Tip & How-To about Heating & Cooling
How to make a/c blower more efficient
Disconnect power, remove panel for blower, remove screws, slide out blower. 1. oil motor 2. take damp rag or q-tip, wipe along each blower fin, the fins are made with a pitched angle for maximum air movement. if dust and other particals build up on fins the blower does not dispence maximum amount of air.due to pitch being altered by partical build up. by wiping off dust and build up, u allow blower to operate at its peak perfomance. re-assemble blower housing, reconnect power
Heating & Cooling Logo
Do you access the blower motor on an 04 bonneville from under the hood or passenger side behind the glove box?
passenger side under the glove box ,
Remove the right side sound insulator. Refer to Instrument Panel Insulator Panel Replacement - Right Side in Instrument Panel, Gages and Console.
Disconnect the electrical connector (1) from the blower motor.
Disconnect the blower ventilation tube (2) from the module.
Remove the blower motor screws (3).
Remove the blower motor from the housing.
Removal Procedure
Remove the fasteners at the rear edge of the insulators in order to disengage from the lower instrument panel.
Pry out the retainers in order to release.
Turn the heater temperature sensor 1/4 turn in order to release and allow to remain connected to its wire (CJ2 vehicles only).
Disconnect the electrical connectors.
Slide the insulator rearward in order to remove.
Sep 11, 2016 | 2004 Pontiac Bonneville
How to replace blower wheel on Friedrich SL28M30 AC unit
follow this steps and fix it. God bless you
    • 1
      Turn the electricity to the air conditioning unit off at the
      service disconnect box. Follow the wires from the AC unit to the
      disconnect box, usually located next to the unit. Open the disconnect
      box and, depending on the type, either pull the buss-bar or flip the
      disconnect switch.
    • 2
      Open the air handler\'s access panels with the correct size of nut driver, usually 5/16- or 1/4-inch. Save the screws.
    • Remove the control panel\'s cover, if equipped, with a nut
      driver. Some models have a flat metal cover over the electronic
      controls, and some control panels butt up to the unit\'s access cover.
      Save the screws and access cover.
    • 4
      Follow the wires from the blower motor. Two wires will go to
      a capacitor located on the blower\'s housing. The rest of the wires will
      go to the control panel.
    • 5
      Cut the wires leading into the control panel with wire cutters. Leave the cut wires connected inside of the control panel.
    • 6
      Remove the retaining bolts with either a nut driver, usually
      3/8-inch, or an adjustable wrench. The retaining bolts, found on the
      mounting brackets that the blower\'s housing slides on, keep the blower\'s
      housing locked into position. Save the bolts.
    • 7
      Slide the blower motor\'s housing out of the AC unit. The housing will slide straight out along the mounting brackets.
    • 8
      Disconnect the two wires going to the capacitor. They will pull straight off the capacitor\'s terminals.
    • 9
      Unscrew the squirrel cage\'s locking-screw with an adjustable
      wrench. The squirrel cage, the bladed wheel, connects to the blower
      motor\'s shaft inside of the housing. The locking screw holds the
      squirrel cage to the shaft.
    • 10
      Unscrew the blower motor\'s mounting screws with either a nut
      driver, usually 3/8-inch, or an adjustable wrench. These screws hold
      the motor to the housing and are found on the opposite side of the
      squirrel cage, the same side that the wires leave the motor.
    • 11
      Pull the motor from the housing. A drop of oil on the shaft
      will aid in removal. If the squirrel cage sticks to the shaft, then hold
      the shaft still with an adjustable wrench while spinning the squirrel
      cage on the shaft.
    • 12
      Slide the new blower motor into the housing. The blower motor\'s shaft will slide into the squirrel cage\'s hole.
    • 13
      Tighten the blower motor\'s mounting screws.
    • 14
      Spin the blower motor\'s shaft until the flat part of the
      shaft lines up with the squirrel cage\'s locking screw. Move the squirrel
      cage in or out until it does not touch the housing or the blower motor.
      Tighten the locking screw.
    • 15
      Connect the blower motor\'s capacitor wires, usually brown or
      brown with white stripes, to the capacitor. Direct replacement motors
      use the same color-coded wires as the original.
    • 16
      Slide the blower motor\'s housing into the AC unit along the mounting brackets. Install the mounting bracket\'s retaining bolts.
    • 17
      Connect the new blower motor\'s wires in the control panel
      one at a time. Disconnect one old wire in the control panel. Determine
      its color and connect the new wire, of the same color, to its place. Do
      this for all wires.
    • 18
      Replace the control panel\'s cover, if equipped, and the
      unit\'s access cover. Turn on the power to the unit at the disconnect box
      and test the blower motor.
Jul 17, 2013 | Friedrich Kuhl Series SL28M30 230 Volt,...
update to the problem with the ac motor making noise; i found that a small plastic bag i had in the glove box has been sucked up into the fan motor how do i get it out
Removal & Installation
  1. Disconnect and isolate the negative battery cable.
  2. If equipped, remove the instrument panel silencer from the passenger side of the instrument panel.
  3. Remove the glove box from the instrument panel.
  4. Disconnect the blower motor wire harness connector (1) from the blower motor power module or resistor (2), depending on how equipped.
  5. Remove the three screws (3) that secure the blower motor (4) to the HVAC housing (5).
  6. Remove the blower motor from the HVAC housing.
To install:
  1. Position the blower motor into the HVAC housing.
  2. Install the three screws that secure the blower motor to the HVAC housing.
  3. Connect the wire harness connector to the blower motor power module or resistor, depending on how equipped.
  4. Install the glove box into the instrument panel.
  5. If equipped, install the instrument panel silencer onto the passenger side of the instrument panel.
  6. Reconnect the negative battery cable.
Jul 10, 2012 | 2008 Jeep Grand Cherokee
How to replace the blower motor in a dodge 2001 caravan
  2. Remove the right quarter trim panel as follows:
    1. Remove first rear seat. Remove the second rear seat, if equipped.
    2. Remove the sliding door sill plate.
    3. Remove the quarter trim bolster.
    4. Remove the upper C-pillar trim and D-pillar trim panel.
    5. Remove the first and second rear seat belt anchors.
    6. Remove the screws securing the quarter trim to quarter panel from the bolster area.
    7. Remove the screws securing the rear edge of the quarter trim to the support bracket.
    8. Carefully disengage the hidden clips securing the front of the quarter trim to the quarter panel just rearward of the sliding door opening.
      Fig. Removing the trim panel to access the rear blower motor
    9. Disconnect the wiring harness connector from the accessory power outlet, if equipped.
    10. On long wheelbase wagons only, remove the quarter trim from the quarter panel and pull second rear seat belt through access hole.
    11. Pull first rear seat belt through the access hole.
    12. Remove the quarter trim panel from the vehicle.
  3. Remove the 5 screws mounting the A/C-heater blower motor housing to the rear HVAC unit (one mounting screw located on evaporator cover).
  4. Twist the blower motor out of scroll housing.
  5. Disconnect the blower motor wiring connector.
  6. Remove the blower motor from vehicle.
    Fig. The rear blower motor is held in place by four screws
To install:
  1. Install the blower motor unit into the vehicle.
  2. Reconnect the blower motor wiring connector.
  3. Secure the blower motor into scroll housing.
  4. Install and tighten the 5 screws mounting the A/C-heater blower motor housing to the rear HVAC unit (one mounting screw located on evaporator cover).
  5. Install the right quarter trim panel as follows:
    1. Install the quarter trim panel in position in the vehicle.
    2. Insert and pull the first rear seat belt through the access hole in quarter trim panel.
    3. On long wheelbase wagons only, insert and pull the second rear seat belt through access hole in quarter trim panel.
    4. Reconnect the wiring harness connector to the accessory power outlet, if equipped.
    5. Engage the hidden clips to secure the front of quarter trim to quarter panel rearward of sliding door opening.
    6. Install the retaining screws that secure the rear edge of quarter trim to support bracket.
    7. Install the retaining screws that secure the quarter trim to the quarter panel in bolster area.
    8. Install the second rear seat belt anchor (if equipped), and the first rear seat belt anchor.
    9. Install the D-pillar trim panel and upper C-pillar trim.
    10. Install the quarter trim bolster.
    11. Install the sliding door sill plate.
    12. Install the second rear seat, if equipped, and install the first rear seat.
  6. Reconnect the negative battery cable. Check blower motor operation.
Hope helps (remember to rate this).
Nov 01, 2010 | 2000 Dodge Caravan
270 people viewed this tip
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
