Tip & How-To about Computers & Internet
Important TIP fot Mac Laptops
Never overcharge your laptops.. It reduces their battery life! Always switch off the charger as soon as the battery gets full..! :)
Computers & Internet Logo
i have 3110 mobile i m havvving charging problem what should i do
try to change your battery, maybe it's worn out. 2nd, maybe your charger is broken. if you have another nokia cellular phone with the same charger, try to charge it up. if it won't charge, then, your charger is damaged. an advice: let your battery be drained before you charge it up so that your battery will last a bit longer than the actual battery life itself and don't overcharge it also. if it is full, unplug your charger always.
Nov 01, 2010 | Nokia 3110 Cellular Phone
Increase Your Laptop Battery Life
http://www.discount-laptop-batteries.co.uk/sony-vgp-bps8.htm
Feb 02, 2010 | Computers & Internet
bad battery ???
It sounds like the battery has just enough "juice" to give the small light some power, but when the larger light is turned on it overloads the bad (or expired) battery. When you put a new battery in you can extend the life by not using the light when the battery starts to die. This is when it starts to permanently damage the battery. Turn it off and recharge as soon as it dims. Charge often, but don't leave on the charger too long unless it is a smart charger and turns off when the battery is fully charged. This will also reduce the life. You can find a replacement battery here: http://batteryinternational.com/spotlight-batteries-vector-battery.html
Jan 16, 2009 | Camping, Backpacking & Hiking
laptop battery
It does charge until the battery reaches full charge, then charger stops and laptop use adapter's power. The whole system is thought to not damage or wear the battery while in charge. Leave battery safely inside your Dell while using it with power adaptor, it should not make any difference in your battery life.
regards
Mar 21, 2008 | Dell Inspiron 6400 Notebook
e260 4gb sansa not turning on
some may be due to low battery power or due to software problem...while charging stop once the charge gets full,...dont overcharge the battery,,,,,,the battery life gets reduced
Jan 03, 2008 | SanDisk Sansa e260 MP3 Player
102 people viewed this tip
David Payne
David Payne
