Tip & How-To about Computers & Internet
How to Connect PC to HDMI TV Step 1 Turn your computer off, and turn it around to view the rear of the unit. Find the cable that comes from the computer's monitor, and follow it to the back of the PC. The cable will be plugged into the output of the video card, which will be either a 15-pin VGA port or a 29-pin DVI port. If you are fortunate, there will be a second port directly next to it, of either the DVI or VGA variety. On the newest machines, you may even find a regular HDMI port on the card. Step 2 Choose the connection for video output. If your computer has an HDMI port, you can simply connect an HDMI cord of the correct length between the computer and the TV. Otherwise, you will need to make a few decisions. If your computer has only a single video output, and it will not be used solely with the television, you may want to invest in a new video card. Purchase one with either a DVI or an HDMI output, and install it in an available slot, according the instructions included with it. If you intend to use the VGA output on a single-output or dual-output card to drive the HDMI display, then a special device will be needed to convert between the formats, and the price of the converter is actually about the same price as an entry-level video card that will be easier to use with your TV. In that case, it may be a wise idea to upgrade the card in order to obtain a DVI or HDMI port. However, if your chosen output port is of the DVI variety, an inexpensive DVI to HDMI cable can be purchased to convert your computer's output into the proper HDMI input for your TV. Step 3 Connect the HDMI cable from your television to your computer. Install the correct adapter or converter for your computer, if necessary. Unless your computer has HDMI output, cords will also need to be connected from the sound card output to the HDMI video cable or adapter, because HDMI carries both video and audio signals. Step 4 Boot your PC, and configure the new display, by selecting "Control Panel" from the "Start" Menu. Then double-click the "Display" icon and click the "Settings" tab. The manual for your HDMI TV will list the screen resolutions it supports, along with the refresh rates. Configure the resolution in the "Settings" tab, and then click the "Advanced" button to set the refresh rate. If you are using the HDMI TV as the second monitor, you will also have to configure how it is used by Windows, according to the instructions pertaining to your video card. Most cards offer a "Clone" or "Mirror" mode, where both screens display the same content. Alternately, the "Extended Desktop" mode can be used, in which each monitor will operate independently. Step 5 Reboot your PC to apply the changes, if necessary, and prepare to relax on your couch and watch your movies on the big-screen HDMI TV.
Computers & Internet Logo
i have a lead from my tv usb, to the samsung tablet, but i dont know how to get it to connect
Step 1 Connect one end of an HDMI cable to the Samsung Galaxy Tab HDTV adapter.
Step 2 Connect the other end of the HDMI cable to a free HDMI port on your television.
Step 3 Connect your Galaxy Tab's travel charger to the other end of the HDTV adapter. Plug the travel charger into a power source, such as an electrical outlet or a computer's USB port.
Step 4 Plug the HDTV adapter connector into the Galaxy Tab's "Power/Accessory Interface" port. The port is on the bottom of the device.
Step 5 Turn on the TV. If your TV has multiple HDMI ports, use the remote control to switch to the correct one. Press the "Source" or "Input" button on the remote to switch ports. When you're using the correct port, the TV will instantly display whatever is on the Tab's screen.
Feb 05, 2015 | Samsung Galaxy Tab 2 7in. WiFi Tablet, 8GB
emachine 1401 how to connect to samsung hdmi tv
Where you able to complete the following:
1) Aquire HDMI cable
2) Connect HDMI cable to TV and Computer
3) Turn on TV and Computer
4) Set TV input source to HDMI
Nov 09, 2013 | E-Machines eMachines Desktop PC
my acer aspire 7540-1317 has a broken screen and i want to connect it to my tv but i don't know if i have the right cord, i am using an hdmi cord going from the port on the computer to the port on the tv the tv is set
You are actually well on your way. Depending upon the make and model of your television an HDMI cable is all you will need. The rest of the process will require you to go into your control panel on your laptop and using your remote for your television. I have put together the steps necessary to connect your laptop to your television
  1. Connect HDMI cable to HDMI Connection on back or side of your television ( remember if you use HDMI 1 thru 4, you will need to remember it)
  2. Turn on Laptop and let boot. Loggin using your user name and password if you have one.
  3. Turn on television
  4. On your television remote press the HDMI button for the Connector you used, example ( HDMI 1, HDMI2, HDMI3, HDMI4) You will see a no signal on the screen until you get the right one, Once you have the right HDMI connection it will say Acquiring Signal then you will see your Desktop on your computer on your television.
  5. From here it is a matter of getting the screen resolution right for the best possible viewing experience.
  6. Happy Viewing
Jul 12, 2011 | Computers & Internet
how to use rca entertainment series 32 inch as pc monitor
Assuming that your RCA 32 inch tv has an HDMI or VGA input, all you need is the proper cable to connect the two units. If your computer has a VGA out (blue female connector) and so does your TV, you would need a male to male VGA cable. If your computer has a DVI out (white connector), you would need to purchase a DVI to HDMI cable. The combinations can me played around with depending on what connectors are on the back of the TV and what you have as an output for your PC.
Feb 28, 2011 | Compaq Computers & Internet
HOW To Make MY TV WORK ON MY COMPUTER ?
Hi
Reboot your PC to apply the changes, if necessary, and prepare to relax on your couch and watch your movies on the TV.
Oct 04, 2010 | Computers & Internet
373 people viewed this tip
David Payne
David Payne
