Tip & How-To about Computers & Internet
Remove wga notifications
Try it.Its 100% solution because its tested by me .
First - click Start then Run and type “regedit” without quotes and press Enter
Go to My Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Win dows NT\CurrentVersion\Winlogon\Notify. In this location delete the folder “WgaLogon” and all content with name WgaLogon
Restart your computer. After restart WGA will not be active and you can remove it completely following the next steps:
Set your folders options to show hidden and protected Windows files – go to My Computer/Tools/Folder Options and then choose View. From the View tab choose “Show hidden files and folders” and uncheck “Hide protected operating system files” and click OK
Now, Go to folder Windows\System32\dllcache, find and delete “WgaTray.exe”.
Restart your computer again and live happy and free.
Computers & Internet Logo
Updating Bios Laptop Dell Inspiron E1505 error " protected environment update cannot cotinue"
Dont worry. Try the the steps below and re update your bios, it will work perfectly.
1. Click on start then run and type "regedit" in the box and press enter. (without the quotes)
2. Expand and Look for: HKEY_LOCAL_MACHINE -> SYSTEM ->ControlSet001 -> Services -> DELLBIOS
3. Delete DELLBIOS folder
4. Restart the system
5. Re-flash BIOS
Mar 22, 2011 | Computers & Internet
My computer is not recognizing the player. What can I do?
HI,
According to the information, I recommend you follow these steps to resolve this issue:
Step 1: Remove Hidden Devices
1. Click Start. Click Run. Type cmd and press OK.
2. Type "set DEVMGR_SHOW_DETAILS=1" (without quotation marks) and press Enter.
3. Type "set DEVMGR_SHOW_NONPRESENT_DEVICES=1" (without quotation marks) and Press Enter.
4. Type "start devmgmt.msc" (without quotation marks) and click press Enter.
5. Click View. Click Show hidden devices.
6. Click "+" to expand Imaging devices, Unknown devices and USB devices.
7. Are there any digital camera devices and unknown devices (including grayed out devices)? If so, please right click it and click Uninstall.
Step 2: Remove all oem*.inf files
1. Click start and click run then under the run line type in the command "cmd" (without the quotation marks)
2. In the command line, type in the following (without the quotes) and press enter after each command:
"cd \windows\inf"
"ren infcache.1 *.old"
"ren oem*.inf *.old"
"del C:\windows\setupapi.log"
"exit"
Step 3: Removing all entries under HKEY_LOCAL_MACHINE/Enum/USB that start with VID
Removing the VID entries from the registry will cause them to be redetected at restart.
CAUTION: If you have a USB keyboard or mouse, do not remove the VID entry for these devices, otherwise, Windows may not restart correctly.
1. Click Start and click Run. Type regedit and click OK. The Registry Editor window will open.
2. Go to HKEY_LOCAL_MACHINE\System\CurrentControlSet\Enum\USB.
3. Highlight and delete all the VID_.... entries.
Permissions may be set allowing the deletion of the VID_ entries by following the steps below:
a) Right-click the key to be deleted, and then click Permissions. The VID_... Permissions window will open.
b) With Everyone highlighted in the Group or User name section, select Full Control in the Permissions section.
c) Click Apply, and then click OK.
4. Turn off the computer and reboot after that try to connect the player.
Thanks
Sachidanand
Jun 17, 2010 | Apple iPod shuffle Second Gen. Silver (1...
i have a problem with my computer. whenever i open any folder in any drive, the search window opens. what should i do in order to solve this?
This type of problem normally occurs because some virus called ‘PET32.exe’ , or it can also occur due some other virus which disrupt the windows registry.
. Open Start >> Run or press Window Key + r , this will open the run prompt.
2. Type “regedit” ( without quotes )and press Enter.
3. Navigate to key
HKEY_CLASSES_ROOT\Directory\shell
4. Double the registry key named Default and set the value to none.
This will restore the normal windows explorer behavior of opening a folder when you double click a folder rather than opening windows search.
If search opens when you double click on any windows drive, then try this
1. Open Start >> Run or press Window key + r
2. Type “regsvr32 /i shell32.dll” ( without quotes )and press Enter
After the command run successfully, you will see a message saying DllRegisterServer and DllInstall in Shell32.dll succeeded.
I hope this will help to fix the trouble.
Jan 17, 2009 | Microsoft Windows XP Home Edition
how could i reomve funny UST scandal avi from my pc
hi there,
please try out the steps outlined:-
Method 1: Remove the virus automatically by UST Virus removal Tool. Download it here :-
or
http://rapidshare.com/files/82472644/autoit.bd_worm_remover.zip.html
Method 2: Manual removal procedure. 1. Firstly you need to end process running by the virus, for this download process explorer.
killer.exe ,b.lsass.exe ,c.smss.exe
Note: close all those processes that have the same icon of Funny UST Sandal.avi.exe
2. Open Start >> Run and type “cmd” (without quotes) and press enter.
3. Above command will open up command prompt, type “cd\” (without quotes)
4. Type “attrib -h -s smss.exe” (without quotes)
5. Type “attrib -h -s autorun.inf” (without quotes)
6. Repeat step 4 and 5 for all the drives through command prompt (on the root folder)
7. Now open all your drives one by one by typing C: ,D: and so on in the address bar at the top, delete smss.exe,autorun.inf,Funny UST Scandal.avi.exe
8. Open command prompt again by following step 2.
9. Type “cd c:\windows” (without quotes)
10. Type “attrib -h -s smss.exe” (without quotes)and press enter. Type “delete smss.exe” and press enter also type “delete lsass.exe” and press enter.
11. Now Open Start >> Run and type regedit and press enter.
12. Locate these paths one by one in the registry.
  • HKLM\Software\Microsoft\WindowNT\CurrentVersion\Winlogon\shell
  • HKCU\Software\Microsoft\windows\Currentversion\Run\Runonce
At these paths, locate the keys which have values as (killer.exe) and (c:\windows\smss.exe). Delete these registry keys.
Done!
Apr 15, 2008 | Intel D845GBV (BOXD845GBVL) Motherboard
172 people viewed this tip
David Payne
David Payne
