Tip & How-To about Computers & Internet
Disable Notification Balloons in XP
If you are annoyed with Windows popping up a balloon notification telling you things you already know every time you turn on your machine, here is a quick tip on completely disabling them. (Note this requires a registry modification so be sure to back up your registry before making any changes.)
You should note that this will disable all balloon notifications, so proceed with caution.
Click on Start \ Run and type in regedit
Now we will navigate to this path in your registry.
HKEY_CURRENT_USER\Software\Microsoft\Windows\Curre ntVersion\Explorer\Advanced
On the right pane right click on an open area and choose New \ DWORD Value
You will see New Value #1. Change this to EnableBalloonTips.
Next double click the new registry entry you created. In the Value Data field set it to 0 (zero). Make sure Hexadecimal is selected under Base. Click OK.
Finally restart your system and enjoy the clean boot up with no balloons popping up at you.
To remove this registry hack, just delete the registry key that you created.
Computers & Internet Logo
optimal resolution notification balloon saying "this is not the primary optimal display for the device.the optimal resolution is 1360 * 768." while playing games. why is it so? plz help me......
Find the Intel Graphics Media driver in the System Tray. Right Click on it --> Graphics Options --> Balloon Notification --> Optimal Resolution Notification --> Disable
Aug 21, 2010 | LG Computers & Internet
Wga notification of software counterfeit keep popping up with a black screen
Your copy of Windows is not Genuine when you updated your system from microsoft update site.
May 20, 2010 | Microsoft Get Genuine Kit for Windows XP...
Windows XP Notification tray Bubbles/Notifications No longer show
Right click on the taskbar and look at properties. Uncheck "Hide inactive icons".
If already unchecked, try:
Start-Run type gpedit.msc and select ok.
In User config, open Start menu and Taskbar,
Double-click Turnoff Notification Cleanup in the right panel, select Enable and apply.
Good luck.
Close gpedit.msc and reboot.
Jun 13, 2009 | Microsoft Windows XP Home Edition
155 people viewed this tip
David Payne
David Payne
