Tip & How-To about Computers & Internet
HOW TO SHARE FILES AND PRINTERS BETWEN WINDOWS 7 AND VISTA
With three different versions of Windows being used now, you’ll probably find yourself trying to share files or printers between them. Today we take a look at how to share files and printers between Vista and Windows 7 machines.
In this example we are on a basic home network using Windows 7 Ultimate (64-bit version) and Windows Vista Home Premium SP2 (32-bit version).
Set Windows 7 Share Settings
On the Windows 7 machine we need to set up a few things in Advanced Sharing Settings. First type network and sharing center into the search box in the Start Menu and hit Enter.
Then click on Change advanced sharing settings…
Now in Advanced Sharing Settings, make sure to turn on network discovery, file and printer sharing, and public folder sharing. Make sure these are enabled in both the Home or work and Public profiles.
Depending on your setup, you might want to turn off password protected sharing. Other wise you’ll need to enter the password for each machine in, which isn’t that big of a deal. Turning it off while you’re setting it up makes things a bit easier though by saving a step.
Set Vista Share Settings
On the Vista machine we need to double check and make sure it’s sharing settings are ready to go. Right-click on Network and choose Properties.
The Network and Sharing Center opens up. Under Sharing and Discovery we need to turn on File Sharing, Public Folder Sharing, and Network Discovery.
Also on the Vista machine you might want to turn off password protected sharing … but it’s completely up to you.
Share Files Windows 7 View
Now that we have the correct Settings On each machine, it’s time to put it to the test. Open up Network on the Windows 7 machine, and you should see all of the machines on the network. The Vista machine in this example is VISTAGEEK-PC.
There was no need to enter a password to access the Vista machine because password protection is turned off. But now you can go through and see the User Shared folders. In this example both public and Users directories are shared.
Share Files Vista View
Now on the Vista computer, double click on Network and you should see the Windows 7 machine (where in this instance it’s MYSTICGEEK-PC).
I enabled password protection on the Windows 7 machine so we can take a look at the login screen that will be displayed before connecting.
Then you’ll see the folders and devices that are shared. Here you can see the HP printer connected to the Windows 7 machine is available.
And you can continue browsing through all available shared folders and files.
Printer Sharing
As we showed above, you can see the printer connected to Windows 7. Let’s make sure we can connect to it and print a test document. In Vista click on the Start menu and type printers into the search box and hit Enter.
Right-click on the shared printer and select Properties.
Under the General tab click on the Print Test Page button.
The following message is displayed while the test page prints out on the printer connected to your Windows 7 machine.
Another test you might want to perform is opening a test document and making sure you can print that to the Windows 7 printer.
Provided everything prints out successfully you might want to make it the default printer.
Troubleshooting
If your machines aren’t able to see each other or the printer isn’t working…here are a few steps you might want to use to determine where the problem is.
Double check to make sure Network Discovery and File and Print Sharing is enabled on both machines as shown above.
In this example both machines are connected to a Belkin home wireless router and IP addresses are dynamically assigned. If you are using Static addresses make sure you can ping the IP address of each computer. If not, double check the assigned IP Address and cabling of each computer…
If the printer isn’t working, double check to make sure you have the latest drivers for each OS installed.
Computers & Internet Logo
Can Vista Home Premium be upgraded to window's 7?
      If you're running a 32-bit version of Windows Vista, you can only upgrade to a 32-bit version of Windows 7. Similarly, if you are running a 64-bit version of Windows Vista, you can only upgrade to a 64-bit version ofWindows 7. Otherwise, you'll need to use the Custom option to install Windows 7.
      Upgrading from Windows Vista to Windows 7 - Windows Help
      windows.microsoft.com/.../windows7/.../upgrading-fro... Microsoft Windows
    Feedback
    windows.microsoft.com/.../windows7/.../upgrading-f...
    Microsoft WindowsIf you're running a 32-bit version of Windows Vista, you can only upgrade to a 32-bit version of Windows 7. Similarly, if you are running a 64-bit version of Windows Vista, you can only upgrade to a 64-bit version of Windows 7. Otherwise, you'll need to use the Custom option to install Windows 7.
    How To Upgrade from Vista to Windows 7 Home Premium ...
Feb 08, 2016 | Computers & Internet
I want to install the CanoScan Lide30/N1240U but there is no driver for Windows7. So it looks like I cannot use the scanner anymore. Is there anyone who knows a solution?
Go to site
http://software.canon-europe.com/products/0000466.asp
and select OS as Vista and language as English and press submit
and download windows vista drivers.
you can use Vista driver in Windows 7 using Compatability Mode.
Step required..
1. Right click on driver installation file.
2. choose properties
3. choose compatability tab
4. select Vista
5. press ok
6. Install the driver
I hope it will help you.
Thanks for using FixYa.
May 23, 2011 | Canon CanoScan LiDE 30/N1240U
can i convert a 32 bit to a 64 bit
You can use the Upgrade option during Windows 7 installation, which preserves your files, settings, and programs, only if you're currently running a 32-bit version of Windows Vista and you want to upgrade to the 32-bit version of Windows 7. Similarly, if you are running a 64-bit version of Windows Vista, you can only perform an upgrade to a 64-bit version of Windows 7. For more information, go to Upgrading to Windows 7: frequently asked questions on the Windows website.
If you want to move from a 32-bit version of Windows to a 64-bit version of Windows 7 or vice versa, you'll need to back up your files and choose the Custom option during Windows 7 installation. Then, you'll need to restore your files and reinstall your programs. For more information about performing a custom installation, see Installing and reinstalling Windows 7‍.
gl_ico.png Notes
  • To install a 64-bit version of Windows 7 on a computer running a 32-bit version of Windows, you'll need to start, or boot, your computer using a 64-bit Windows 7 installation disc or files.
  • If you start your computer using a 64-bit Windows 7 installation disc or files, but your computer isn't capable of running a 64-bit version of Windows, you'll see a Windows Boot Manager error. You'll need to use a 32-bit Windows 7 installation disc or files instead.
  • Windows Easy Transfer can't transfer files from a 64-bit version of Windows to a 32-bit version of Windows. If you're running a 64-bit version of Windows Vista but you plan to install a 32-bit version of Windows 7, you can move your files to an external location manually or use Backup and Restore in Windows Vista. For more information, go to Back up your files and
Apr 08, 2010 | Dell Precision Workstation 490 - MT -...
303 people viewed this tip
David Payne
David Payne
