Tip & How-To about Computers & Internet
A trick for modems (dial up)
U can try this tip,
by clicking on,
start > control panel > phone & modem options > Click modem tab, select ur modem and click properties.
Go to advanced tab and in EXTRA INTILIZATION COMMANDS write " at&fx1 " without any quotes.
Click OK and then connect to internet.
U will get a at least 115 kbps speed. ( It depends upon network traffics also but it will help for sure for some extends
Computers & Internet Logo
i can't find my modern detect to set up internet
Run the modem diagnostic tool. To do this, click "Start" and then select "Control Panel."
Select "Printers and Other Hardware" and then click "Phone and Modem Options."
Click the "Modems" tab, highlight the modem you would like to run the diagnostic test on and then click "Properties."
Go to the "Diagnostics" tab and click "Query Modem." Look for lines that read "Interpreted Response: OK" to indicate healthy modem functions. Proceed to Step 5 if you have further issues.
5
Go to the General tab and read the status of the modem. It should read "The device is working properly." If not, click "Troubleshoot" and follow the prompts to diagnose and repair the problem.
Thanks.
Have a great day.
Oct 06, 2010 | Computers & Internet
my laptop as 5534-1096 did't recognise the modem
Hello pothapalu,
Assuming this is NOT a dsl or cable modem, try the following:
The modem settings can be managed from the control panel as follows:
•Click Start (lower left-hand of screen)
•Select Control Panel
•Click Phone and Modem Options
•Select the Modem Tab
•Select the Modem Name and click properties.
•Check the properties settings and make sure the Modem is enabled and working ok.
-Device Status should be: 'This device is working properly.'
Also, review the other tabs in the properties page (General - Modem - Diagnostics - Advanced - Driver - Details).
Make a note of any setting before changing it.
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Feb 06, 2010 | Acer Aspire One PC Notebook
my acer laptop is not getting a dial tone but the phone line is good. If the modem is bad, where is it located on the laptop?
Hello flubber20054,
The modem settings can be accessed through the windows control panel as follows:
•Opening the Control Panel
The Windows Control Panel can be opened by:
Selecting *Start > Control Panel (on Windows Vista)
- OR -
Start > Run > Type 'Control' and select OK (on Windows XP)
In the Control Panel, do the following:
•Select Phone and Modem Options (Brings up the phone and modems properties sheet)
•Click on the 'Modems' tab
•Highlight the modem's name
•Click the properties button
•Look for the words 'Device Status' on that page.
If the message box says 'This device is working properly' then the modem is working ok. The Phone and Modem Options also has a tab called 'Dialing Rules'. The dial tone might work if you 'Edit' the existing Dialing Rule or Create a 'New' Rule. When you 'Edit' or create a 'New' rule, enter the requested information as best you can. You can always go back and 'Edit' the rule to keep testing it. I hope this gives you some ideas for resolving the dial tone problem.
If this solution is helpful please click 'YES' by 'Was this helpful?' below.
Have a great day,
martyshaw152
Aug 04, 2009 | Acer Aspire 5720-6661 Notebook PC
computer modem and dial tone
Hello Mikenrgrsvll
This problem can be due to the software not handling a certain dial tone rather than a specific hardware fault. Around the world there is a variance in the signal quality of the dial tone which causes a report of no dial tone detection. Disable the dial tone detection to prevent the system from trying to detect a dial tone.
Disabling dial tone detection for modems:
Windows XP
  1. Click Start
  2. Select Control Panel
  3. Click Switch to Classic View to change the control panel view
  4. Click Phone and Modem Options
  5. Select the Modem Tab
  6. Select the installed modem (Example: Lucent Technologies Soft Modem AMR)
  7. Click the Properties button
  8. Select the Modem tab in the Properties window
  9. Click Wait for dial tone before dialing to remove the check from the checkbox
  10. Select the Advanced tab
  11. Add X3 to the Extra initialization commands field in the Extra Settings box
  12. Click OK twice
  13. Select Switch to Category View to change back the control panel view
  14. Close Control Panel
if this does not work trying re-installing modem drivers.
hope this helps, have a good day.
May 04, 2009 | Acer Aspire One PC Notebook
Modem
Found this after some deep looking from blackberry itself: Good Luck
A BlackBerry smartphone with tethered modem capabilities can be used as an external modem to connect a computer to the Internet.
Summary of Tasks To set up a tethered modem, complete the following tasks:
  1. Install BlackBerry Desktop Software 4.1 or later (one time only).
  2. Set up the Internet access point name (APN) (one time only).
  3. Configure dial-up networking (one time only).
  4. Connect to the Internet using dial-up networking.
Task 1
Install BlackBerry Desktop Software 4.1 or later on your computer.
When you install BlackBerry Desktop Software, the drivers that allow the BlackBerry smartphone to communicate through the Universal Serial Bus (USB) port and virtual communications port are installed. The standard modem, which is used by dial-up networking, is also installed.
Note: If upgrading your BlackBerry Desktop Software from version 4.0 to 4.1, the required virtual communications port and standard modem might be removed during the upgrade process. If this is the case, re-install the BlackBerry Desktop Software 4.1 or later and choose the Repair option to re-install these components.
Task 2
Set up an Internet APN.
  1. Click Start > Settings > Control Panel.
  2. Double-click Phone and Modem Options.
  3. In the Phone and Modem Options window, click the Modems tab.
  4. Select Standard Modem and click Properties.
  5. Click Change Settings.
  6. In the Standard Modem Properties window, click the Advanced tab.
  7. In the Extra initialization commands field, type the following: +cgdcont=1,"IP","<your Internet APN>"
    Note: The following is applicable for T-Mobile® customers only:
    The extra initialization command is: +cgdcont=1,"IP","wap.voicestream.com"
    Note: If you do not know your Internet APN, or if you do not have an Internet APN, contact your service provider.
  8. Click OK.
  9. In the Phone and Modem Options window, click OK.
Task 3
To configure dial-up networking, complete the procedure that is appropriate to the operating system you are using:
Windows Vista
  1. Click Start.
  2. Select Connect To.
  3. Click Setup a connection or network.
  4. Click Setup a dialup connection.
  5. In the Dial-up phone number field type *99#.
  6. Type the user name and password provided by your service provider.
  7. In the Connection Name field type BlackBerry.
  8. Click Dialing Rules.
  9. Make sure the profile created in Task 2 has been selected, and then click OK.
  10. Select Connect to establish an internet.
Note: For instructions on connecting a computer to the Internet using a BlackBerry smartphone with CDMA as a tethered modem, see KB04664.
Windows XP operating system
  1. Click Start > Settings > Network Connections.
  2. Double-click New Connection Wizard. The New Connection Wizard opens.
  3. Click Next.
  4. Select the Connect to the Internet option. Click Next.
  5. Select Set up my connection manually. Click Next.
  6. Select Connect using a dial-up modem. Click Next.
  7. If the Select a Device screen appears, select the Modem - Standard Modem check box. Click Next.
  8. In the ISP Name field, type a name for your connection. Click Next.
  9. In the Phone number field, type *99#. Click Next.
  10. Indicate which users will have access to the connection. Click Next.
  11. Type the user name and password provided by your service provider. Click Next.
  12. Click Finish.
  13. In the Connect window, click Properties.
  14. In the Properties window, verify that Modem - Standard Modem appears beneath the Connect using heading, and then click Configure.
  15. In the Modem Configuration window, clear the Enable hardware flow control check box and make sure none of the other check boxes are selected. Click OK. In the Properties window, click OK.
Windows 2000 operating system
  2. Double-click Network and Dial-up Connections. Note: The following is applicable for T-Mobile customers only:
    Under the networking tab in the properties window for the dial-up connection, clear the Enable LCP Extensions check box, as well as all check boxes beneath the PPP Settings window.
  3. Double-click Make New Connection. The Network Connection Wizard opens.
  4. Click Next.
  5. Choose Dial-up to private network. Click Next.
  6. In the Phone number field, type *99#. Click Next.
  7. Indicate which users will have access to the connection. Click Next.
  8. Type a name for your connection. Click Finish.
  9. In the Connect window, click Properties.
  10. In the Properties window, verify that Modem - Standard Modem is selected, then click Configure.
  11. In the Modem Configuration window, clear the Enable hardware flow control check box and make sure none of the other check boxes are selected. Click OK.
  12. In the Properties window, click OK.
Task 4
Note: During this procedure, do not operate the BlackBerry® Browser or any third-party applications on the BlackBerry smartphone. An active data session might interfere with the modem connection. Also, make sure an ethernet connection is not active at the same time.
  1. Connect the BlackBerry smartphone to the computer.
  2. Open BlackBerry Desktop Manager.
  3. Click Start > Settings > Network Connections > <name of your new connection>.
  4. Type the user name and password provided by your service provider.
  5. Click Dial.
Apr 07, 2009 | RIM Blackberry 8310 8320 8330 Curve 8100...
138 people viewed this tip
David Payne
David Payne
