Tip & How-To about Computers & Internet
Double clicking C:drive gives "open with window"
Hi Friends,
- Run a full system virus scan (make sure the anti-virus is updated).
- Remove the virus if any
- Go to Start>Run.type cmd and hit enter
- Type the commands as follows:
cd\ (hit enter)
c:
attrib -h -s -r * .inf
del *.inf
You can try this with every drives which gives you this error.
Regards
Chiranjeet
Computers & Internet Logo
program/virus removal
Not quite sure what you mean by how do i remove do searches ?
There are two possiblities
Oneyour old anti-virus setting is not remove from your PC.
Install crap cleaner (ccleaner) to get rid of the anti-viruses left over setting in the windows registry.
http://www.softpedia.com/progDownload/CC...
Two - a virus is preventing you from installing anti-virus
Use another clean PC to download Clamwin portable anti-virus and install it on a USB pen drive.
http://portableapps.com/apps/utilities/c...
Document on how to configure ClamWin
http://support.real-time.com/open-source...
Start Clamwin anti-virus and update the latest anti-virus definition files.
Select the tools menu bar, set the preferences to remove virus.
Start the infected PC in safe mode by pressing F8 during start up.
Run the Clamwin Anti-virus on the USB pen drive to scan the infected PC.
or
If you have tried all the various AV Removal Tools to look for expired/leftover remnants of other AVs, I\'d suggest scanning your System for Malware.
Malware will often stop you downloading Security Products.
Download, install, update and scan with each of the two programs below to check for/remove Malware/spyware.
If necessary, do all the above work in Safe Mode with Networking.
To get into Safe Mode with Networking, tap F8 right at Power On / Startup, and use UP arrow key to get to Safe Mode with Networking from list of options, then hit ENTER.
Read all info below before starting:
http://www.malwarebytes.org/mbam.php
Malwarebytes is as the name says, a Malware Remover!
Download the Free Version from the link above.
Download, install, update and scan once a fortnight.
http://www.spybot.info/en/index.html
Spybot Search & Destroy 1.6.2 is a very good, FREE Anti-Spyware Program.
Download, install and update it.
Then SCAN with it.
Update it, and scan your System once a fortnight.
Jan 26, 2014 | Computers & Internet
blue screen and freezes randomly
There could be hard disk errors that need to be fixed, or there could be files in your OS that are missing. First you should login to an account that has administrator privileges and go to Start, select Run and in the Run window type CMD and then hit enter to bring up your command prompt. If you're using Vista or Windows 7, go to the Start Orb and type CMD into the search bar, then right+click CMD and pick "Run as Administrator." Now, in the command prompt, type SFC /SCANNOW and hit enter. If you're missing any files you will be prompted to insert your Windows disc, it is quite possible that you don't have one, but the main reason you're doing this is to see if you're missing OS files because if you are then that will immediately explain the blue screens and freezes because parts of your Operating System are gone. Anyway, it will prompt you for a specific disc, if you don't have it and you don't know anyone who has it then you can't complete the scan, so stop/cancel it and run it again when you get the CD. For now though, let's work with what we have. We want to see if your harddrive is damaged. In command prompt type CHKDSK /R this will scan your harddrive for errors and repair them on the next reboot (this scan will take at least 40min). After all of that, you should run a PC/Registry optimizer such as Glary Utilities http://www.glaryutilities.com/ (I prefer this one because it's free and simple to use. Tell it to scan after you install it and then tell it to repair the issues it finds.
Scanning with an anti-malware program, an anti-rootkit program, and an anti-spyware program certainly won't hurt anything. The 3 free programs I use are
http://www.malwarebytes.org/ -- Anti-Malware
http://www.sophos.com/products/free-tools/sophos-anti-rootkit.html -- Anti-Rootkit
http://www.superantispyware.com/ -- Anti-spyware
If you don't have any antivirus program installed, Avast! http://www.avast.com/lp-upgrade-4-5-free# Is a great one, but it does not work well at all with other anti-virus programs, so don't install it if you have another anti-virus program (such as Norton Antivirus, Panda Anti-virus) running.
Hope this helps!
Dec 16, 2010 | Microsoft Computers & Internet
My computer is so slow could it be that i have formatted it several times? when i want to remove programs from the control panelit tells me that access denied. When i down load an anti virus in my flash and want to install to my pc it cant the setup is corrupted. My pc is not connected on internet. What can i do?
Your system probably has a virus. The fastest way to solve is to do a new installation of Windows. You would need a bootable CD to format and install Windows.
CAUTION: FORMATTING A HARD DRIVE WOULD ERASE ALL OF YOUR DATA. WHICH WOULD MAKE IT IRRETRIEVABLE.
For further help, please feel to ask me.
Jul 09, 2010 | Computers & Internet
drives open in seprate window
  1. Windows XP: Go to Start -> Run... and type cmd
  2. Windows Vista: Open Start menu and type cmd
  3. Hit Enter
  4. Type del C:\autorun.inf /ah /as /ar.
  5. Press Enter
  6. Repeat steps 4 and 5 replacing the letter C with the letters of your disk partitions.
You have got some nice piece of virus. This is only temporary solution, as the virus will come back. Make sure you install some good anti-virus utility (Kaspersky recommended) and update it.
Jan 15, 2009 | Microsoft Windows XP Professional
windows explorer
This could be due to a spyware/virus. Have you tried running a virus scan? As you can still get online try an online virus scan: http://www.pandasecurity.com/homeusers/solutions/activescan/ click SCAN PC NOW
Sep 02, 2007 | Acer Aspire E380 ASE380-UD500A PC Desktop
149 people viewed this tip
David Payne
David Payne
