty charger.have you tried using another charger.have you also tried running the battery completely flat via control panel utilities.sometimes this helps the battery renew its stamina by complete discharge then doing full recharge.lastly if the charger is not faulty and you have tried full discharge and recharge cycle it could be the battery is starting to fail.it is not a good idea to leave the battery on continual charge as this can shorten its life.most batteries last between 500 to 700 recharge cycles before they start to lose their holding capacity.
Feb 01, 2016 | Computers & Internet
Headset won't recharge battery must be dead
That may very well be the case. There is a finite number of charge / discharge cycles a battery can handle. This number varies based on the level of discharge prior to charging, temperature, etc. Some devices can operate via charger alone - and others require a small amount of battery power and a charger to operate. A classic tell tale sign is an older device that has been used regularly and charged every day or night - but was allowed to fully discharge once - due to failure to connect to the charger. Attempting to charge may indicate it is accepting a charge but goes completely dead / dark when the charger is removed. That usually indicates a battery that was drained so low that it will need to be replaced. Good luck!
Oct 19, 2015 | Radio Communications
had this tablet for one day, its showing 50% .. battery, when should I recharge..
There's no harm in keeping it on charge all the time. Unlike older rechargeables, newer Li-ion batteries don't need to be broken in by running them down and then recharging.
Feb 12, 2015 | Tablets & eReaders
128 people viewed this tip
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
