Tip & How-To about Cell Phones
How to Hard reset your Nokia 5800 Xpress Music Phone?
To Hard reset your nokia 5800 nokia mobile, firsly make sure it's switched off then, Press call key(Green Button), End Key (Red Button) and the camera Key (at the right side of your mobile). Hold all together annd press the power key and wait till screen lights up with nokia logo.
that's it you are done, Now your nokia 5800 is brandnew with all factory settings reset and phone memory is cleared.
(note: Make sure you have backup all the details from the phone memory else everything will be wiped out).
Cell Phones Logo
give me nokia 5800 master code
I was also looking for that, but i couldn't find it. But i got one solution to format Nokia 5800 it doesn't work for security code.
To format or hard reset nokia 5800 press 'green key, red key and camera botton. After pressing these three botton, press the power which is located at the top. When it shake release only the power botton not the green, red and camera botton. It will start up your phone and after sometime it will display country botton and now you can release the keys. Thats it. This is call Hard Reset.
Jul 22, 2010 | Nokia 5800 XpressMusic Smartphone
I have a Nokia 5800 XpressMusic phone, I am having problems is the delivery of my sms's it goes directly to my outbox. Can anyone assist
Nokia 5800 XpressMusic Soft Reset
Using the dialing keypad type in *#7370# and then inter your lock code (default is 12345).
OR
Nokia 5800 XpressMusic Hard Reset
In order to perform a hard reset on your Nokia 5800XM, enter the following key combination
Ensure your handset is turned off then,
Press and hold the, Green key, Red key + Camera Key and press the On button.
The device will then resert in it’s default factory settings with all handset data removed.
Jun 02, 2010 | Nokia 5800 XpressMusic Smartphone
How can i fully formated my nokia 5800 express music
The reset will restore all the phone’s settings to factory default and delete all user info. You need to use the dialer to enter this code.
*#7370#
For hard reset
Switch off the phone and Press GREEN + RED + CAMERA + ON simultaneously until you see the “Select country
May 20, 2010 | Nokia 5800 XpressMusic Smartphone
my nokia 5800 xm freezes whenever i play music on it, this is a big problem especially as its an xm edition. HELP PLEASE
back up all data and perform hard reset.
In order to perform a hard reset on your Nokia 5800XM, enter the following key combination Ensure your handset is turned off then,
Regards
Apr 03, 2010 | Nokia 5800 XpressMusic Smartphone
I am using the 5800 xpress .Setting and some other icon missing in my phone.How can i get it back?
well u can restore your cell try this way
5800 Hard Reset
WANNA HARD RESET YOUR NOKIA 5800 XM?
JUST PUT *#7370# AND THEN PUT LOCK CODE(I.E 12345) BACK UP YOUR PHONE MEMORY BEFORE DOING THIS
NEW LOCK CODE METHOD FOR NOKIA 5800XM
PRESS GREEN KEY + RED KEY + CAMERA KEY WHILE BOOTING YOUR 5800 JUST PRESS IT UNTIL YOUR DEVICE RESTARTS
Mar 02, 2010 | Nokia 5800 XpressMusic Smartphone
149 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
